Electrical Ground in cabin for Hella 500 install
Old Feb 21, 2019 | 09:03 PM
Racingguy04's Avatar
Racingguy04
I'm adding some hella 500's to my car for night driving and I'm almost done, but I can't find an easily accessible ground in the cabin for the switch. Does anybody know of a convenient ground near the center console, or the fuse panel? My backup is to run the ground through the firewall near the hinge for the hood, but it's a pain to get the wires through the grommet, and I don't want to stretch out the rubber too much in case I decide to pull this whole thing off.
Old Feb 22, 2019 | 04:43 AM
N0B0DY's Avatar
N0B0DY
Just find a place that's metal. The whole chassis is grounded.
Old Feb 22, 2019 | 05:33 AM
iwashmycar's Avatar
iwashmycar
I think I had found a screw over near the dead-pedal area when I had to ground a switch. On a more recent install I actually ran an extra ground wire with my relay trigger wire back out to the engine bay just so i wouldnt have to ground a switch inside at all. Was actually worth it.
Old Feb 26, 2019 | 05:52 PM
JAB 67's Avatar
JAB 67
Iwashmycar: Where did you route your wires through the firewall?
Old Feb 26, 2019 | 06:00 PM
TwoWings's Avatar
TwoWings
Here's one way to find one...hook up a wire to 12V source and bring it in to the cabin...expose a little bit of the bare wire taking care to not let it touch metal and use a VOM meter set on DC Volts....connect the postiive lead to the wire and then use the common lead to touch likely grounding points...you'll know you have a good one when the VOM reads 12+ volts...
Old Feb 26, 2019 | 07:37 PM
Racingguy04
I'm not sure where he put his through, but I used the grommet behind the brake booster when you're looking in the engine bay. It's a bit of a pain, but it's better than drilling holes in stuff. https://cdn4.pelicanparts.com/techar...mall/Pic21.JPG
Old Feb 26, 2019 | 07:38 PM
Racingguy04
Thanks for the tip! I might try this, though I think I've just resigned myself to running another wire through the firewall. It might end up being the simplest option.
Old Feb 27, 2019 | 05:57 AM
iwashmycar's Avatar
iwashmycar
This. There is a roughly 1" diameter grommet easily seen from inside the up under the dash a little. Worked out well.
Old Mar 1, 2019 | 02:58 PM
JAB 67's Avatar
JAB 67
Thanks guys!
minimike21
Electrical
Jan 4, 2012 09:24 PM
Jeremy1026
May 15, 2010 07:43 AM
MInI___Gz
Apr 17, 2010 06:45 PM
Kazy
Dec 17, 2008 09:56 AM
Aeromax
Electrical
17
Jan 27, 2007 05:57 PM
