F55/F56 Best sway bar?
Old Jul 27, 2021 | 02:02 PM
Kmead's Avatar
Kmead
Best sway bar?
Hi all,
Considering upgrading rear sway bar on my 2015 F56 daily driver to 22mm solid. Any thoughts/experiences regarding NM vs. M7 Speed? Not sure I’d need three adjustment points… Other recommendations?
Thanks!
Old Jul 27, 2021 | 02:56 PM
cmt52663's Avatar
cmt52663
See sig.
Cheers,
Charlie
Old Jul 27, 2021 | 03:08 PM
Kmead's Avatar
Kmead
Thanks. What does that mean?
Old Jul 27, 2021 | 03:29 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
A sway bar is just a bar. Get the one in the size you want that fits your budget.
Old Jul 27, 2021 | 03:40 PM
MikeMJCW's Avatar
MikeMJCW
RSB = Rear Sway Bar Brand NM Engineering, size 25mm hollow. There's a discussion about this on the suspension thread: 25mm hollow vs 23mm solid, should work the same. As stated above, grab one that fits your budget and post about it. Good Luck.
FYI: I have Eibach F/R.
Old Jul 27, 2021 | 03:50 PM
TVPostSound's Avatar
TVPostSound
Originally Posted by Kmead
Hi all,
Thanks!
Consider
VIP
23mm solid bar
$249 Free shipping
Was my first till Was very impressed until I went bigger front and rear.
https://www.vipcustomparts.com/F56%20parts%20page.htm
Old Jul 27, 2021 | 05:17 PM
cmt52663's Avatar
cmt52663
It means that when I was faced with the same question, I went with the 25mm hollow NM bar.
I have no regrets.
Cheers,
Charlie
Old Jul 28, 2021 | 05:01 AM
Kmead's Avatar
Kmead
Decided to go with NM 22 mm, and upgraded end links. Any thoughts on upgrading clamps?
Old Jul 28, 2021 | 05:04 AM
MikeMJCW's Avatar
MikeMJCW
Where have these guys been Hoping they can fab up a resonator bypass for the JCW pro exhaust
The rear bar looks good at only $249, I think the NM 25 is closer to $500 (probably lighter tho).
Old Jul 29, 2021 | 05:32 AM
Juice84's Avatar
Juice84
I got this one in:
WMW 25MM Rear Sway
I wanted a front and rear set, but they are no longer produced.
Old Jul 29, 2021 | 07:16 AM
TVPostSound
Originally Posted by Juice84
I got this one in:
WMW 25MM Rear Sway
Bought mine here:
https://www.tunershop.com/shop/h-r-s...-mini-f56.html
Old Jul 29, 2021 | 07:35 AM
Juice84's Avatar
Juice84
Originally Posted by TVPostSound
Are you sure the H&R kit is still sold? If you look at H&R website they don't list sway bars for the mini anymore; neither does Eibach. I, personally, thought the H&R bars were too thick and I think I remember reading they had fitment issues (maybe those got corrected) which is why I didn't get those. I did call eibach and tried to see if they had any on a shelf some place and went so far as to ask them who their last multi order was from so I could call them to see if they were in stock. A lot of resellers just haven't updated their websites.
Old Jul 29, 2021 | 08:09 AM
Juice84's Avatar
Juice84
Just called H&R and they disco'd it. No more F&R sway bar kits in the market for our cars.
Old Jul 29, 2021 | 01:35 PM
TVPostSound
You called H&R in the US, which is a distributor, NOT the company.
Ive spoken with him, and not pleased with his responses.
I call BS from him.
H&R US never imported sway bars for the Mini.
They also only carry springs for the F56, but say it works on the F55.
H&R has rear bushing issues, too tight. I ended up getting the NM Engineering bushings for mine.
Email Tuner Shop, they get them in Germany.
https://www.tunershop.com/shop/contacts/
Alexander is the US rep.
Old Jul 30, 2021 | 07:12 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We found going to a 22mm solid wasn't enough of an improvement to be worth it as the stock bar is a 22mm solid on the F56. That is why we made our 25mm and didn't bother producing a 22mm option as the labor and time involved is the same for both, but the improvement and feel is far better with the 25mm. It is what we have used on all our builds in our shop.
https://www.waymotorworks.com/wmw-25...5-f56-f57.html
Old Jul 30, 2021 | 07:20 AM
Juice84's Avatar
Juice84
I call BS from him.
It does appear they are on H&R's German website still. Oh well, I'm not gonna replace them a third time or pay the labor for the front at this point. Thanks for the info!
Old Jul 30, 2021 | 08:38 AM
Kmead's Avatar
Kmead
I thought the stock rear sway bar on the F56 was either 16 or 17 mm…
Old Jul 30, 2021 | 09:39 AM
TVPostSound
Way is partially correct, the stock bar on my F56S is 22mm, but hollow. I just went out to my garage, and verified.
A 22mm solid is a marked improvement for the casual driver.
A 25mm solid is significant, and would not recommend to someone that just wants an improvement. Ot takes some skill to control
during aggressive driving.
It induces too much oversteer, needing a front bar to even out the handling.
Old Jul 30, 2021 | 10:17 AM
Kmead's Avatar
Kmead
do you know what the stock rear bar size is on the Justa F56?
Old Jul 30, 2021 | 07:06 PM
TVPostSound
The rear bar at 23mm was a good gateway drug. By itself it did wonders.
Definitely give them a call, I bet they would be interested. They are custom fabricators.
BackRoads-Mini
Sep 28, 2019 03:46 PM
f56_sierra
Jul 7, 2019 09:22 PM
DAVIDLEERAD
Nov 30, 2017 09:34 PM
ZeroGravity
Nov 13, 2015 05:08 AM
PatM
Jul 28, 2015 08:02 PM
