F55/F56 Things You Didn't Know Your F56 could do:
Old May 6, 2014 | 10:22 AM
Nochaz01's Avatar
Nochaz01
I figured there should be a spot here for this as well since there are a lot of new items in the next generation model. I will start it off with the sunroof: You no longer have to hold the toggle to open, tap it 3 times to open all the way and 3 times to close it all the way. Any variation in between leaves it partially opened or closed.
Old May 6, 2014 | 04:29 PM
Mrdi's Avatar
Mrdi
Turn the steering wheel to restart the engine when the
Stop/Start option is active.
Old May 6, 2014 | 05:48 PM
dwdyer's Avatar
dwdyer
Not sure what option it goes with but if you flip the switch to the driver side side-mirror adjustment, when you put it in reverse the passenger mirror adjusts to point to the ground. Don't like it? Put the switch to the passenger side.
Old May 6, 2014 | 06:46 PM
MarcoPolo's Avatar
MarcoPolo
That's what makes it go down!! I've had it on the passenger side so I don't accidentally bring down the driver side.
Thanks!
Old May 6, 2014 | 07:20 PM
ojedam64's Avatar
ojedam64
I was wondering about that too!
Here's a question...I parked my mini tonight in a way that I was looking at it from behind, I noticed that the led ring kept throbbing red at the top, then eventually stopped but the hazard button and headlight control switch and start stop button remained illuminated, then they all went out but the start stop. Then eventually the start stop went out too.
Is this the normal shutdown sequence? Anyone else notice this?
Old May 6, 2014 | 09:34 PM
AWDBat's Avatar
AWDBat
I believe some of this lighting can be configured in the Lighting options (heartbeat lighting for the LED ring for example).
Old May 6, 2014 | 10:57 PM
dwdyer's Avatar
dwdyer
If you have the paddle shifters you can start the auto-stopped engine by downshifting to M1. Have to remember to upshift or it shifts a bit late for normal driving. Going to M/S mode does it too as the manual says.
Old May 7, 2014 | 04:25 AM
CobraBob's Avatar
CobraBob
Are you pushing the Start toggle once or twice when you shutdown? If you only push it once, you remain in the Ignition position and some of the lighting will remain on. Also the radio. If you push it a second time after the engine shuts off (clutch out with the manual) the ignition shuts off, too. Along with all of the lighting and the radio.
Old May 7, 2014 | 05:51 AM
ojedam64's Avatar
ojedam64
twice, I shut down the engine, then do it again it shuts down the radio and gauges...then I get out, lock the door (it beeps to set the alarm) and then all that stuff I said previously happens.
Does yours do this? I never noticed until it was night time.
Old May 7, 2014 | 07:40 AM
dwdyer's Avatar
dwdyer
The image of the car in the instrument cluster, when you've stopped the car and open the driver's door -- it winks at you.
Old May 7, 2014 | 10:37 AM
msbragg's Avatar
msbragg
This was a new one to me coming from a 2008... The cruise control buttons for accelerate and decelerate have 2 notches. Push the button to the first notch and your cruise setting goes up/down by 1 mph. Push it to the second and it goes up/down by 5 mph. Very handy.
Old May 7, 2014 | 11:02 AM
VYPUR's Avatar
VYPUR
I saw a video of that, can't find it now of course. I wasn't sure if it was real or just for the ad.
Old May 8, 2014 | 11:58 AM
MarcoPolo's Avatar
MarcoPolo
btw, this does NOT work on my car, so it's part of a package.
Old May 8, 2014 | 12:20 PM
ojedam64's Avatar
ojedam64
yes very handy, i like that it gives you the digital speed selected. when slowing down if you hit the minus to lower the speed, it feels like its hitting the breaks because it slows you down quick. All other vehicles I've driven just coast to the lower speed.
Old May 9, 2014 | 06:15 AM
peter314's Avatar
peter314
After driving the F56 all day yesterday, This morning I found that you can voice command to any menu instead of navigating with the control wheel.
Also I noticed that when you shut the car off with one push of the Ignition button the lights and radio stay on, If you get out, close the door, and lock it everything shuts off as if you had pushed the Ignition twice.
Old May 9, 2014 | 07:32 AM
blanc71's Avatar
blanc71
What do you mean it winks at you?
Old May 9, 2014 | 08:10 AM
peter314's Avatar
peter314
Old May 9, 2014 | 06:57 PM
StevenZoz's Avatar
StevenZoz
That would be the 'dynamic' cruise control
Old May 11, 2014 | 11:54 AM
shraz's Avatar
shraz
1x stop, music still plays and lights are on. Mine stops everything when I lock the car.
2x stop, everything off.
Old May 11, 2014 | 02:53 PM
fxdavis's Avatar
fxdavis
Haven't seen any updated videos in the owner's lounge, but here is a YouTube link which has a bunch of feature videos for the F56...
"https://www.youtube.com/user/MINIvideoCH"
Old May 19, 2014 | 07:55 PM
shraz's Avatar
shraz
Is this a standard feature? Mine doesn't do that. I did read the feature in the manual and how to turn it off by just flipping the the passenger side.
Old May 19, 2014 | 07:57 PM
MarcoPolo's Avatar
MarcoPolo
same here. must be included in an option. hopefully when more folks get involved with NCSExpert we'll be able to unlock some of these features.
Old May 19, 2014 | 08:02 PM
shraz's Avatar
shraz
I read around, seems you need the folding mirrors package
Old May 20, 2014 | 06:21 AM
SeppTB's Avatar
SeppTB
Seems likely. Thankful the Cold Weather package adds powerfold mirrors... guess I can thank our ultra-snowy winters for something, snagged me a feature I may have otherwise missed.
Old May 20, 2014 | 09:43 AM
dwdyer's Avatar
dwdyer
The auto dimming mirrors forces you into the auto-folding side mirrors as well, for those that want it without the cold weather package.
