Xenon headlight—is it the bulb or the ballast?
Old Oct 9, 2015 | 03:09 PM
Aaron Keith Harris's Avatar
Aaron Keith Harris
I have a second-hand '06 R53, and a few days ago, my right/passenger headlight started turning pink, which I assumed meant the bulb was going out.
As of yesterday, the light was totally out, but upon starting the car, it does briefly and weakly flash.
So I bought a headlight at AutoZone, but when I went to install, found that I had the Xenons.
Then I found out how expensive they were.
To make 100 precent sure that it was indeed the bulb ONLY and not the electrical stuff (ballast?), I decided to try take the one out of the driver headlight to try it in the right.
When I got into the driver headlight, I found that it was hooked up entirely differently and didn't want to try disconnecting it. (see photos, silver setup and bulb are from driver side)
So, before I spend $100 on a Xenon bulb, I have these questions:
1) How does one disconnect the bulb from the left headlight setup?
2) Is there another way to verify that the ballast is OK on the right side and that there is nothing wrong other than the bulb?
3) Finally, how much trouble/cost would it be to switch both headlights back to halogens?
Bulb from driver side headlight
The reverse of the bulb setup from other picture
The set up on passenger side after extracting the bulb and replacing it empty
Old Oct 9, 2015 | 05:25 PM
ZippyNH's Avatar
ZippyNH
Xenons turn a pinkish hue when they are starting to burnout ..
So the bulb should be bad.
Old Oct 9, 2015 | 05:27 PM
ZippyNH's Avatar
ZippyNH
The unit the bulb is attached too will be included with the bulb....don't over think stuff...
If you are really parinoid, just switch the bulbs left to right ...
Old Oct 9, 2015 | 08:54 PM
ayypeeemm's Avatar
ayypeeemm
Don't attempt to take the bulb out of that silver unit, its all on piece. You can just disconnect it and swap it with the other side and see what happens. if it doesn't work then its the bulb.
Heres a video from bentley on it (i know the year is different, but its the same bulb)
Old Oct 12, 2015 | 08:12 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Zippy gave some good advice for troubleshooting. 63-21-7-160-806 here is the part number for the bulb and less than $100. For bulbs, I typically recommend replacing in pairs as the other bulb could be on its way out. Some info here for switching to Halogen. Headlights here if needed.
888.280.7799 | 6am - 5pm PST
Old Oct 19, 2015 | 06:09 PM
Aaron Keith Harris
Sure enough, I got new Xenon bulbs, and no luck.
The right one doesn't work, the left one does.
PelicanParts provided some helpful links, am checking those out.
Old Oct 19, 2015 | 06:22 PM
AZdsrt's Avatar
AZdsrt
I wouldn't feel bad about that, you do have an '06 that the bulbs probably didn't have much time left in them..
Old Oct 19, 2015 | 06:26 PM
Aaron Keith Harris
Like I said, it's not the bulbs.
Old Oct 19, 2015 | 06:29 PM
AZdsrt's Avatar
AZdsrt
Ya, I sure got that one backwards
Old Oct 20, 2015 | 08:41 AM
PelicanParts.com
Vendor
Glad they're helpful and let me know if you need anything.
Old Oct 20, 2015 | 02:26 PM
Weird looks like you have D2S on one side and D1S on the other side. Do you have pics of the front headlights ?
Moshu-Clubman
R55 :: Clubman Talk (2008+)
Jul 13, 2016 08:54 AM
skmboardchik4lyf
Feb 28, 2016 11:28 AM
atlantaorange
21
Oct 2, 2015 12:32 PM
BushOner
Sep 19, 2015 06:51 AM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
