Electrical Antenna ripped out...
Old Apr 19, 2006 | 03:35 PM
sandtoast500's Avatar
sandtoast500
My Girlfriend drove the MINI thru an unauthorized car wash without my permission ( ) and the antenna got ripped out of the base along with the female screw piece. The antenna is gone and the base is cracked and broken on top.
I know this has happened before to SOMEONE... I called the dealer and they said it would be $400. They did say it doesn't need to be covered and that water would not pool in the roof thru the hole. I hope they're right.
c'mon... How can I replace the base parts, base and antenna? Can I go in thru the security sensor in the backseat roof? Or is it more intense?
Any help or direction is welcome, car wash suggestions are not.
Thanks,
-Steve
Old Apr 19, 2006 | 04:25 PM
sfgrunge's Avatar
sfgrunge
Everything that I have seen and read says that you just pop off the security sensor and the antenna parts are right behind it. You should not have take down the entire headliner. I know that I have seen pics of antenna replacement on NAM or MINI2.
Old Apr 19, 2006 | 04:37 PM
become1's Avatar
become1
whenever something bad happens to our cars we usually take the opp to upgrade the car- so if you are looking to replace the antenna, i'd suggest getting a honda s2000 one
shorter and better lookin imo
i think itll run you about $50. sorry i dont know anything about the base
Old Apr 19, 2006 | 04:43 PM
mcsdmn's Avatar
mcsdmn
mini mania sells 'shorty' ones if your thinking about going that route
Old Apr 20, 2006 | 08:40 AM
sandtoast500
Yea, I had the Alta antenna on when it went into the car wash...
I really liked the look of it. I may change up to a diff one... But what other bases are available?
Old Apr 20, 2006 | 08:46 AM
Wagnbat's Avatar
Wagnbat
I got mine for $16 from my local honda dealer.
Old Apr 20, 2006 | 09:20 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Depending on the model year and equipment (you have an '05, apparently without Nav), the antenna bases differ. Most of the antennas can be replaced by accessing the mounting nut and pigtail cables through the motion sensor hole. Other versions have an amplifier mounted below the roof with the nut on top which is accessed by dismantling the base from above and removing the mounting nut and removing the amp from inside the car.
Old Apr 20, 2006 | 10:29 AM
Passat774's Avatar
Passat774
try a junk yard, there has to be a few Mini's out there somewhere
pglgp1292
Oct 5, 2015 06:47 PM
Colt45Magnus
Oct 1, 2015 04:08 PM
simo711
Oct 1, 2015 05:36 AM
eliseo1981
Sep 30, 2015 07:57 PM
dragonby
Sep 25, 2015 08:10 PM
