Electrical R53 NCS Expert Guide Add-In
Old Jun 11, 2012 | 08:52 PM
mziol's Avatar
mziol
Set out to get auto up on my windows today using the R56 NCS Expert guide (because there really isn't one for R53). Had to do a little of my own tinkering but eventually found the correct way and now have auto-up on my windows without the need for any aftermarket circuit boards (they do look great though for the other functions they offer!).
The directions are basically the same as GTECKO's that can be found here: https://www.northamericanmotoring.co...beginners.html
Follow those for the installation process and make sure you put R50 and R56 folders in the DATEN folder.
The instructions are exactly the same until you get to the choose chassis section. Here you will choose R50 (I did this for a 2006 Mini Cooper S with JCW Kit) instead. Then, you choose EWS instead of CAS which you would choose if you had an R56. Go ahead and then (in the case of auto-up windows) choose BC1 and read the ECU. Go in to the FSW_PSW.TRC file (AS ALWAYS, MAKE A BACKUP!) and edit the lines of code you want to change. Next, I had to go to Job and set it to SG_CODIEREN and then tell it to run the job. It worked for a bit (just like his guide will say) and then completed. Viola! Working auto-up windows.
I know this information is sort of out there but I just wanted to write it down for anyone with an R53 that sets out to do this. It could save them some time because it set me back about an hour (maybe the sangria I was sipping did too ). Hope this helps somebody out, and remember to thank the guys at the BMW Coding forums as well as GTECKO!
Old Jun 20, 2012 | 07:41 PM
claancy's Avatar
claancy
What settings did you change in your FSW_PSW.TRC file? Auto-up is working on my driver's window, but not the passenger's.
Old Jul 16, 2012 | 08:02 AM
mziol's Avatar
mziol
Sorry for the delayed response. I couldn't actually get the passenger window up to work yet, if I do I'll post results. There doesn't seem to be any code for a pinch sensor on my R53.
In the meantime, I did get the OBC to work, and now I can see MPG, distance to empty, etc on the tac display in case you're interested in that.
Old Jul 31, 2012 | 08:34 AM
spidertnt's Avatar
spidertnt
can you define folder setup better.
C:\NCSEXPER\DATEN\R50\--contains all files from r50 daten sub folder
C:\NCSEXPER\DATEN\R56\--contains all files from r56 daten sub folder
Is this correct ?
From the guide
3. Navigate to “C:\NCSEXPER\DATEN\XXX” (where XXX is your chassis code) and run the
“LADEN.BAT” file.
R50 does not contain a “LADEN.BAT” file. I copied the one from R56 folder...is this ok.
Old Jul 31, 2012 | 02:00 PM
claancy's Avatar
claancy
I copied the one from the R56 folder, and changed the "R56" to "R50" in the first line and ran it.
Old Jul 31, 2012 | 06:44 PM
spidertnt's Avatar
spidertnt
mziol what package are you using for your coding..GTECKO 's links are dead for me...edit downloaded GTECKO setup still no go.
Vin is faulty........... error can't find ECU
Old Aug 6, 2012 | 09:15 AM
spidertnt's Avatar
spidertnt
Just sharing
All my troubles came from my cable...bought cheap China version only compatible with cars after a certain date . My car requires pin8 and pin7 tied together....took my cable apart attached both pins together. Now NCSexpert can read my VIN and i have programmed driver side window 1 touch up !
source http://osefactory.com/tools/k+dcan/A...patibility.pdf
Our K+DCAN USB Interface came in the beginning unlike products from
other vendors with full backward compatibility to older K-Line
equipped vehicles, many of those vehicles use besides the primary KLine on pin7 also the secondary K-Line on pin8 for additional modules
(ECUs). Unfortunately on the latest F Series DCAN equipped vehicles
that pin got re-used as Ethernet activation which interfered with that
full backward compatibility by causing connection problems.
Because most customers prefer the ability to work on latest DCAN
equipped vehicles over the full backward compatibility to older K-Line
equipped vehicles - pin8 was physically removed from the Interface to
enable that. The consequence from that step is that when used in
backward compatibility mode on older K-Line equipped vehicles that
the Interface now only covers modules (ECUs) connected to the
primary K-Line on pin7. Modules (ECUs) connected to the secondary KLine on pin8 will no longer be directly accessible.
Old Aug 8, 2012 | 05:13 PM
spidertnt's Avatar
spidertnt
I'm interested in those settings...hope they will work for my MCS 2004
Old Aug 17, 2012 | 07:48 AM
acowx's Avatar
acowx
NCSExpert working on 03 R53
Just programmed auto-unlock when key removed to get rid of that annoying double-pull.
Auto-up on the windows next.
Awesome
Old Aug 17, 2012 | 12:44 PM
acowx's Avatar
acowx
Auto-up on drivers and passenger side done. Chuffed.
Old Aug 17, 2012 | 12:49 PM
spidertnt's Avatar
spidertnt
Does it work for you on the passenger side ?...if so can copy and paste your FSW_PSW.TRC file so i can compare.
Old Aug 17, 2012 | 12:53 PM
acowx's Avatar
acowx
Yeah, works fine on the passenger side. The 4 lines I modded for the windows are in RED
DWA
nicht_aktiv
VERRIEGELN_AUT_AB_X_KM/H
aktiv
ZV_SELEKTIV
aktiv
STANDRUECKSCHALTUNG
aktiv
VERRIEGELUNGSSCHWELLE
16_km/h
GED_FL_ALS_DRL
nicht_aktiv
HEIMLEUCHTEN
wert_01
TAGFAHRLICHT_ECE
nicht_aktiv
AC_AUTO
aktiv
AC_BASIC
nicht_aktiv
AC_POLUTION
aktiv
ALARM_INDICATION
aktiv
AUX_OFF_TIME
r50
AUXILIARY_LAMP_ENABLE
nicht_aktiv
BOOT_RELEASE_ENABLE
aktiv
CAT1
nicht_aktiv
CLUTCH_OFF
wert_01
CLUTCH_ON
wert_01
DAYLIGHT_RUN_POWER
wert_01
DEFAULT_EXT_AMBIENT_TEMP
nicht_aktiv
DIPPED_BEAM_NAS
nicht_aktiv
DISABLE_FRESH_PARK
nicht_aktiv
DISABLE_RECIRC_PARK
nicht_aktiv
DO_MISLOCK_ON_ALL_RF
nicht_aktiv
EEROM_STATUS
r50
ENTRIEGELN_B_MOTOR_STOP
aktiv
FOG_DISABLE_WITH_TRAILER
aktiv
FRONT_FOG_NAS
aktiv
HALTEN_FB_OEFFNEN_TASTE
komfort_oeffnung
HEADLAMP_LEVEL_POSITION1
wert_01
HEADLAMP_LEVEL_POSITION2
wert_01
HEADLAMP_LEVEL_POSITION3
wert_01
HFS
nicht_aktiv
HFS_HIGH_TEMP_TIME
wert_01
HFS_LOW_TEMP_TIME
wert_01
HFS_OFF_TIME
r50
HR_HIGH_BAT_THRESHOLD
wert_01
HRW_HIGH_TEMP_TIME
wert_01
HRW_LOW_BAT_THRESHOLD
wert_01
HRW_LOW_TEMP_TIME
wert_01
HRW_OFF_TIME
r50
INDICATE_DURING_HAZARD
aktiv
KEY_DISARM
aktiv
KEYINTERLOCK_AUTO
manual
KEYINTERLOCK_ENABLE
nicht_aktiv
KOMFORTOEFFNUNG_SCHLOSS
nicht_aktiv
LAMP_WITH_AUX_OFF
aktiv
LAMP_WITH_AUX_SIDE
nicht_aktiv
LAZY_LOCK_WITH_KEY
aktiv
LIGHTS_ON_WITH_WIPERS
nicht_aktiv
LOCK_DIRECT_SUPERLOCK
aktiv
LOCK_DOUBLE_SUPERLOCK
nicht_aktiv
MAN_WISCHEN_IM_WASCHPROG
aktiv
MANUFACTURING_MODE
nicht_aktiv
MAX_ALARM_EVENTS
r50
MAX_ON_LEVEL
r50
NO_MAP_WITH_PERM_OFF
nicht_aktiv
NO_SOFT_ON_OFF
nicht_aktiv
NORMAL_MODE
aktiv
PARKING_LIGHTS
aktiv
POWER_WASH_MIN_OFF_TIME
r50
POWER_WASH_OFF_TIME
wert_01
POWER_WASH_ON_TIME
wert_02
RAMP_DOWN_INCREMENT
r50
RAMP_UP_INCREMENT
r50
REAR_WIPER_CONTINUOUS
nicht_aktiv
REF_POINT_STEPPER_MOTORS
r50
REMOTE_CONTROL
aktiv
REMOTE_DIRECT_SUPERLOCK
aktiv
REMOTE_DOUBLE_SUPERLOCK
aktiv
REMOTE_LAZY_LOCK
nicht_aktiv
SEL_ZV_SENDER
aktiv
SENSOR_REGEN
nicht_aktiv
SENSOR_SETTLE_TIME
r50
THRESHOLD_STEPPER_MOTOR
r50
TRANSIT_MODE
nicht_aktiv
TRIGGER_DURATION
r50
ULTRASONIC_WINDOW_OPEN
aktiv
VERRIEGELN_MIT_MOTOR_AN
nicht_aktiv
WIN_PINCH_ENABLE_DRIVER
aktiv
WINDOW_AUTO_UP_DRIVER
aktiv
WINDOW_AUTO_UP_PASS
aktiv
WINDOW_INCH_AUTO
nicht_aktiv
WINDOW_PINCH_ENABLE_PASS
aktiv
WINDOW_SHORT_DRIVER
aktiv
WINDOW_SHORT_PASS
aktiv
WINDOW_SHORT_RAISE_DELAY
r50
WINDOW_SUNROOF
aktiv
WIPER_BOOT_INHIBIT
aktiv
WIPER_CAM_DELAY
wert_01
WIPER_NO_PROG_REAR_WASH
aktiv
WIPER_PROGRAM_WASH_OPTION
option_2
WIPER_REAR_CAM_DELAY
wert_01
WIPER_WASHER_START_TIME
wert_01
WISCHER_GESCHW_ABHAENGIG
aktiv
FRONT_FOG_ENABLE
aktiv
HEADLAMP_LEVEL_TYPE
automatic
INERTIA_SW_FITTED
aktiv
MISLOCK_BEEP_ENABLE
aktiv
REAR_FOG_ENABLE
nicht_aktiv
Old Aug 17, 2012 | 01:39 PM
spidertnt's Avatar
spidertnt
Comparing mine to yours the only difference i can see is also red. I'll try changing that to nicht_aktiv
nicht_aktiv
aktiv
aktiv
WINDOW_AUTO_UP_PASS
aktiv
WINDOW_INCH_AUTO
aktiv
aktiv
WINDOW_SHORT_DRIVER
aktiv
WINDOW_SHORT_PASS
aktiv
r50
WINDOW_SUNROOF
aktiv
Old Aug 17, 2012 | 01:42 PM
acowx's Avatar
acowx
nicht_aktiv
aktiv
aktiv
WINDOW_AUTO_UP_PASS
aktiv
WINDOW_INCH_AUTO
aktiv
aktiv
WINDOW_SHORT_DRIVER
aktiv
WINDOW_SHORT_PASS
aktiv
r50
WINDOW_SUNROOF
aktiv
Cool, interested to hear if that fixes it for you.
Old Aug 17, 2012 | 09:37 PM
KevinBaker's Avatar
KevinBaker
Is it possible to code the extra features into the tacho with this (i.e. MPG, dist to empty etc) - as I've replaced my speedo/tacho and they don't have the extra features, and MINI Australia won't enable them for me?
Also doing this could I change my MPH digital speedo to KMPH?
Old Aug 18, 2012 | 08:01 AM
spidertnt's Avatar
spidertnt
passenger still doesn't work for me...maybe be hardware or BC1 revision.
Old Aug 18, 2012 | 08:05 AM
spidertnt's Avatar
spidertnt
Awesome
can you tell me what line for auto-unlock....and what is your BC1 revision is mine is BC1.C03 ?
Old Aug 21, 2012 | 07:51 AM
claancy's Avatar
claancy
can you tell me what line for auto-unlock....and what is your BC1 revision is mine is BC1.003 ?
From this thread:
Automatic unlocking after engine off
BC1 module - ENTRIEGELN_B_MOTOR_STOP
Old Aug 21, 2012 | 07:54 AM
claancy's Avatar
claancy
I don't remember the BC1 revision levels, but I have been able to get both windows to auto-up on three different 2003 cars (11-2002 thru 07-2003 builds), but only the driver's window on a 2004 (12-2003 build) and my 2006.
Also, I have the windows up with my remote working on my 2006, but not on any of the others.
Old Aug 21, 2012 | 09:31 AM
spidertnt's Avatar
spidertnt
For my windows up with remote... i have to click the remote lock button many times very fast to close windows and sunroof.
Old Aug 21, 2012 | 10:58 AM
claancy's Avatar
claancy
Out of curiosity, does your car have the "old" 2-button key/remote, or the "new" 3-button one? What's the build date of your car?
Old Aug 21, 2012 | 02:56 PM
spidertnt's Avatar
spidertnt
My MCS is 04/04 with the 2 button remote.
Old Aug 25, 2012 | 12:45 PM
spidertnt's Avatar
spidertnt
Just enabled on-board computer in the KMB module
CODIERUNG_ERFOLGT
codiert
K_ZAHL_TACHO
46463_imp/km
K_ZAHL_TACHO_KOMPL
46463_imp/km
TANK_SICHERHEITSFAKTOR
wert_01
TANK_FILTER_KL15
wert_01
TANK_SCHWELLE_RESERVE
8_l
TANK_MITTLUNGSZEIT
wert_01
TANK_BERUHIGUNGSZEIT
wert_01
K_ZAHL_WEG
46463_imp/km
K_ZAHL_WEG_KOMPL
46463_imp/km
MOTOR_ART
benziner
SPRACHE
kanada
ZEIT_EINHEIT
12_stunden
TEMPERATUR_EINHEIT
grad_c
WEGSTRECKE_EINHEIT
km
WEG_DURCHSCHNITT
km/h
VERBRAUCH_D1
l/100km
BC
aktiv = enable onboard computer
ASC
aktiv
LL/RL
linkslinker
GURTWARNUNG
mit_gurtschlosskontakt
TANK_SCHWELLE_AUF/AB
wert_01
SIA_GRENZE_INSPEKTION
25.000_km
SIA_GRENZE_ZEIT
0_tage
SIA_LITER_GRENZE
1.6_cooper_s
AUSSENTEMP_DELTA_K1
wert_01
AUSSENTEMP_ZEITKONST_Z1
wert_01
AUSSENTEMP_ZEITKONST_Z2
wert_01
TANK_ANZEIGEWINKEL
kennlinie_01
KUEHLMITTELTEMP_ANZEIGEWI
kennlinie_01
LICHTWARNUNG
aktiv
GETRIEBE_ART
handschalter
TANK_VORHALT_REICHW
wert_01
WEG_EINHEIT
km
AKUSTIK_DWS
aktiv
DWS
aktiv
ZUENDSCHLUESSEL_WARNUNG
aktiv
AUSSENTEMP_WARN_AKUSTIK
aktiv
LIMIT
nicht_aktiv
GONG_1
wert_01
ANZEIGE_FUEHRENDER_NULLEN
aktiv
KALIBRIERUNG_TACHO
wert_01
LCD_DIMMUNG_MAX
wert_01
LCD_DIMMUNG_MIN_NACHT
wert_01
LCD_DIMMUNG_MIN_TAG
wert_01
REMOTE_KOMBI
dzm
AUSSENTEMP_SENSOR
aktiv
A_TEMP_DELTA_OFFSET
wert_01
A_TEMP_OFFSET_SCHWELLE
wert_01
AKUSTIK_TANK_RESERVE
nicht_aktiv
AKUSTIK_WARN_UEB_LEITUNG
nicht_aktiv
AKUSTIK_WARN_UEBER_BUS
aktiv
AUSSENTEMP_DELTA_K2
wert_01
AUSSENTEMP_SPERRZEIT_2
wert_01
AUSSENTEMP_SPERRZEIT_3
wert_01
AUSSENTEMP_ZEITKONST_Z3
wert_01
AUSSENTEMP_ZEITKONST_Z4
wert_01
BC_GESCHW_ANZEIGE_DIGITAL
aktiv
BC_TWSZ_2
nicht_aktiv
BREMSFLUESS_FILTER_ZEIT
25_sec
BREMSFLUESSIGKEIT_UEBER
can_bus
GONG_FREQ2
wert_01
KALIBRIERUNG_WEGSTRECKE
wert_01
KOMBI_TYP
ece
KUEHLMITTELTEMP_WARNSCHW
wert_01
MOTORHAUBE_OFFEN_WARNUNG
aktiv
ODOMETER_OFFSET
wert_01
PREDRIVE_CHECK
aktiv
RUECKWAERTSGANG_WARNUNG
aktiv
SCHWELLE_DZM_WARNFELD_1
nicht_aktiv
SCHWELLE_DZM_WARNFELD_2
nicht_aktiv
SCHWELLE_DZM_WARNFELD_3
nicht_aktiv
SCHWELLE_DZM_WARNFELD_4
aktiv
STOPPUHR_0_AUF_100
nicht_aktiv
STOPPUHR_1/4_MEILE
nicht_aktiv
TANK_1_ADC_FEHLER_OG
wert_01
TANK_1_ADC_FEHLER_UG
wert_01
TANK_2_ADC_FEHLER_OG
wert_01
TANK_2_ADC_FEHLER_UG
wert_01
TANK_FEHLER_SCHWELLE
wert_01
TANK_SCHW_RES_HYSTERESE
wert_02
TANKDAEMPFUNG_FAHRT_AB
wert_02
TANKDAEMPFUNG_FAHRT_AUF
wert_02
TANKDAEMPFUNG_NORMAL_AB
wert_01
TANKDAEMPFUNG_NORMAL_AUF
wert_01
TANKGEBER_1_LITER
kennlinie_02
TANKGEBER_2_LITER
kennlinie_02
TLETZ
wert_01
UEBERTEMP_WARNUNG
nicht_aktiv
VERBRAUCH_2
nicht_aktiv
VES_INFO
r50
WARN_GESCHW_LIMIT
nicht_aktiv
ZEITINSP_DISPLAY_FLAG
icon_wird_nicht_angezeigt
ZEITINSPEKTION
nicht_aktiv
ZEITINSPEKTION_VORGEZOGEN
nicht_aktiv
ANZEIGE_CFC
nicht_aktiv
AUSGABE_FEHLERSPEICHER
aktiv
BC_ANZ_NACH_ATEMP_WARN
aktiv
BC_QUITT_ATEMP_WARN_LSS
aktiv
CC_AUSSENTEMPERATUR
aktiv
DWS_UEBER
can_bus
TANK_NICHT_MESSBAR_OBEN
wert_02
BC_NAVI_VISUELLE_WARNUNG
nicht_aktiv
BC_RW_VERB_U_GRENZE
wert_01
SIA_GWSZ_BEI_SERVICE_MSB
wert_01
SIA_TAGE_BEI_SERVICE
wert_01
SIA_TIME_SERVICE_COUNTER
wert_01
TANKDAEMPFUNG_STAND_AB
wert_01
TANKDAEMPFUNG_STAND_AUF
wert_01
BC_AKTUELLER_VERBRAUCH
aktiv
BC_DURCHSCH_GESCHW
wie_tacho
BC_GESCHW_ANZEIGE_GESCHW
wie_tacho
BC_GESCHW_ANZEIGE_KBUS
nicht_aktiv
BC_LIMIT_GESCHW
wie_tacho
BREMSBELAGVERSCHL_WARN
aktiv
MOTOR_OELSTAND_AUSWERTEN
nicht_aktiv
UHR
nicht_aktiv
KBUS_SPEED_LOWERLIMIT
lower_limit
KBUS_SPEED_UPPERLIMIT
upper_limit
KUEHLMITTELTEMP_BEGRENZ
aktiv
KUEHLMITTELTEMP_SPERRZEIT
wert_01
OILPRESSURE_ANZEIGEWI
kennlinie_01
OILTEMP_ANZEIGEWI
kennlinie_01
SEATBELT_PASSENGER
nicht_aktiv
SEATBELT_US
nicht_aktiv
SRS_VIA_KBUS_WARNUNG
nicht_aktiv
DWS_NEW_SPEC
aktiv
DWS_US
aktiv
GATEWAY_ST_VERBR_KON
nicht_aktiv
SBE_STEP_DOWN
wert_01
SBE_STEP_UP
wert_01
SBE_THRESHOLD
wert_01
Old Aug 25, 2012 | 12:54 PM
acowx's Avatar
acowx
From this thread:
Correct, that is the line I updated to active
Old Aug 26, 2012 | 02:14 AM
KevinBaker's Avatar
KevinBaker
Thansk spidertnt - I'm just waiting on my cable to arrive and I'll let you know if (when) it's worked :D.
Thanks mate!
