Looking for JCW PRO Rear Diffuser PDC 51192339046
Old Aug 21, 2022 | 03:46 PM
MikeMJCW's Avatar
MikeMJCW
Looking for a JCW PRO REAR DIFFUSER PDC 51192339046. Doesn't appear to be in stock anywhere. If you folks know of any dealer/shop etc (preferably in USA) that has one please let me know. I'll start calling around next week.
Old Aug 21, 2022 | 06:24 PM
RichsMINI's Avatar
RichsMINI
@MikeMJCW, many sites list this part as “no longer available” however on FCP Euro and @WayMotorWorks sites it appears you can still place an order.
I would also contact MINI Bedford, Flow MINI or Seattle MINI parts department to see if they have it in-stock.
Good luck with the search
Rich
Old Aug 22, 2022 | 01:31 PM
MikeMJCW's Avatar
MikeMJCW
Woo Hoo- Mini of Peabody had it in stock- sitting on my table now. Next step getting the center portion of it painted.
Old Aug 22, 2022 | 04:35 PM
RichsMINI's Avatar
RichsMINI
@MikeMJCW, that is awesome and congrats
In case you need any video instructions for the installation (it’s pretty straightforward) here are a few from YouTube which are great references.
Car Creations:
https://m.youtube.com/watch?v=HjajFyLtH8U
tweedbean:
https://m.youtube.com/watch?v=Fycos2k1lZQ
The MINI Vlog: (This is it being installed on my MINI)
https://m.youtube.com/watch?v=2Cr7iCMrmcY
I cannot wait to see the center part painted and installed!
Rich
Old Aug 22, 2022 | 05:32 PM
MikeMJCW's Avatar
MikeMJCW
Thanks Rich, I got the paint idea from this gentlemen
Old Sep 1, 2022 | 10:23 AM
These were blocked by MINI, I am checking to see whats going on because they were NLA as they were out of stock and set nla in the system. No dealership in the USA can order them, you got lucky they had them on shelf.
https://www.ecstuning.com/Search/Sit..._19_2_339_046/
and
https://www.ecstuning.com/b-genuine-...c/51192339047/
Old Sep 1, 2022 | 11:15 AM
MikeMJCW's Avatar
MikeMJCW
These were blocked by MINI, I am checking to see what's going on because they were NLA as they were out of stock and set nla in the system.
Wonderful, they probably fall off being that they're mostly glued on. Thanks for checking.
Mine is currently being painted by the dealer.
Old Sep 1, 2022 | 06:34 PM
RichsMINI's Avatar
RichsMINI
@MikeMJCW, I’ve read on other forums about the glue not adhering properly or the diffuser shifts and will sag
Maybe they aren’t using Betalink adhesive and taping it into place for a few hours after but who knows…
We used 3M adhesive so it can be taken off if needed and after multiple washes and one winter it hasn’t moved
Looking forward to seeing it painted and installed on your MINI.
Rich
Old Sep 2, 2022 | 05:03 AM
MikeMJCW's Avatar
MikeMJCW
Maybe they aren’t using Betalink adhesive and taping it into place for a few hours after but who knows…We used 3M adhesive so it can be taken off if needed and after multiple washes and one winter it hasn’t moved Looking forward to seeing it painted and installed on your MINI.Rich
Thanks Rich,
Saw on the F56 forum a BMW dealer (England) used white glue, then proceeded to scratch the guy's car up. I got the Betalink from ECS, local dealer said he could only order during a chemical order?
Got a pick of your car's diffuser?
Old Sep 2, 2022 | 06:31 AM
Yep we have the beta link and thats the best stuff to use as its used on body kit, wings, and other stuff since BMW in the 90's used it.
MINI requires it on certain applications.
Old Sep 2, 2022 | 11:13 AM
RichsMINI's Avatar
RichsMINI
@MikeMJCW,
I realized I have no close-up pictures and I will take some and add them to this thread.
Maybe for you next modification you could enable the rear fog lights . I did it and here’s the post about it:
https://www.northamericanmotoring.co...unctional.html
Old Sep 2, 2022 | 04:12 PM
MikeMJCW's Avatar
MikeMJCW
@MikeMJCW, Maybe for you next modification you could enable the rear fog lights . I did it and here’s the post about it:
Maybe because your car's red the rear fog lights look particularly sweet! I might look into the switch, picking up the diffuser tomorrow.
Old Sep 3, 2022 | 04:38 PM
MikeMJCW's Avatar
MikeMJCW
Pic is dry fitted. Thunder grey insets, gloss black band (to match roof and side pillars). I asked the body shop guys for advice, not my thing. Love the color combo, the diffuser itself isn't 100% i.e. a bit after thought-y,
Whenever you see glue or Loctite 9 times out of 10 the engineers goofed something. Speaking of goofed- if you forget to hook up the back up sensors (or need to replace the fog bulbs) simply remove rear wheels and unfasten the wheel arch liners. This gives access to rear mounted fog light housing bolts. Added a before pic, not using splash guards as the Hankooks don't pick up crap.
Old Sep 4, 2022 | 02:55 PM
RichsMINI's Avatar
RichsMINI
HOT DAMN!! That’s one good looking painted diffuser Congrats…
Off topic, what brand race ramps are those? I was looking for a set and have been overwhelmed with brands and reviews.
Old Sep 4, 2022 | 03:43 PM
MikeMJCW's Avatar
MikeMJCW
Rhino ramps 11909. I paid $50 with a coupon a few years ago at Advance Auto. I built the extension (bolt hole in the Rhino logo) for an Alfa Giulia I had. My mini was originally dropped 10mm but has probably settled a bit and it does scrap the front a little bit without the extension. The diffuser had cured but this afternoon I parked the rear facing the sun and I saw the diffuser pull away and the glue had softened. So much for $60 Betalink. What 3M did you use?
Old Sep 5, 2022 | 03:29 AM
RichsMINI's Avatar
RichsMINI
@MikeMJCW, thank you for that information about the ramps. I will be picking up that model.
Here’s the link to the 3M automotive adhesive we used:
3M Adhesive: Amazon 3M Adhesive: Amazon
For best adhesion use an alcohol wipe and clean the inside lip of the rear diffuser and the top of the brackets that were installed into the rear bumper.
Place the 3M on the top area of the brackets (10) going down the entire length.
bluonyx
Feb 17, 2019 07:04 AM
j5ktt
Aug 3, 2017 06:39 PM
CK Williams
Jul 2, 2017 09:51 PM
B-_-RAD
Feb 13, 2015 08:27 AM
