F55/F56 Things You Didn't Know Your F56 could do:
i got the cold weather pack...not sure what I'll use the auto folding mirrors for though.
and now, I just got a job south of orlando (moving in a couple months) so won't be needing that cold weather pack either....oh well a heated seat is still nice when its 60 out LOL
Too cOOl!
No idea what the actual temps are but each front seat has three heat level settings. They go from mildly hot to kinda warm.
LED Headlights
I got the LED headlights on my F56 (without the turning feature) and noticed when I turned them on in the garage that the height of the beam changes as they come on. Not exact measurements but when they come on the top of the beam is say 3 feet above the ground then within a second or so it's like opaque shield comes down and they're only say 2 feet above the ground. I think this is maybe how they do high beams on the LED lights - not with more illumination but physically changing the light pattern. Maybe I'll don my welding helmet and see if I can see anything moving in there.
That sounds like a possible scenario, but if what you're saying is true then the whole "bulb" mechanism is moving downward as they light up. That would be a relatively complicated situation. I can't say you're wrong but it makes me want to look up there even more. I won't have a chance to do this until mid next week, but if somebody hasn't come up with a definitive answer by then - that's exactly what I'll do.
The LED lights are basically the same as the HID lights in that regard -- self leveling.
If you go uphill, the lights adjust down a bit tomatoey pointing on the road. Adjusting up a bitif you're going downhill.
I believe they are also shuttered the way the HID lifts were on the R56. Shutter down for low beams, shutter up for high beams rather than having a separate bank of lights for high beams.
The shutter and leveling are two different things.
Cornering lights a third thing.
Oh, and it's not the light source that moves when leveling, it's the lens assembly.
On incandescent lights (which can be self-leveling but usually aren't) it's the reflector.
This guy has a problem with his but you can see what's going on.
Love the fact that when you unlock the car at night the headlights come on, and even cooler - the exterior door handles light up!
I never saw reference to this anywhere on the MINI site?
Its awesome though!
Its awesome though!
This was new tonight, I went out and added some music to the HD and ran the car round the neighborhood. When I got out of the car as I was going in I noticed the light around the center ring was pulsing in red. It did it for like 1-2 minutes then it stopped. It's weird I've only had it for like 3 days but never seen this before.
I don't have the alarm, it's also weird I've only seen it once. Tried last night to get it to do it again but it never did it.
I believe that is if you have your headlights turned ON or in auto?
It doesn't appear so.
That's good to know, although I was wondering about an optional setting to make them fold-in every time the car is shut-down.
