F57 :: Convertible Talk (2016+) Cooper and Cooper S convertible (F57) discussions.
F57 Hardwiring a Rove dashcam
Old Aug 27, 2025 | 01:41 PM
gargoyle7642's Avatar
gargoyle7642
Anyone hardwiring a Rove dashcam with the 3 lead kit? I'm installing one in a 2022 F57 and was wondering which fuses others have used for the constant power and the switched power. Thanx in advance!
Old Aug 27, 2025 | 02:45 PM
cooper48's Avatar
cooper48
Check this out:
https://www.ebay.com/itm/15662730061...EaAhh6EALw_wcB
Old Aug 27, 2025 | 03:23 PM
gargoyle7642
Originally Posted by cooper48
I already have the Rove hardwire kit. But thanx.
Old Aug 27, 2025 | 03:30 PM
gargoyle7642
It looks like Fuse 44 & 47 are the only easily accessible fuses with constant power. Anyone one know if they are ok to tap into? I have attached a photo of the fuse diagram below. I have open slots available with constant power. Can I tap into them? If so, would I need 2 fuse in the tap, or just the one that came in the tap?
Old Aug 27, 2025 | 03:44 PM
gargoyle7642
I found fuses F1 - F14 behind a panel on the right side floorboard. I may be better off using one of them for constant power. Any insight would be appreciated!
Old Aug 27, 2025 | 03:45 PM
cooper48's Avatar
cooper48
The product link I sent allows you to tie directly into the rear view mirror power eliminating the need to run wiring to fuse blocks.
Old Aug 27, 2025 | 05:43 PM
straz's Avatar
straz
Here's a photo of the fuseblock on my 2022 F57, with both a dashcam and a blind spot detector professionally installed.
2022 fuseblock with dashcam and blind spot detector
Old Aug 27, 2025 | 05:58 PM
gargoyle7642
Awesome! Thanx!! I ended up using the empty slot above where you're installer tapped into with the yellow wire and the empty slot above the 3 yellow fuses on the right. Everything is working great!
Old Aug 27, 2025 | 06:06 PM
gargoyle7642
Wish I knew about these before I bought my kit and have the car all torn apart!! 😅😅
00zero
Feb 26, 2008 08:26 PM
Snappychip
Oct 4, 2006 08:08 PM
1cleancooper
Jan 26, 2004 06:07 AM
antsmini
May 1, 2003 05:59 AM
