F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Received a Transmission "Over-Heating" Warning Light
Old Mar 14, 2018 | 01:28 PM
Johnny Danger's Avatar
Johnny Danger
I might be the first forum member to earn the distinction of getting a transmission "Over-Heating" warning light on an F54.
I recently got stuck in a snow bank so badly, that in the process of trying to get myself out (while also digging my way to China) I apparently overheated the transmission to the extent that it triggered a warning light.
I doubt that I did any real image to the drivetrain, but I certainly did something to overcook the tires as my Clubman hasn't ridden as smoothly since the episode. :(
Old Mar 15, 2018 | 08:00 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
Manual or Autobox?
Old Mar 15, 2018 | 08:24 AM
Johnny Danger
Manual
Old Mar 15, 2018 | 08:31 AM
cyow5's Avatar
cyow5
If you have snow buildup inside the rim, that will add unbelievable vibration, so check that before assuming the heat did anything to the tires. Assuming you killed the engine after the warning light and let it cool off before driving again, does it stay on?
Old Mar 15, 2018 | 09:58 AM
Johnny Danger
The vehicle was shutdown within a minute or two after the warning light came on, and it's remained off ever since.
As far as snow/ice build up in the wheels is concerned, the incident occurred weeks ago and the vehicle has been driven several hundred miles since then.
While there are no clear signs of damage to the tires, I suspect that I diid something to compromise the integrity of rubber, as the ride quality has never been the same.
Old Mar 15, 2018 | 01:51 PM
darex's Avatar
darex
Wow! Nearly the exact same thing happened to me, in the same situation, including burning rubber smell, but without the warning message. A by-stander told me my wheels were spinning, but I couldn't hear it. Also manual.
Old Mar 15, 2018 | 02:32 PM
Johnny Danger
What was the outcome with your tires?
Old Mar 20, 2018 | 07:34 AM
darex's Avatar
darex
They appear fine. Guess it smelled worse than it was?
03_uni-b
Aug 10, 2015 08:56 AM
fastnufva
Apr 27, 2008 10:07 AM
racinbmw
May 3, 2006 11:01 AM
joecooool
Jun 20, 2004 09:11 PM
M7
Jan 28, 2004 05:12 PM
