F55/F56 Mini coding/programming
Old Dec 4, 2014 | 10:39 AM
  #76
brando087's Avatar
brando087
What's the difference between the lite and regular versions?
Old Dec 4, 2014 | 11:57 AM
  #77
DarkBlue15MCS's Avatar
DarkBlue15MCS
Not sure, I just know you can do all basic coding with the lite versions
Old Dec 4, 2014 | 11:59 AM
  #78
hp79's Avatar
hp79
From what I read, the 20+ GB version is for complete ECU flashing which could lead to bricking. For most of us, for tweaking little things, the Lite version is good enough and that's what we should be using.
Old Dec 4, 2014 | 12:12 PM
  #79
brando087's Avatar
brando087
ok, that makes sense. does it matter what cable i get as long as it is obd II to ethernet?
Old Dec 4, 2014 | 12:18 PM
  #80
CooperB's Avatar
CooperB
^^^ what HP79 and DarkBlueMCS said.
Lite is all you need for FDL coding. The stuff most of us are doing/wanting. They are just tweaks to make certain features do things other than MINI/BMW thought we should have.
Mess up the ECU via FA/VO coding/flash and you're going to be getting it towed to the dealer for a factory re-flash most likely.
brando087 - I will PM you a good source for the cable.
Old Dec 4, 2014 | 01:00 PM
  #81
DarkBlue15MCS
Somebody in this thread bought an OBDII to Ethernet connector, Hopefully it works for him as it was only $5. I paid $20 for mine.
Old Dec 4, 2014 | 07:50 PM
  #82
r33's Avatar
r33
Here is the clear explanation, I have been coding BMW for few years already.
The lite version doesn't come with the parts that needed to update the firmware of the car.
For now you don't need it since F55/F56 is still new. While on BMW, for experienced user, they can be used to update the firmware without the need to go to a dealer.
As far VO code, it will not brick your ECU. If you don't have the hardware, it just won't work.
I played with the F56 a little bit, but I forget to create the cheatsheet.
Old Dec 5, 2014 | 09:18 AM
  #83
brando087's Avatar
brando087
Awesome. Thanks guys. You cleared up most of my confusion. Ordered my cable this morning. Hopefully I'll be tinkering by middle of next week.
Old Dec 5, 2014 | 09:58 AM
  #84
SemperMini's Avatar
SemperMini
My mini hadn't been delivered yet, but I am pretty excited to start tinkering when it does show up. Any chance you would upload a video of the setup and process when you start your tinkering? Would love to see the process instead of just reading about it (visual learner here).
Old Dec 5, 2014 | 02:41 PM
  #85
brando087's Avatar
brando087
I'll see what I can do.
Old Dec 6, 2014 | 08:47 AM
  #86
MarcoPolo's Avatar
MarcoPolo
Found a mistake in the .docx file.
The correct lines to "enable tails with DRLS" is as follows:
MAPPING_TAGFAHRL_1_H_L_OUTPUT= sl_l
MAPPING_TAGFAHRL_1_H_R_OUTPUT=sl_r
Old Dec 6, 2014 | 11:15 AM
  #87
allhailpoptart's Avatar
allhailpoptart
For anyone else having issues getting mirrors to fold in and windows to close with the key fob this:
3056 → KOMFORTSCHLIESSUNG_FB = aktiv 00 (Comfort Access ONLY)
Is NOT just for comfort access. My mirrors will not fold using the keyfob unless this is set and I do not have the $250 comfort access package (which AFAIK only allows auto unlocking when approaching the car from outside). Mirrors unfold immediately when unlocking the car.
You can also change this value:
3056 → KOMFORT_SCHLIESSEN → WERTE = 00 (Mirror Fold Delay = 0 sec delay)
to something else if you don't want the mirrors to fold immediately on lock. Using the '00' setting means 0ms delay so as soon as you press LOCK on the keyfob your mirrors fold in. You can use '0D' to set a 100ms delay which means you have to hold the lock button for a split second before the mirrors fold and windows go up.
Old Dec 8, 2014 | 03:51 PM
  #88
MiniLynsk's Avatar
MiniLynsk
Time to start coding!
Attached Thumbnails Mini coding/programming-image-3537851109.jpg
Old Dec 8, 2014 | 07:29 PM
  #89
brando087's Avatar
brando087
I've already changed a few options. Once you mess with the software a little, it becomes very easy to figure out. I had an issue with the clutch bypass and had to revert to using the clutch to start. Not sure why it wouldn't work.
Old Dec 8, 2014 | 07:39 PM
  #90
tripleTurbo's Avatar
tripleTurbo
Does anyone know if you can program low beam to stay on with high beam? This would fix my Halogens at night.
Old Dec 8, 2014 | 07:42 PM
  #91
SemperMini's Avatar
SemperMini
what benefit would you get from the clutch bypass? Just curious on the rationale. I am so used to pressing the clutch to start I don't even think about it (I often find myself pressing the air on automatics if I drive it short term) so I don't really see the benefit unless you are later going to add a remote start function?
Old Dec 8, 2014 | 07:49 PM
  #92
brando087's Avatar
brando087
I'd like to get a remote start so I'm just tinkering to see what options I have to work with.
Old Dec 9, 2014 | 05:07 AM
  #93
MarcoPolo's Avatar
MarcoPolo
It'd be great if everyone commented on what they got to succeed so others can be made aware. This should help in people wasting time on a code that so far has been unproven to work.
My list:
Windows/sunroof closed with keyfob
Door handle lights on when backing up
Tails w/drls
Old Dec 9, 2014 | 07:05 AM
  #94
CooperB's Avatar
CooperB
I am almost positive you can. I just don't recall the line in BDC where this can be done. I'll look next time I connect E-Sys to the car. I still need to dump all the code so I can reference it quicker.
Agree, 100%. I'm thinking about starting a WIKI with updated coding info that is verified functional as many items in the DOCX file/guide are not correct. It's a good starting point but the actual code is not always correct. Hopefully I will have some time later this week to start the WIKI.
Old Dec 9, 2014 | 11:37 AM
  #95
SemperMini's Avatar
SemperMini
Cooper B ^ The real MVP
Old Dec 9, 2014 | 02:26 PM
  #96
DarkBlue15MCS
Things I have coded:
Allow video on nav screen while vehicle is in motion
Removed iDrive startup disclaimer
Disable sound seat belt disconnect driver and passenger
Disabled Active Sound Design
Play ringtone from phone
Tire Pressure AND temp
Changed max startup volume for radio to 50%
With auto lock enabled, all doors unlock with ignition shutoff
Front windows roll up with door open
Close windows/sunroof/fold mirrors with key fob AND comfort access button
Turn off radio/nav when door opens
Change blinker blink rate to 4 flashes instead of 3
Changed emergency braking lights to flashing lights
Fog lights on with parking and high beams
I think that's all I have coded
Old Dec 9, 2014 | 04:19 PM
  #97
fatherfork's Avatar
fatherfork
Originally Posted by DarkBlue15MCS
Things I have coded:...
Could you post the related codes? I don't see all of those I the cheat sheet.
Old Dec 9, 2014 | 04:26 PM
  #98
tripleTurbo
Thank you CooperB! I may just have to get this special cable.
Old Dec 9, 2014 | 05:22 PM
  #99
DarkBlue15MCS
HU_NBT
3000  SPEEDLOCK_X_KMH_MAX werte = FF
3000  SPEEDLOCK_X_KMH_MIN werte = FF
3000  VIDEO_HANDBRAKE set to: nicht_aktiv
3000  VIDEO_FRONT_LOCKED set to: nicht_aktiv
3000  VIDEO_SPEEDLOCK_CONDITION set to: none
HU_NBT
3001>LEGAL_DISCLAIMER_TIME = kein_ld
Disable sound seat belt disconnect driver and passenger******
ACSM
3001>SBR_PreWarning_Fahrer >nicht_aktiv
3001>SBR_PreWarning_Beifahrer > nicht_aktiv
ASD Module:
Disable Active Sound Design
3000>Funktionen-Baureihe(Model Range) > set to: F021
HU_NBT Module
3000>ASD_SOUND_OFF>set to: aktiv
HU_NBT
Set cell phone ringer as primary
3003>INBAND_RINGING>set to: aktiv – werte=01
HU_NBT
Display Tire Pressure & Temperaure in Vehicle Info:
3001>RDC_SAFETY = aktiv 01
HU_NBT
3002>VOL_MAX_ON> werte value =32
With auto lock enabled, all doors unlock with ignition shutoff ******
BDC
3040>VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK> aktiv
Front windows roll up with door open******
BDC
3050>FH_TUERAUF_STOP_MAUT>nicht_aktiv
BDC
3056>KOMFORTSCHLIESSUNG_FB>aktiv 00 (Comfort Access ONLY)
3056>KOMFORT_SCHLIESSEN>WERTE = 00 (Mirror Fold Delay = 0 sec delay)
3110>ASP_BEIKLAPPEN = aktiv (werte=01)
3110>ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = (werte=01)
3110>ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN=(werte= 01)
Change Mirror Un-Fold Automatically at XX Speed (Binary value in Werte):
3110>ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN >werte=14 (12Mph)
Turn off radio/nav when door opens*****
BDC
3020>TCm_LOGIC_R_OFF_DOOR>aktiv
Change blinker blink rate to 4 flashes instead of 3 (value is xx+1) *****
BDC
3068>BLINKZYKLEN_ANZAHL_TIPP> werte=3
Fog lights on with parking and high beams******
BDC
3068>NSW_EIN_AUF_LDS_STL>aktiv (on with parking lights)
3068>NSW_AUS_BEI_FL>nicht_aktiv
Some of the section numbers may be wrong; put the function in the search field on E-Sys to help locate it
Old Dec 9, 2014 | 05:24 PM
  #100
DarkBlue15MCS
A lot of these codes I got from other BMW cheat sheets
