F55/F56 Rear Fog Lights
Old Jul 5, 2019 | 04:45 PM
TJANK's Avatar
TJANK
Rear Fog Lights
Wow! That was the easiest mod I ever did. Replaced light switch and activated 2019 F55 Rear Fogs lights (bulbs and wiring already there!) Euro Rear fog switch 61 31 9 865 845 (Thank you ECS Tuning!) Panel simply pulled out and switch was held in by fasteners (no screws), clicked new switch in and replaced wire connector. Everything except the rear fogs worked after replacing switch. As I had to code ECU with BimmerCode iphone app ($31) and a bluetooth OBDLinkMX+ adapter.
Recoded and now both rear and front fogs work
I found coding Originally Posted by TVPostSound (thank you!)
Coded: In Expect Mode....in the "Body Control Module" [No idea what that link is?]
Activate Rear Fog Lights:
3068 NSL_Verbaut = Verbaut
(Note nebelschlussleuchte = NSL= Rear Fog Lights)
Code first, the cycle ignition, then restart Bimmercode for the below options
to show up. This was scariest part as it cycles thru with alerts--but afterwards it is all OK).
Activate Rear Fog Lights feature for lighting switch:
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht
Every time you recode after doing rear fogs, you WILL get a dash warning about lighting errors.
cycle the ignition, it will go away, the warning after coding is because the VO has not been coded.
It will not persist after that.
This link was helpful.
file:///C:/Users/toddt/Downloads/BMW...3%20series.pdf
Turned on both left and right fogs
Back of switch
Original switch with dummy rear light switch
Installed euro switch with rear fog button
Old Jul 7, 2019 | 10:49 AM
TVPostSound's Avatar
TVPostSound
If the dealer ever needs to recode your car, make sure you have the original switch with you.
Reinstall the original switch before coding.
Unlike the R56s we don't write a new VO, thus the coding will look for a switch with NO rear fog ability, and fail coding.
It happened to me, dealer called and said mine failed coding, and they ordered a new switch!!
Old Jul 18, 2019 | 07:01 AM
Looks good with the UJ taillight.
Old Aug 6, 2019 | 04:51 PM
TJANK's Avatar
TJANK
This is helpful. Do I need to undo the coding in addition to using the original switch, or just swap the switch back?
Old Aug 6, 2019 | 04:58 PM
TVPostSound
Just swap the switch.
Mall your custom coding will get zeroed out by the dealer coding.
Their coding resets your car to factory VO specs with the updates.
Old Aug 6, 2019 | 10:17 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
You can also use the backup function on Bimmercode to quickly restore your set up. In theory, I've never actually needed to do so but it is documented by Bimmercode how to do it.
Old Aug 7, 2019 | 03:03 PM
vetsvette's Avatar
vetsvette
Moderator
MM. I'm not familiar with a backup function, so I emailed BimmerCode about it.
My question: "Iis it possible to save my coding to simplify recovery after the dealer performs a software update?"
His answer:
t"this is not possible. The backups that are made contain the complete coding data and this may not be compatible anymore after the software has been updated."
Old Aug 7, 2019 | 03:20 PM
Minnie.the.Moocher
Originally Posted by vetsvette
His answer:
Bummer-code !
Old Aug 7, 2019 | 03:41 PM
vetsvette's Avatar
vetsvette
Moderator
I agree completely. But, on a positive note, most of the desired coding changes are included in the shortcut menu now. Lot easier to just toggle the feature on/off rather than get into the weeds with expert mode. The first time I coded mine it seemed to take a long time, but a couple months ago after the dealer surprised me with an unexpected DME software update, it took very little time to add all my changes back.
Old Aug 11, 2019 | 09:58 AM
TVPostSound
If the backups do not works as Stephan (Bimmercode) stated, then that version of Bimmercode will not
work until he updates it.
Thats happened to me.
Old Feb 1, 2020 | 03:47 PM
Mr. Pep'r's Avatar
Mr. Pep'r
Originally Posted by TJANK
Back of switch
TJANK, thanks for posting this information, it's exactly what I was looking for.
Quick question, on the back of the new switch (w/ rear fog light switch), which one of those numbers is the part#?
Alpha Motoring
Feb 8, 2013 06:31 AM
Slyp Dawg
Electrical
Oct 19, 2012 05:41 PM
jgaset
Sep 5, 2009 11:50 AM
javadavaz
Mar 14, 2004 06:19 PM
EliteCooperS
Feb 17, 2003 09:55 AM
