F55/F56 Drive mode selector can it be switched?
Old Oct 20, 2019 | 09:23 PM
bluonyx's Avatar
bluonyx
So the one thing that bugs me with my JCW is the drive mode selector. When I was test driving the JCW before I ordered it it was around the collar, when I ordered mine, I guess MINI changed them to the far right switch for the 19 model years.
Can the drive mode selector be changed from the far right toggle switch behind the shifter to the collar around the shifter? Has anyone done it yet?
Old Oct 20, 2019 | 11:16 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Probably need to look on realoem.com for part numbers to see how things have changed and what might fit together. Don't recall reading anybody doing this mode.
One of the reasons I don't want to trade up to a newer model is exactly this. I love the collar switch, don't like leaning to reach the on dash switch like I had in the Countryman.
So if the collar switch won't easily mod, you can always just wire up a toggle switch and put it in the console and run the wire from original switch. I have two switches I added on my console for stereo sub woofer control, very handy location.
Old Oct 21, 2019 | 05:52 PM
Scypio's Avatar
Scypio
I don't mind mine. I just flip it to Sport mode when I start the car. I've tried Eco on long highway drives so I switched it while driving and while it's not the most convenient thing, it's not frequent enough that I mind it. And I guess if I know I'll be stuck in traffic, I'll switch it back to Normal (or don't switch it to Sport when I start). So for me, it's not a big deal. But I can see if it used to be more convenient that it's annoying now.
But do people normally change modes often when they drive?
Old Oct 21, 2019 | 06:39 PM
Minnie.the.Moocher
Frequently !!!
With the Dinan Elite tuner, I find that Sport Mode can be extreme in certain circumstances. Also when hitting lots of speed bumps and rough road I go back to mid mode. Down hill runs I'll turn on Sport to modulate the speed, etc. Green mode has rarely been used, I'd only used it with long traffic jams and almost no movement.
Old Oct 21, 2019 | 07:47 PM
bluonyx's Avatar
bluonyx
Yup, every daily commute, 15 minute drive through a canyon (sport), 25 minute drive highway (mid), if there is traffic on the highway (eco), then I'm at work. Then I do it all over again come the evening, I love it!
Does newtis.info have wiring diagrams to look at for the rear of the START STOP CONSOLE SWITCH UNIT to see if I can tap or splice into the selector toggle?
Old Oct 21, 2019 | 08:28 PM
bluonyx's Avatar
bluonyx
I'm getting closer...
EDC Layout/Info
Old Oct 22, 2019 | 06:29 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Code it to stay on Sport all the time and drive a mini like it should be
Old Oct 22, 2019 | 10:43 AM
bluonyx's Avatar
bluonyx
Its coded to Sport on startup but since I put in the Forge IC it constantly feels like it pulling, which is perfect for the canyons but on the freeway I kind of just want it to coast along. Which is why I'm starting to use the drive selector much more now. I'm a little worried how much more the pull will be when I get it properly tuned with the Mario's DP.
Old Oct 22, 2019 | 11:20 AM
Walt's Avatar
Walt
I was casually thinking of doing the reverse. Moving my drive mode selector switch from the collar to the dash.
I guess its always better the other way.
Old Oct 23, 2019 | 12:11 PM
bluonyx's Avatar
bluonyx
Thanks be the internet gods, I found my drive mode selector collar with a wiring harness attached cause I know I'm going to have to do some splicing. Now I just have to wait till it gets here.
Old Oct 25, 2019 | 01:10 PM
wagon4me's Avatar
wagon4me
Drive mode selector
Greetings! I too wanted to change from the collar to a switch. But someone told me that it’s also wired in to the cruise control, so I just left it alone. It’s just not that much of a big deal...just hate the look of the blank plate because there’s no switch.
Old Oct 25, 2019 | 04:36 PM
Walt's Avatar
Walt
That's my mind set too. The empty spot just screams "owner too cheap to have bought the option, for which, a switch would be placed right here".
Old Oct 25, 2019 | 04:38 PM
bluonyx's Avatar
bluonyx
Found some wiring diagrams for us...
Center Control Panel Console
Old Jan 28, 2020 | 03:58 PM
joemysterio's Avatar
joemysterio
This is something I want to do, move from the collar to a switch elsewhere so I can install the CS shiftwell cover. I would be content with moving/extending the cable, moving the control board in the collar elsewhere and securing/adapting a toggle switch to it. Just a matter of figuring out the best type of switch or toggle, and how to secure it.
Old Jan 30, 2020 | 10:28 PM
holyspiritf56's Avatar
holyspiritf56
i find with my JCW pro exhaust with the valve open it’s easier to just switch to mid mode then close the exhaust when driving through town or past cops to attract less attention. So yes I use it quite a bit for that purpose. But eco mode not so much.
On a side note my wife still hasn’t figured out that the exhaust opens and closes, I pray she never does or she will never let me open it!!
Old Apr 21, 2020 | 04:42 PM
shmandrew's Avatar
shmandrew
any developments on this? I'm going to be installing a coolerworx shifter and am looking for a way to relocate the sport mode switch from the collar to some kind of external toggle. In an ideal world, I'd also be able to tie the exhaust valve to the relocated sport mode switch - I saw a guy on IG that had somehow wired up his JCW PRO exhaust valve to the original shifter sport mode ring.
Old Apr 21, 2020 | 06:04 PM
J_L's Avatar
J_L
That sounds interesting- what's IG of the guy that added the JCW valve to the sport ring?
Old Apr 21, 2020 | 06:37 PM
shmandrew's Avatar
shmandrew
View this post on Instagram
Old Apr 22, 2020 | 04:35 AM
sgscomps's Avatar
sgscomps
If you want your car to be in sport mode all the time you can use Bimmercode to make sport mode active on startup, no more moving the ring. If you want your JCW pro exhaust to be in sport all the time you can remove one of the cables from the bluetooth module while the car is running in sport. Somewhere on this forum it tells you which cable to remove. Again no more having to push the button on the controller to activate it.
Old Apr 22, 2020 | 10:11 AM
shmandrew's Avatar
shmandrew
I appreciate the advice, but I am already aware of both of those options and unfortunately that's not what I'm trying to achieve. I want to keep the flexibility of both of those systems. My main focus right now is trying to relocate the sport mode switch. There's a write-up in the How To forum for hard wiring the exhaust valve to a switch that looks promising... tying it to the sport mode selector is an interesting alternative that I'm also exploring.
I'm looking into buying another sport mode ring just to tear it apart and figure out a solution that works for my application. If I find anything interesting, I'll be sure to share with the forum.
Old Oct 12, 2021 | 12:58 AM
ranger052's Avatar
ranger052
Hi,
sorry for reviving this.
were you able to make the retrofit? If so, could you pls share details on the install?
thanks!
Old Oct 12, 2021 | 09:27 PM
bluonyx's Avatar
bluonyx
Nothing new I'm afraid, I gave up on this venture. Has something to do with the coding, because my BCM does not have the hard wire to it that is used on the collar. I did try to add it but then it messed with the HUD. To bad newtis.info isn't free anymore.
Old Oct 18, 2021 | 04:50 PM
ranger052's Avatar
ranger052
AHHHH! :(
I was hoping it could had been done haha.
Thank you!
Old May 17, 2025 | 11:20 AM
N52B40's Avatar
N52B40
Originally Posted by ranger052
AHHHH! :(
Thank you!
Hi guys,
bit late to the game but want you to know I was successful doing this retrofit.
My car is a 2018/12 Countryman Cooper.
Car didn’t have driving experience modes at all, so had to first VO/FA code 4AV.
Afterwards the following parameters were changed individually:
BDC_01 > BfImUX 3004 > SWITCHBOARD_AI_C_ENABLE DTC = nicht aktiv -> aktiv
BDC_01 > BfImux 3004 > SWITCHBOARD_FES MINUS_VARIANT = switchboard_a_s2 -> switchboard_c_s2
BDC_01 > BfImux 3004 > SWITCHBOARD_FES_PLUS_VARIANT = switchboard_a_s3 -> switchboard_c_s3
Wiring the rotating switch to BDC and it does work!
Old Jul 10, 2025 | 07:01 PM
cjv2's Avatar
cjv2
Originally Posted by N52B40
Hi guys,
Nice!
colourblind
Dec 15, 2025 03:06 AM
todoubled
May 16, 2023 07:59 PM
Sigboi
Sep 17, 2016 04:03 PM
Autorepairz
Oct 7, 2011 02:10 PM
1cophere
Jan 19, 2009 12:19 PM
