Electrical Making the alarm light blink?
Old May 5, 2023 | 10:56 AM
  #126
Loic Ponce's Avatar
Loic Ponce
Old but very useful thread, thanks for sharing. I coded everything required through Bimmercode, but did not worked. Guess I would have to build a harness between KOMBI and SPEG. I have a spare tachometer wiring harness that came with the LED tachometer I ordered from ebay. Can someone please help me with harness building?
Old May 5, 2023 | 11:13 AM
  #127
Loic Ponce's Avatar
Loic Ponce
Originally Posted by Lucky7
Exactly, i have change DWA_VERBAUT, nicht_acktiv to aktiv, in both SPEG ans KOMBI module, and HEARTBEAT_ZEIT, 0 to 16min.
Origine country of my mini is france. Does it possible to flash the alarm light hardware and rewrite the good one ??
Salut! Est-ce que tu as réussi à le faire fonctionner ?
Old Mar 5, 2024 | 11:06 AM
  #128
Loic Ponce's Avatar
Loic Ponce
Originally Posted by jwzimm
Just to update, I fabricated and installed the jumper wires from the SPEG to the KOMBI per above and my LED now lights up!!
What's your model year? Is it a euro spec? I wired my 2013 R55 Clubman between SPEG and KOMBI following the instructions, coded with Bimmercode. Now if I unlock with the key the hazard lights are flashing, so I guess the coding is right, but the tachometer won't blink... If I change the tachometer with a LCI one with LED, will it work or the speedo will have to be coded?
Thanks in advance
Old Mar 6, 2024 | 03:39 AM
  #129
Yoshimura 1's Avatar
Yoshimura 1
So, this can be done ........I always thought from reading another post that the light on the speedometer can be
coded to blink......They called it the idiot light because of having no alarm......in the vehicle.....
Old Sep 30, 2024 | 04:20 AM
  #130
Martino Dacosta's Avatar
Martino Dacosta
Heartbeat light
Thanks in advance
I wondered if you have the light blink? I coded my R55 and attached the two wires but no blink. I got the normal SPEG in the car and not the High SPEG. So in the normal SPEG it is not possible to place the alarm fuse. I wonder if it have to work without it.
Old Sep 30, 2024 | 07:59 AM
  #131
Loic Ponce's Avatar
Loic Ponce
Unfortunately, not. I think I would have to change the tachometer to make it work. But it would require coding, as a used tachometer will be having a different mileage. And the coding part requires skills I don't have.
BadgeFTW
Oct 17, 2024 09:50 AM
spaboy
R55 :: Clubman Talk (2008+)
Oct 20, 2011 02:14 AM
Parkerton
Jul 3, 2008 02:38 AM
flav
Jul 24, 2007 07:41 PM
Safi
Nov 22, 2003 12:21 AM
