HELP: Where to buy oem parts?
I'm new to the mini scene and just found out my car is heating/losing coolant, I need;
Water pump
Water pump housing
Thermostat
Where is the best place to buy great parts at a low price? How much should it cost me? Anything else I should replace at this point? 2009 MCS 97k miles.
Water pump
Water pump housing
Thermostat
if you do both thermostat and pump, also replace the pipe between them. The pump and thermostat are essentially seperate jobs by the way, you really ought to take the time to find the leak instead of just replacing everything.
There are several vendors on this forum each carrying various items. Visit their websites. Any number would be pleased to help you if you make contact with them.
We keep all that in stock,
R56 thermostat
http://www.waymotorworks.com/thermos...5-r56-r57.html
New OEM aluminum water pump, you prob have old plastic one and that is why it is leaking
http://www.waymotorworks.com/water-p...8-r59-r60.html
And water pump pipe
http://www.waymotorworks.com/water-p...9-r60-r61.html
Can ship it all tomorrow, we combine shipping on orders to ship as cheap as possible for you.
R56 thermostat
And water pump pipe
Water pump
Water pump housing
Thermostat
Water pump
Water pump housing
Thermostat
We have everything to look for here with a DIY linked.
https://www.northamericanmotoring.co...8-no-heat.html
Water pump
Water pump housing
Thermostat
Water pump
Water pump housing
Thermostat
888.280.7799 | 6am - 5pm PST
Or https://www.automd.com/shops/
http://www.autoblog.com/auto-repair-shops/
You can get OEM parts from ECSTuning, PelicanParts, and WayMotorWorks. All great vendors. They also all regularly post here, as you've already seen. Another great resource to BMW and MINI owners is realoem.com. You just punch in the last 7 characters of your VIN and you can browse exploded diagrams of every single system in your car, complete with part numbers, supplier pricing, and the dates through which each part was used in production. They even have listings of retrofit kits for stuff your car may not have been optioned with. Really great resource that most other car manufacturers do not have.
Thanks for the support.
Realoem.com is a great tool when you look for the 11 digit part number. You can also use our ECSTuning site. Realoem.com has most of the catalog, but not all, some part number don't show up like ( 11614584240 ) . If you looking for hard to find parts or strange off ETK parts you can always PM me. I usually can find them or a source that has them.
OEM and Value Line OEM parts available here http://new.minimania.com/index.cfm
I don't know what part of the country you're in, but I've always used http://parts.seattlemini.com/ when it had to be an OE part. They're a little bit cheaper than most places but the shipping is usually a lot cheaper.
JPMontes3
Dec 3, 2015 10:05 AM
Drivetrain Coolant flush; radiator upgrade modification
ti22fjc
Nov 30, 2015 03:55 PM
