Electrical Wiring Color Code at Reverse Lamp of 2011 MCS?
Old Nov 5, 2011 | 09:05 AM
oldsbear's Avatar
oldsbear
Installing a backup camera on Molly2's boot "grill". I'd like to get power from the wires at the backup lamp. I have three wires: brown, green, and black with white stripe. Which is ground? Which is backup lamp?
Old Nov 5, 2011 | 10:28 AM
bluefox280's Avatar
bluefox280
With a mulimeter, you should be able to check.
First, ground is typically the ground (negative).
Second, put the car in the reverse and probe with a test light / multimeter to see which wire carries voltage to the reverse lights.
Confirm that the wire 'loses' power when the car is removed out of reverse.
- Erik
Old Nov 5, 2011 | 10:50 AM
oldsbear's Avatar
oldsbear
Originally Posted by bluefox280
With a mulimeter, you should be able to check....
I can do that, Erik. Is the brown wire the system ground?
Old Nov 5, 2011 | 12:03 PM
walk0080's Avatar
walk0080
Are you planning on posting pics of the installation and finished install?
Old Nov 5, 2011 | 12:14 PM
oldsbear's Avatar
oldsbear
I hadn't planned to; not an elegant installation at all. I will snap a couple, though.
Old Nov 5, 2011 | 01:59 PM
bluefox280's Avatar
bluefox280
Typically, yes; but with anything electrical, always verify.
With a multimeter, touch the brown wire connection and the negative battery terminal to confirm electrical continuity.
- Erik
Old Nov 5, 2011 | 02:05 PM
oldsbear's Avatar
oldsbear
Typically, yes; but with anything electrical, always verify....
Definitely. Thanks.
Old Nov 6, 2011 | 05:24 PM
oldsbear's Avatar
oldsbear
SUCCESS: Backup Camera Installed :)
Today I installed the backup camera mentioned in my earlier posts. Here is a link to my captioned Picasa album:
https://picasaweb.google.com/1072365...raInstallation
FYI: the wires at the backup/rear fog lamp of a 2011 MCS are:
Brown = Ground
Green = Backup Lamp Power
Black with White Stripe = Rear Fog Lamp Power
Kimolaoha
Jul 5, 2023 01:04 PM
Mini'mon
Aug 16, 2015 04:15 PM
Emnotek
Aug 13, 2015 05:47 PM
massmini03
Aug 12, 2015 11:19 AM
