F55/F56 Mini coding/programming
Old Dec 9, 2014 | 05:41 PM
  #101
fatherfork's Avatar
fatherfork
Originally Posted by DarkBlue15MCS
A lot of these codes I got from other BMW cheat sheets
Most of those don't match the F56 cheat sheet. I wonder what the differences in the codes are. So far the two things I've coded have matched the cheat sheet, but I haven't looked to see if what you just posted matches any codes I have. I will say this, my seatbelt chime codes were in 3001, not 3000. These discrepancies are quite strange.
Old Dec 9, 2014 | 05:46 PM
  #102
fatherfork's Avatar
fatherfork
Changed max startup volume for radio to 50%
HU_NBT
3002>VOL_MAX_ON> werte value =32
What would be the werte value for 75%?
Old Dec 9, 2014 | 06:06 PM
  #103
DarkBlue15MCS's Avatar
DarkBlue15MCS
Yeah I found them in different sections as well. That's why I said some sections may be wrong and to search for the function if it's not in the listed section.
The value is in Hex 75%=4b
Old Dec 9, 2014 | 06:22 PM
  #104
brando087's Avatar
brando087
Anyone know how to get it to start in sports mode? I never use anything else. I was also looking to see if there was a way to turn on the ability to use sat radio.
Old Dec 9, 2014 | 07:59 PM
  #105
DarkBlue15MCS
I edited post #99 to the sections and functions that I have my car coded at. I should have done that at first instead of pulling info off the cheat sheets.
***** indicates changed sections/functions
Old Dec 9, 2014 | 08:26 PM
  #106
r33's Avatar
r33
Nope. Been looking on that in the BMW, no way code that.
Old Dec 9, 2014 | 10:09 PM
  #107
r33's Avatar
r33
@MarcoPolo, did some coding today, I tested 6NE and the voice command button still doesn't work. It actually removed the phone menu from the head unit.
Also, I did disabled the front yellow reflector light.
I forgot the details, but it is in the BCD_BODY module.
I uses the search function to code.
So, I could careless where each function at which section of the modules. It will bring me to it directly if I typed up the whole function names.
In this case, I typed up sidemarker. There is 1 function for the Left side and 1 function for the Right side.
I hope it helps.
Old Dec 10, 2014 | 06:06 AM
  #108
MarcoPolo's Avatar
MarcoPolo
I hope it helps.
couple things
- yes, 6NE makes things worse so i reverted back. i am going to add 6NS which add voice control specifically.
- the flashing emergency lights was put into use yesterday and i got a "lighting system malfunction" alert. the alert went away but it could have detected the system forcing the flash and another sensor went off?
- i'll try a few more when i have the time but i'm starting to see that someone just copied the f56 docx file from somewhere else w/out really testing. the group of us will have to put together a new document...a better one.
Old Dec 10, 2014 | 06:13 AM
  #109
DarkBlue15MCS
It was me that posted the codes yesterday. I went back and changed the codes that were incorrect. Everything that is in post #99 is accurate as that is how my car is coded.
And yes when you stop hard the Kombi will let you know the lighting system activated.
Old Dec 10, 2014 | 06:50 AM
  #110
brando087's Avatar
brando087
I've changed quite a bit. I'll try to put a list together to let you guys know what worked for me. Has anyone messed with the Active Sound Configuration menu? I got the settings to come up, but couldn't select anything. Anyone have any luck? It appears you can change the sound of your car.
Old Dec 10, 2014 | 06:59 AM
  #111
DarkBlue15MCS
I disabled my ASD
Old Dec 10, 2014 | 07:02 AM
  #112
fatherfork's Avatar
fatherfork
I disabled my ASD
Is active sound design always active or just in sport mode?
If it's always active and just made louder in sport mode, does disabling it disable it completely, even in sport mode?
Old Dec 10, 2014 | 07:14 AM
  #113
CooperB's Avatar
CooperB
How does it sound with ASD disabled? Noticeable difference?
Old Dec 10, 2014 | 07:19 AM
  #114
DarkBlue15MCS
I honestly can't tell much difference. I just don't like the idea of fake engine noise over my radio.
Old Dec 10, 2014 | 07:52 AM
  #115
CooperB's Avatar
CooperB
Until we can come up with a WIKI page or something I have put together a list of verified working codes for the F56. This list can be updated as the group finds additional verified working codes. I don't want to just throw a code on this list as verified until it's truly tested and functional. Drop an email to f56codelist@gmail.com and you'll get an auto-response.
Old Dec 10, 2014 | 08:24 AM
  #116
fatherfork's Avatar
fatherfork
...The value is in Hex 75%=4b
Well crap, I don't even have the HU_NBT section because I have the base head unit. I wonder if the startup volume code is in another place on the base head unit or if it exists at all. I'll have to do some digging.
Old Dec 10, 2014 | 08:28 AM
  #117
DarkBlue15MCS
Everything I posted is verified and working
Old Dec 10, 2014 | 09:19 AM
  #118
CooperB's Avatar
CooperB
Nice. I'll add it all in.
Old Dec 10, 2014 | 11:13 AM
  #119
CooperB's Avatar
CooperB
Updated the list. The only codes I am unable to test is the video on navigation screen while in motion as I don't have navigation and mirror unfold at set vehicle speed as my current coding for unfold with the keyfob press of unlock does this for me. All others are working as described. Thanks to everyone who has contributed thus far.
Old Dec 10, 2014 | 12:20 PM
  #120
brando087's Avatar
brando087
I can verify the video on nav while in motion works.
Old Dec 10, 2014 | 01:13 PM
  #121
handn's Avatar
handn
Things I have coded:
Changed emergency braking lights to flashing lights
I think that's all I have coded
When I set ESS_AKTIVIERBARER_AUSGANG to "bremslicht blinkend" it does indeed pulse the brake lights during heavy braking, but then I get a "lighting system malfunction" warning. This doesn't happen when I switch it back to the default of "flachenvergroesserung".
Anyone else having this issue?
Old Dec 10, 2014 | 02:28 PM
  #122
DarkBlue15MCS
I get the same message on my Nav Screen. On the Kombi screen(above steering wheel) I get a message that says "Lighting System: Stop Carefully"
The malfunction message goes away after a few seconds.
Old Dec 10, 2014 | 03:24 PM
  #123
r33's Avatar
r33
That could mean that you don't have the hardware for that feature.
Old Dec 10, 2014 | 04:08 PM
  #124
DarkBlue15MCS
It's working it just splashes a lighting malfunction message for a second.
I'll check around and see if I can find any info
Old Dec 10, 2014 | 11:37 PM
  #125
MiniSquirty's Avatar
MiniSquirty
Stupid question, do you need to have purchased navigation to be able to play video? I've got mini connected but no navigation. Never tried playing a video.
