F55/F56 Mini coding/programming
Old Feb 1, 2016 | 10:31 AM
  #551
GregoryK's Avatar
GregoryK
I drive a standard. It has a feature that stops the engine stalling. It causes the engine to rev up on its own while engaging the clutch.
Anyone seen a software switch to defeat this.....It is my#1 complaint. I find it really annoying.
Old Feb 1, 2016 | 12:33 PM
  #552
CooperB's Avatar
CooperB
Are you referring to the "rev-match" feature? I don't notice it on my 6 speed unless I am downshifting.
Old Feb 1, 2016 | 02:19 PM
  #553
GregoryK's Avatar
GregoryK
No. There is an anti-stall feature. try stalling the car in 1st gear and it will restart. If you let the clutch out with out giving the car gas and the revs drop to say 500 rpm the engine will rev-up as it thinks it is going to stall. Very annoying....IMHO.
Old Feb 1, 2016 | 02:54 PM
  #554
siriuszero's Avatar
siriuszero
Rev-matching? You can turn it off by disabling DSC. Not sure if there's a way to code out in ESYS.
Old Feb 1, 2016 | 03:04 PM
  #555
GregoryK's Avatar
GregoryK
What I'm talking about is not rev-matching. The car restarts itself when it is stalled.
Old Feb 2, 2016 | 05:38 AM
  #556
vetsvette's Avatar
vetsvette
Moderator
Can't understand why anyone would want the car to re-start after a stall!
I don't have a problem with that. It's only happened a couple time since I got the car last September, and those times were because I wasn't paying attention to what I was doing.
Old Feb 2, 2016 | 06:31 AM
  #557
GregoryK's Avatar
GregoryK
I don't care about the restarting so much as the way the throttle is opened when the revs drop. Try letting the clutch out without using much gas. The car surges. This also happened with my 2014 MCS. I just want to switch this function of and allow the care to stall without the revs climbing when it is close to a stall.
Old Feb 2, 2016 | 07:25 AM
  #558
CooperB's Avatar
CooperB
I've never noticed this on my 2014 MCS. I'll have to check it out again. I recall stalling it once and it did not re-start or rev-up to compensate for the impending stall condition, I restarted the car myself.
Old Feb 4, 2016 | 05:27 PM
  #559
siriuszero's Avatar
siriuszero
Gotcha
Old Feb 5, 2016 | 08:14 AM
  #560
CooperB's Avatar
CooperB
Just verified, mine will not "rev-up" on a pending stall and will not restart by itself. I stalled it on purpose twice. I was in sport mode if that matters (I always drive in sport, habit now when I start the car, switch to sport)
Old Feb 5, 2016 | 12:14 PM
  #561
Ryephile's Avatar
Ryephile
It's not nearly as annoying as the differential torque request for the rest of the pedal mapping between gears. Though it appears the latest firmware revision I just got minimizes that delta.
In your case, you're going to have to tip in a little bit, just like you'd have to on a cable throttle car. If you're drooping the revs enough to activate the anti-stall then it seems clear you're not applying enough accel pedal.
Or are you intentionally trying to stall the car and have it not help? I guess I'm not seeing the problem here other than you trying to do something that wouldn't work on another car anyway.
Old Feb 5, 2016 | 11:13 PM
  #562
vetsvette's Avatar
vetsvette
Moderator
Tried it on mine today too. Stalled on purpose. No revving to prevent stall. Everything normal. What is nice is all you do to restart it is depress the clutch pedal. That's a nice feature.
Old Feb 28, 2016 | 01:40 PM
  #563
thays_91's Avatar
thays_91
has anyone else had this error? I followed directions, or so I thought. . . I went through them twice and got this error.
Old Feb 28, 2016 | 03:40 PM
  #564
MarcoPolo's Avatar
MarcoPolo
when is this happening? during the install process? upon loading up? after you select F56?
Old Feb 29, 2016 | 10:37 AM
  #565
ad78's Avatar
ad78
Out of range.. Looks like your Ethernet won't detect anything from your car. Is your car ignition turned ON?
Old May 26, 2016 | 02:32 PM
  #566
pjo1966's Avatar
pjo1966
Has anyone tried coding using Carista and an Android tablet? The dealer had to reset the system when I went in for service. I paid $60 last year for someone else to do it for me. I could spend the same amount and do it myself.
Old May 26, 2016 | 09:15 PM
  #567
hammerhands's Avatar
hammerhands
"NOT supported: F55, F56"
http://www.caristaapp.com/supported-vehicles/
Old May 26, 2016 | 09:44 PM
  #568
pjo1966's Avatar
pjo1966
Originally Posted by hammerhands
Well, crap.
Are there any Android solutions that do work?
Old May 27, 2016 | 03:16 AM
  #569
hammerhands
I read about one for iOS that could do some minor coding, BMWhat.
It looks like it doesn't do F series cars either.
Old May 27, 2016 | 07:09 AM
  #570
vetsvette's Avatar
vetsvette
Moderator
These guys say they're planning to release the F5x version in the 3rd quarter.
http://www.mycarly.com/home-wip/?utm..._campaign=home
Old May 27, 2016 | 07:34 AM
  #571
pjo1966's Avatar
pjo1966
Thanks. I subscribed to their Android/BMW emails. 3rd quarter's not too far away.
Old Jun 5, 2016 | 08:37 AM
  #572
raceing86's Avatar
raceing86
Has anyone tried to code for Variable Light Distribution(VLD) on an F56? I've seen on a couple threads people talking about it, but never read anything about anyone trying it before.
On my F30 335i I removed 5AP (decoder for no-dazzle high beams) and 8S4 (decoder for VLD) from the FA to get the functions of these. I've noticed on my F56 Cooper S that it still has the decoder for VLD (8S4).
Has anyone tried removing this and then VO code the FEM_BODY and KAFAS2?
I know there is relatively little harm in doing this since you aren't writing the FA back to the car, but I'd not like to be the guinea pig on this either... haha
Old Jun 5, 2016 | 08:44 AM
  #573
GregoryK's Avatar
GregoryK
It can't do any harm. I'd try it and if you are not happy then just put it back the way it was. That's the great thing about coding.
Old Jun 5, 2016 | 09:50 AM
  #574
Gambedegallina's Avatar
Gambedegallina
Coding to enable "Siri" voice control with base HK radio?
Sorry if I missed the "ultimate conclusion " on this question when I scanned this great thread.
Have a 2016 F56 with HK radio, base Bluetooth, no Nav, etc. Like others, I am cheesed that BMW chose to eliminate use of Siri and similar voice phone controls in this model.
I have seen the discussion of activating Bluetooth music streaming with this configuration but unsure if I saw the answer to whether coding can enable the phone voice control such as Siri. Thanks!
Note, if it's codeable, I will be having a serious discussion with Mini and the dealer.
Old Jun 5, 2016 | 10:19 AM
  #575
hp79's Avatar
hp79
Not possible.
By saying you have the base Bluetooth (but with HK speakers?), do you mean you have the base infotainment system? I have the base and there's no way to code Bluetooth streaming. I think the base infotainment system doesn't even have the menu to select Bluetooth audio and that's why even if you are able to add the VO and code it as if you do have it, it won't work. But that's just my thought. To play music, I just keep a 64GB Sandisk Fit USB 2.0 version plugged in. (The Sandisk USB 3.0 version heats up a lot, at least 5 times more than the USB 2.0 version)
Yeah, it sucks that Bluetooth stream is not standard. It's on every new car these days and our F56 already has the hardware but MINI decided we need to cough up more money to get that.
