F55/F56 How do you adjust the headlights ?
Old Oct 19, 2016 | 09:36 AM
umberto's Avatar
umberto
I have a 2016 F55 and notice that the right headlight is aimed a little lower than the left ......where is the adjustment to adjust the headlight vertically?
The owners manual was no help ........
Old Oct 19, 2016 | 10:14 AM
TheBigNewt's Avatar
TheBigNewt
I think one is supposed to be aimed a little lower but I forget which one.
Old Oct 19, 2016 | 06:01 PM
dube53's Avatar
dube53
Go to your dealer. Don't mess up, you are under warranty.
Old Oct 26, 2016 | 03:52 AM
umberto's Avatar
umberto
no assistance as to how to aim the headlights? The are two white plastic screws that I am assuming are the adjustment screws but not sure which is vertical and which is horiz .....i don't want to mess around though until i know that these are the adjustment screws
Old Oct 26, 2016 | 04:28 PM
sootyvrs's Avatar
sootyvrs
I have the LED lights and I used the inner white allen key tumble wheel to adjust vertical beam.
Clockwise for down and opposite for up
Old Oct 26, 2016 | 06:16 PM
PooLeArMor's Avatar
PooLeArMor
driver side headlight is always lower than the pass side headlight
Old Oct 26, 2016 | 06:45 PM
umberto's Avatar
umberto
in my car the passenger side is lower ..... i just installed the Phillips Extreme H4s ( from Daniel Stern Lighting) and they are very bright and white focusing on the pavement so i am thinking if i raised each up a little, and the passenger side a little more then the beams would go a little further
Old Oct 31, 2016 | 09:28 PM
WhatV8's Avatar
WhatV8
Check Daniel's site for proper aiming guidelines and/or ask Daniel directly, he is usually pretty prompt on responses to questions. I have used his products/advice on several cars over the years, good guy!
I would have to agree that the driver's headlight is normally lower than the passenger unit, so something got shifted or improperly aimed on the production line. Make sure your bulbs are properly seated in the housings, since a small shift in the bulb's filament in relation to the reflector can really throw the light pattern off.
Old Nov 1, 2016 | 06:01 PM
umberto's Avatar
umberto
whatv8 ...saw your post last night and thought worth a shot ...so this morning took out the bulb and re-seated it ....nope .....same thing....so think i will play and adjust it up a wee bit
Old Nov 2, 2016 | 09:14 PM
WhatV8's Avatar
WhatV8
Worth a try, eh? DS Lighting does have a good write-up on how to properly aim your headlights, if you want to delve into things more than just raising up the one unit:
http://www.danielsternlighting.com/tech/aim/aim.html
Good luck.
Old Nov 17, 2016 | 09:21 AM
TX1911fan's Avatar
TX1911fan
Got my F56 back from the body shop after a fender bender and my headlights seem too low now. Might have to look to see if I can raise them just a bit.
Old Jun 4, 2020 | 12:17 AM
Imperial's Avatar
Imperial
Guys, anyone can take a picture of low beams against the wall? Just want to see how even the lights are or a bit off? The passenger headlight on my US spec F55 MCS is a bit lower than left side. Dealer replaced right upper engine mount recently. So the right side seems a bit lower than it used to be(although it was't at the same height as left side to begin with but was better)
Here is how the headlights are at the moment. Does it look on par with other cars?
docpat99
R60/R61 Stock Problems/Issues
Aug 16, 2014 07:31 PM
Mindspin311
Aug 9, 2011 12:52 PM
Steve T
Jan 15, 2010 04:52 PM
Vento9
Mar 9, 2009 07:34 AM
