F55/F56 Funny thing discovered installing my Forge Hard Intake
Old Jul 28, 2022 | 03:13 PM
TVPostSound's Avatar
TVPostSound
I decided to install my Forge Hard Intake Pipe today.
First a back story:
I always had an issue with high rpm upshifts, whereas it felt like too much boost was being dumped. You know
that burble between shifts so you dont jerk into the next gear (Auto trans). Mine would fall on its face hitting 2nd gear like the Turbo had
to spool up to regain boost.
Dealer would say thats the way it is.
(BURBLE= The wastegate dumping off boost)
Fast forward to today:
I remove the air filter with the MAF intake pipe, then remove the intake center bolt to the engine, and WTF the intake pipe to
the turbo inlet falls over!!! I looked down and the spring clip was never engaged!! The intake pipe was never seated!!!
Was this a Monday car, Dutch drank too much on the weekend?
So, I go on and install the Forge pipe, along with a new turbo inlet seal. (2 hours start to finish)
ROAD TEST!!!
My upshifts are hitting as hard as I believed it should have been form the beginning, and a shorter (yet louder) burble between shifts, and my idle
has smoothed in Sport.
IMPRESSIONS?
I now cant really answer whether this pipe was worth $300, as I have nothing to compare with due to the OEM pipe never fitted
properly!!
FIY car was built 2/2017 in the Netherlands assembly plant.
You want pics?
Old Jul 28, 2022 | 04:27 PM
RichsMINI's Avatar
RichsMINI
@TVPostSound that’s crazy but at least you caught and resolved it
Yup, I noticed idling in all modes have been smoother. In Sport mode there are more “pops and bangs” from the exhaust too.
Now I really want to install Forge’s intercooler and charge/boost pipes
Enjoy the upgrade and post an update on MPGs. I’m averaging in the mid 30s now.
Rich
Old Jul 28, 2022 | 04:44 PM
TVPostSound
Yeah, 5 years later!!
Mileage? I only do short hops lately, so its hard to judge, but it runs so smoothly now!!!
And... I lost the grey lock to the Blowby heater connector!!! I might remove the under tray, probably will find all the grey locks Ive dropped!!
Did not remove any bits above, but had to remove the OEM snorkel to get the intake body out. Also the front battery wall kept it from coming out. Removed that too.
Old Jul 29, 2022 | 06:54 AM
mruehl's Avatar
mruehl
You guys are really making me want to get the forge intake pipe, but as you said $300 is a hard sell. Are you guys pairing it with OEM intake + K&N or an aftermarket?
Old Jul 29, 2022 | 08:42 AM
TVPostSound
Im only saying I have no comparison due to the OEM not fully seated.
I have no regrets!!
Old Jul 29, 2022 | 11:24 AM
NBCGLX's Avatar
NBCGLX
Strange that you had a leaky intake (post MAF) and you weren’t getting a CEL. But glad you’ve fixed it.
FYI the “farts” on upshift are caused by the engine pulling timing for a momentary and immediate reduction in torque, so the gearshift can happen quickly. This is common in several makes/models now, more pronounced in cars with exciting exhausts, and not related to the turbocharger at all (which actually has a recirculating valve and doesn’t “dump boost” at all).
Old Jul 29, 2022 | 12:00 PM
RichsMINI's Avatar
RichsMINI
Hi @mruehl, I would agree about the price, but I was lucky because I used some points with my credit card to cover the cost.
However, after receiving the product and seeing Forge's incredible build quality I have to say its well worth the money!
- Also having a smoother idle, better airflow (non-restrictive) to the turbo while maintaining mpg was a benefit in my opinion
My MINI still has the OEM intake and panel filter. I have an aFe performance dry panel filter I have to install but Forge does make an induction kit that looks amazing...
Rich
Old Jul 29, 2022 | 12:45 PM
TVPostSound
I worded it wrong.
Yes, I agree with the timing part, but the wastegate does not recirculate, it dumps exhaust past the turbo. being unburnt fuel being ignited on its way out.
Old Jul 29, 2022 | 01:09 PM
TVPostSound
I had rich and lean codes, but attributed it to my JB+
I might have to reinstall the replacement, and see. (Burger sent a new one no questions asked!!)
Old Dec 13, 2022 | 09:47 AM
NBCGLX's Avatar
NBCGLX
Originally Posted by TVPostSound
I worded it wrong.
You're talking about the turbine side, but I was talking about the compressor side. The compressor side uses a recirculating valve to recirculate the intake air, rather than vent it to atmosphere via a traditional blow-off valve or what some may call a dump valve (or, "dumping boost"). [Curiously, BMW/MINI does call this valve a blow-off valve in technical documents, though it functions as I stated and does not vent to atmosphere. Instead, it recirculates the air on the compressor side when the throttle is closed.]
Old Dec 13, 2022 | 12:30 PM
Stu-mon's Avatar
Stu-mon
looks identical to mine ! but I've got an NM Blue Cone Air Cl. element on end of mine.
Old Dec 15, 2022 | 09:01 AM
TVPostSound
I had the NM also. Too loud for this old man!!!
Old Dec 16, 2022 | 04:39 AM
Stu-mon's Avatar
Stu-mon
that ain't nuthin compared to my 3" SS Manaflow exhaust & Forge DP ! turn up my Sirius B.B. King 1/2 way & go !
Old Dec 16, 2022 | 05:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I'm not sure what your experience has been with the 3rd generation cars, but all S and JCW models, with the exception of the GP3, LCI Clubman JCW, and LCI Countryman JCW (the ~300hp engines) do not use a diverter/recirculation/blow-off valve. Boost is solely controlled through the use of the wastegate. The ~300hp JCW engines have an added diverter valve to the intake side of the turbo, but the lower spec S and JCW engines do not have that valve on the intake side.
Old Dec 16, 2022 | 06:20 AM
RichsMINI's Avatar
RichsMINI
I also had the NM Engineering intake on my previous F56 and it was loud. I can’t imagine how loud it is with both the intake and the Forge hard pipe installed
Personally I think the Forge hard pipe with an aftermarket panel filter installed sounds great
Old Dec 16, 2022 | 08:17 AM
TVPostSound
Same combo here.
Also removed the Magnaflow, and installed a full GP3 exhaust.
Now sounds good, but heads dont turn.
JosephM635
Oct 31, 2025 01:07 PM
EmedpaDHSc
F54 :: Clubman Talk (2015+)
May 20, 2023 11:09 AM
theBeardedPagan
Sep 3, 2018 03:15 PM
Sbray
Feb 13, 2015 02:24 PM
madmax88
R60/61 Cooper S Drivetrain
Apr 10, 2014 01:13 PM
