F55/F56 Check engine light
Old Mar 4, 2015 | 03:11 AM
honderpilot's Avatar
honderpilot
Check engine light
I woke up this morning and got to work late and noticed my check engine light was on. The car drove fine and there were no other warning messages other than this light. I'm low on gas and that's the only thing I'm thinking could be it. Will check again after work. This is the first "mini" issue with the car in 7k miles. Thoughts?
Old Mar 4, 2015 | 03:23 AM
brando087's Avatar
brando087
You can go into your vehicle status screen and see why the light is on.
Old Mar 4, 2015 | 03:25 AM
honderpilot
I meant to add that, I did under check control and it read "all systems ok". I will check the gas cap but I've been driving it around for about a week since last getting gas.
Old Mar 4, 2015 | 07:39 AM
honderpilot
Dealer said it was the programming update. I didn't know that would throw a CEL? Oh well...
Old Mar 4, 2015 | 08:17 AM
Helix13mini's Avatar
Helix13mini
My guess is that the programming update was to fix a diagnostic trouble code which illuminated your CEL, and not the cause of the CEL. Either way, you're fixed now.
Old Mar 4, 2015 | 09:28 AM
TheBigNewt's Avatar
TheBigNewt
Battery pull!
Old Mar 4, 2015 | 04:14 PM
honderpilot
What is the programming exactly? Like what does it do differently?
Old Mar 5, 2015 | 07:54 AM
Helix13mini
^Dunno^. I should have said software update. Without going too deep into it, your car's engine control computer has the capability to adapt to its environment, making slight changes based upon fuel quality, atmospheric conditions, even how clogged your air filter is. If the adaptation for any one of these parameters goes beyond a pre-set threshold, it can set a check engine light. It may be that the dealer did a software update to re-set one of those thresholds. Just a guess.
Old Mar 5, 2015 | 01:06 PM
honderpilot
Thanks!
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
