F55/F56 Cigarette lighter fuse
Old Jun 19, 2016 | 07:37 AM
spyked's Avatar
spyked
My cigarette lighter socket is dead. I plugged something into it, with the car OFF, and it sort of sparked and now it's dead. Happened once in another car I had too. I tripped a fuse in that case.
When I search on here in the F56 forum, I don't see anything about fuse types or numbers. The owners manual says to unscrew the glovebox, but then someone here says that is incorrect?
Anyone have experience with this? Can I just go to auto store and buy a fuse, or is it off to the local dealer for a 2 day ordeal?
Thanks!
Old Jun 19, 2016 | 09:00 AM
bheights's Avatar
bheights
It should be fuse 65 with a 20A standard sized fuse. There is a folded sheet of paper with the location of the fuses tucked in the middle of the fuse panel (along with the fuse puller).
See https://www.northamericanmotoring.co...-fuse-box.html
I didn't take out the glove box or disconnect the panel but it's a very tight space.
Old Jun 19, 2016 | 10:09 AM
spyked's Avatar
spyked
I'll give those instructions a shot. Thanks!
Whats weird is the USB power an inch below the 12v socket works fine. Must be on separate fuses, or I really fried something.
Old Jun 19, 2016 | 10:27 AM
bheights's Avatar
bheights
YW. USB is powered by the head unit rather than direct.
Old Jun 19, 2016 | 11:06 AM
spyked's Avatar
spyked
Good to know (about the USB), thanks.
I'm gonna have to take it to dealer. Moved passenger seat all the way back, got under the glovebox, and see some fuses, but don't see the tab/clip to press to get all of them to fall out/down. I'm thinking it's more confusing too since it's a LHD car installed in a place where RHD is the norm. And you're upside down when looking at it. I'd most like have an airbag pop in my face if I tried to force it down.
No YouTube vids out there either. This platform still too new I guess for all the serious modders out there (in terms of electrics anyway).
Old Jun 19, 2016 | 11:26 AM
bheights's Avatar
bheights
This might help to locate things.
Old Jun 19, 2016 | 11:46 AM
spyked's Avatar
spyked
Thanks for the diagram! Turns out my local auto parts store doesn't know what fuse to sell me because there are multiple types of 20 amp fuses. Like styles of them I guess. ATx or ATy or ATz. Owners manual doesn't say.
They don't have single fuses either. Like $25 for bulk amounts.
Old Jun 19, 2016 | 02:35 PM
spyked's Avatar
spyked
FIXED! My shoulder blades and neck officially hate MINI designers (fuse box way under there, really?), but I replaced the fuse (yellow 20 ATM) and the socket works now. Won't ever plug in anything there I have a feeling.
Thanks again bheights!
Old Jun 19, 2016 | 02:47 PM
bheights's Avatar
bheights
Good to hear!
Old Jun 19, 2016 | 03:49 PM
ZippyNH's Avatar
ZippyNH
¢14-28 each depending on style on rockauto.com.....
I might suggest keeping an "assorted" kit in the garage or glove box for a couple $.
Anyplace selling you $25 for a "big box" of fuses must be several hundred I would hope....
Old Jun 19, 2016 | 04:04 PM
ZippyNH's Avatar
ZippyNH
One tip...if you know which one you are pulling...a pair of needle nosed pliers is the simplest way to yank them....the plastic puller is kinda emergency use only...just don't squeeze too hard!!
Old Jun 19, 2016 | 04:55 PM
spyked's Avatar
spyked
Thanks for the advice. I had my needle nose handy but ended up using the red puller. It was fairly easy because the 65 fuse has 66 on one side, but no 64 on the other. So you have room to grab it. The old one (old...car build date of April 13, 2016, ha!) was melted real good. Won't be plugging that item in the lighter socket ever again, that's for sure.
drpep
Mar 21, 2020 06:16 AM
cdninsw
Jun 3, 2016 11:10 AM
penguinhomey
Apr 9, 2016 04:32 PM
AlphaQuad
Mar 29, 2016 07:07 PM
AFN704
Mar 23, 2016 10:58 PM
