F55/F56 Wheel/tire question, miniusa.com confuses!
Old Apr 13, 2014 | 01:21 PM
marcussoori's Avatar
marcussoori
The 17" Silver Cosmos Spoke:
17" x 7" wheel
205/45 R17 tire
The 18" Cone Spoke:
18" x 7.5" wheel
225/45 R18 tire
Why is the "45" profile of the tire the same for each wheel? Doesn't this mean the 18" tires have a greater circumference than the 17" tires, and the speedometer will show different readings for each tire with the car at a constant speed?
Could this be a typo on the miniusa.com site and the correct profile size for the 18" wheel might be "40"?
Thanks in advance...
Old Apr 13, 2014 | 02:38 PM
torpeau's Avatar
torpeau
17" x 7" wheel
205/45 R17 tire
The 18" Cone Spoke:
18" x 7.5" wheel
225/45 R18 tire
At tirerack, I see, for instance, that on a Potenza RE050A
a 205 45 R17 does 857 revs per mile and a 225 45 R18 does 804 per mile. The 18s will read slower.
Old Apr 13, 2014 | 03:26 PM
papawhiskey's Avatar
papawhiskey
Isn't there a tweak for the ECU that the mfg can put in that does the calculation for speed/distance? They then plug in the value for the tire size so things come out right. If you've got a GPS you can simply check the speedo against the GPS and see if they agree.
Old Apr 13, 2014 | 05:02 PM
junkart's Avatar
junkart
Typo for sure. The 225/45R18 is the spec-ed tire for R60/61. Way too fat for the F56. 225/35R18 is the closest one to stock OD, slightly under but really close... although i'm not sure if such size will work without rubbing or not.
Old Apr 13, 2014 | 05:26 PM
VYPUR's Avatar
VYPUR
MINI R56 speedo is off +4mph from factory. Always drove me crazy that it is that way.
Old Apr 13, 2014 | 05:29 PM
marcussoori
Guess I'll have to wait until my car arrives before ordering new tires.
Old Apr 13, 2014 | 06:05 PM
torpeau's Avatar
torpeau
Historically, speedos have nearly always been off. Car magazines routinely showed that they were 5-6% fast in their road tests. GPS is only making it more more widely known. Of course, tire wear, inflation and tire brand are also factors.
Old Apr 13, 2014 | 07:39 PM
rkw's Avatar
rkw
Yes, it's an error. Here is the MINIUSA price sheet: http://s3.motoringfile.com.s3.amazon...ng-1-30-14.pdf
The correct tire size is 205/40 R18
All of the tire sizes 15"-18" are the same as in previous generations.
Old Apr 14, 2014 | 08:37 AM
marcussoori
Thanks so much, rkw! Tires ordered.
For anyone interested, tire rack.com is offering a $70 gift card for eligible Michelin 4-tire sets purchased from today through the first week of May.
Old Apr 14, 2014 | 08:40 AM
marcussoori
rkw, not sure if you noticed, but all the 17" and 18" tires are showing 205 width...perhaps that could be a typo as well?
Maybe the correct size is 225/40 R18?
Old Apr 14, 2014 | 08:42 AM
marcussoori
Never mind...forgot and just confirmed you were correct via a thread I started a while ago.
https://www.northamericanmotoring.co...tire-size.html
Thanks for all your help!
silence2-38554
Nov 12, 2015 09:39 AM
desant89
R55 :: Clubman Talk (2008+)
Sep 2, 2015 11:24 AM
kurosh
Aug 27, 2015 11:54 AM
Drumsound
Aug 25, 2015 05:22 AM
TJANK
Aug 24, 2015 06:11 PM
