Electrical Seat heaters TOO warm
Old Mar 11, 2007 | 11:02 AM
PhysicsGeek's Avatar
PhysicsGeek
Maybe it's just me, but the seat heaters on low and high seam way too warm to me. Anyway to tone them down? I rode in a coworkers new VW and it was adjustable from 1-10. Anyone have any good ideas how to cool it down a bit? Different fuse, add resisters inline, etc??? Yes, I did a search, but couldn't find anything.
Thanks, Joe
Old Mar 11, 2007 | 11:34 AM
rkw's Avatar
rkw
There was a Technical Service Bulletin about it. Dealers can adjust the temperature with resistors for too hot or too cold seats. If your car is still under warranty, it should be covered. Alldata.com used to have the TSB document on their website but now you have to purchase their service to access it.
Old Mar 11, 2007 | 05:46 PM
humcmcel's Avatar
humcmcel
I just tun them down or shut them off when it gets too warm. By then the car has warmed up sufficently that I don't need them any more anyway.
Old Mar 11, 2007 | 05:53 PM
CR&PW&JB's Avatar
CR&PW&JB
You need a tougher butt. You must be a desk jockey.
Yep, they're pretty darn warm. I like them on the low setting only and even then, I turn the heating system down to about 68 degrees. That combo is very comfortable to me. Try it.
Might have to wait until next winter though... it's almost Spring !! FINALLY.
Old Mar 12, 2007 | 07:21 AM
cristo's Avatar
cristo
Alliance Member
here's the TSB
File Type: pdf
Old Mar 12, 2007 | 12:47 PM
PhysicsGeek
Thanks all,
I'm due for a oil change under free service in 1400 miles anyway, I'll just have them do it then. Thanks for the attachment cristo. And yes, I do have to sit at a desk :impatient , me and my red stapler
Motor On
Old Mar 12, 2007 | 01:00 PM
Loony2N's Avatar
Loony2N
Thanks, Joe
It's to keep the pizza warm!
Old Dec 7, 2007 | 05:03 PM
cristo's Avatar
cristo
Alliance Member
I just got the adapter to use when the seats are too warm (as mine are).
In case anyone is interested, I checked it out with my volt-ohm-meter
and determined that it places a 27K resistor across the yellow and
blue wires. Well, they're blue and yellow on the adapter, on the
Bentley Manual, it's probably pin 2 and pin 1 (white/green and green/violet,
respectively) on the wires in the car.
This will alter the signal from the temperature sensor in the seat heater that tells the
heating circuit how hot the seat is and when to apply current or not to the heating
elements.
I suspect that the one used when the seats aren't warm enough probably
uses a resistor in series interrupting the blue or yellow wire on the adapter
(whichever one corresponds to pin 2 - white/green).
See 3 posts back for the TSB about this.
It's too cold and slushy and dark to put it in now.
After I put the adapter in I'll report on the change in seat temps.
Old Dec 8, 2007 | 07:01 AM
cristo's Avatar
cristo
Alliance Member
Done.
The seats used to have 3 settings: way too hot, too hot, and off.
Now they suit me much better: hot, warm, and off.
Old Dec 19, 2007 | 06:54 PM
kgardnez's Avatar
kgardnez
Great info, as I'm out of warranty I think I will need to find myself a 27K resistor!
Where might I be able to mail order this adapter (if I want to save myself some time)? My dealership is over an hour away...
Old Dec 19, 2007 | 07:16 PM
FP's Avatar
FP
I don't know about you guys, but I turn mine off as soon as my but is warm, and the car is comfortable temperature wise.
Old Dec 19, 2007 | 07:20 PM
rkw's Avatar
rkw
You can order from Classic MINI -- just tell them the part number in the TSB. Your own dealer may be willing to put it on a credit card and mail it to you (my dealer offered to do this once for a special order part, but I'm just 10 minutes away).
Old Dec 20, 2007 | 05:52 AM
cristo's Avatar
cristo
Alliance Member
I used pelicanparts, but classic mini is probably 10% cheaper.
Only about $20 and $8 shipping from the former.
Part number 61 10 0 152 025.
Easy to do yourself. It's the small white connector near the inner seat rail
that you have to patch into.
Don't fool with the Airbag connectors.
Look at the TSB in post # 5 above.
Old Jan 19, 2008 | 04:50 PM
JLLG's Avatar
JLLG
Not sure how to move this but I realized after posting that another thread in the 2nd gen section linked to this. I have a R56.
I recently had my driver's seat leather (back only) cover replaced and now the seat heater barely gets warm. The original seat cover and the current passenger seat warms very nice and hot (on the high leve). I actually like this because as someone else stated, I just turn it off typically after I am nice and warm. By the way, I was told that seat heating elements are integrated into the seat covers, seems ridiculous to me especially if we have to replace a heating element after warranty expires. The cost is probably 10 times more that it would need to be.
Anyway, I am puzzeled as to why my seat is now not warming as the original one did. The TSB only mentions 2 options, one for making hotter and one for making colder. This does not seem to provide much flexability for adjusting. Maybe its possible that the technician installed this part the wrong way?
Old Jan 19, 2008 | 09:51 PM
MiniDaMoocher's Avatar
MiniDaMoocher
Try wearing pants
Old Jan 28, 2008 | 11:15 AM
Ferroequine's Avatar
Ferroequine
Not too warm for me. Its -22F outside right now!
Old Jan 28, 2008 | 11:18 AM
tony1athome's Avatar
tony1athome
Anyone have any issues with their seat heater when used in conjunction with neoprene seat covers?
Old Jan 29, 2008 | 04:57 AM
ksmaas1's Avatar
ksmaas1
I'm using the moss seat covers (look like space cloth), and the seat heaters work nicely right through them. They are thicker than the neoprene, so I suspect the heat should work Ok there too. I have not had the resistor put in, so the seat hearers are the original June 2002 build version. However, it takes noticably longer for the heat to kick up... a good 4 to 5 minutes instead of the 2 minutes in my other 2002 with no seat covers.
Old Jan 29, 2008 | 05:01 AM
mmatarella's Avatar
mmatarella
They work great with my neoprene Wet Okoles.
Old Jan 29, 2008 | 12:42 PM
tony1athome
Cool, thanks! That's great news.
Old Mar 8, 2008 | 07:58 AM
AllBlack05S's Avatar
AllBlack05S
I know its an older post in this thread but I laughed when I saw it because I've done just that. Pizza in the passenger seat on High. maybe this should go in the things you don't know about your mini thread too.
I use position 1(low) then 3(off) myself. never know when I'll need the nuclear hot position 2
Old Mar 8, 2008 | 08:11 AM
joe_r's Avatar
joe_r
LOL I just had NW Mini install the warmer seat heater tsb & they are wicked warm now.
Gotta have warm in teh NW.
joe r
please_remain_calm
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:33 PM
rob&JCW
Sep 10, 2015 12:06 PM
Sterling Thompson
Sep 9, 2015 07:42 PM
SeattleF56
Sep 3, 2015 03:01 PM
