Electrical Making the alarm light blink?
Old Mar 17, 2014 | 01:14 PM
  #101
bmwr606's Avatar
bmwr606
Originally Posted by d454brisson
Success, I was using this as my first coding experience.
After getting the following and baby steeping through:
BEST errors
Cable issues ( a bad one, then latency setting on a new one)
Daten issues
Bonking my Kombi because of the cable
Having to connect the Kombi via the 2 left out wires (Thanks PLAYLIFE for the diagrams)
It works. It coded, it flashes and pulses. Even flashes lights as if alarm was there if opened incorrectly.
Cant wait to figure out more neat coding tricks
D.Brisson
2010 Camden edition
Evolve tune
Evolve catless DP
Forge FMIC
NVIDIA exhaust
Hotchkis rear bar
you did this by making software changes only, no hardware or extra wiring?
please post the specific software changes
Old Mar 17, 2014 | 03:16 PM
  #102
d454brisson's Avatar
d454brisson
I had to do both since mine is a 2010. The two wires from the speg to combi needed to be run see PLAYLIFE posts on page 3-4.
In speg and combi module change DWA to aktiv
Heartbeat to 16
All is posted earlier in this thread specific lines etc
D.Brisson
2010 MCS Camden
Old May 25, 2014 | 08:23 AM
  #103
Lucky7's Avatar
Lucky7
hello guys
I 've got a mini cooper S '07. i have programming DWA_VERBAUT aktiv. But nothing work.
i've installed the two wires from speg and kombi. But nothing work.
My rev counter haven't got the three red led so i have welded it But it not working !
any ideas ??
Old May 28, 2014 | 04:45 AM
  #104
Lucky7's Avatar
Lucky7
anybody know if there is a difference of wiring between a '07 mini cooper S and newer ?
Old Jun 18, 2014 | 08:04 AM
  #105
Lucky7's Avatar
Lucky7
what about HEARTBEAT_INKREMENT in SPEG module ? mine is to "0sec" and yours ?
Old Jun 19, 2014 | 06:11 PM
  #106
Chernobyl's Avatar
Chernobyl
Same here.
Code:
HEARTBEAT_INKREMENT
    0sec
Exactly which settings did you change?
What country of origin is your MINI? Apparently some countries used a different tach that did not have the alarm light hardware.
Old Jun 20, 2014 | 02:53 AM
  #107
Lucky7's Avatar
Lucky7
Exactly, i have change DWA_VERBAUT, nicht_acktiv to aktiv, in both SPEG ans KOMBI module, and HEARTBEAT_ZEIT, 0 to 16min.
Origine country of my mini is france. Does it possible to flash the alarm light hardware and rewrite the good one ??
Old Jun 26, 2014 | 04:58 PM
  #108
Lucky7's Avatar
Lucky7
Can i do a firmware upgrade on the KOMBI to make it blink ? My mini is a 2007. Maybe the firmware is too old. is it possible with tool32 ?
Old Jul 8, 2014 | 03:08 AM
  #109
Lucky7's Avatar
Lucky7
On WDS BMW for R56, I read :
"FRM: Footwell module
The footwell module activates the lighting system for the visual DWA alarm. The junction box electronics (JBE) forward the request on the K-CAN to the FRM. "
So i suppose there is some parameters to change in the FRM module ? Right ?
Old Nov 23, 2014 | 10:34 AM
  #110
gmchew's Avatar
gmchew
SF Bay area
Hi All,
By chance anyone in the SF Bay Area do some of this coding? Would rather see if I can find someone already knowledgable and can do this, instead of buying the cable and trying to figure it out...
Old Dec 1, 2014 | 08:56 AM
  #111
calforhelp's Avatar
calforhelp
Originally Posted by gmchew
Hi All,
I'm in Los Angeles and do coding. PM me if you'd want to make the trip or are ever going to be in the area.
Old Jun 11, 2015 | 07:46 AM
  #112
alpalpha's Avatar
alpalpha
Hello!
Sorry for my bad English but do you guys say that it don't work to code 2011 models?
We have a little R56 Mini one D -11 from Sweden (EU).
Default tacho don't have LEDS so I changed it to one WITH leds, and tried to code both SPEG and KOMBI but it still don't blink.
What could be a possible reason?
If someone can help me over team viewer i am willing to pay for the assistance over paypal.
Thank you very much and take care !!!
Old Jun 11, 2015 | 07:27 PM
  #113
cactusjk's Avatar
cactusjk
Does a 2013 R56 have all the hardware needed for the light to blink?
Old Jun 12, 2015 | 09:49 AM
  #114
It has all the hardware to light, just have to hack through the coding experience listed above.
Old Jun 12, 2015 | 11:53 AM
  #115
synzeus's Avatar
synzeus
Originally Posted by GTECKO
would this light on all the time drain the battery ........
Does it?
Old Jun 12, 2015 | 12:08 PM
  #116
Most likely not, My factory one with factory full alarm pulsates at first , then flashes after an couple minutes all the time I have the door locked. And its factory.
Old Jun 12, 2015 | 12:58 PM
  #117
rkw's Avatar
rkw
Does it?
The light uses much less power than the ultrasonic alarm system it would normally be connected to.
Old Jun 17, 2015 | 07:04 AM
  #118
alpalpha's Avatar
alpalpha
Hey guys!
To make both my self and others understand the total of this project:
1. If not changing DWA_VERBAUT in KOMBI and SPEG modules from "nicht_aktiv" to "aktiv" works. Then we need to do the wiring thing manually.
2. Wiring thing, i dont really understand how we are going to wire from X14272 to X9002. Do we need to add 2 more cables? Or use existing?
Can someone please explain it a little better. Thank you very much!
(I hope it is okey for Peter that i use your photos .)
Old Jun 26, 2015 | 04:43 PM
  #119
walk0080's Avatar
walk0080
Old Aug 14, 2015 | 06:28 PM
  #120
nate09565's Avatar
nate09565
just wanted to say thank you, I followed this guide and enabled the heartbeat on my 2013 JCW. Note, that duing the programming in KOMBI, only DWA_VERBAUT is there... then in SPEG both DWA_VERBAUT and HEARTBEAT_ZEIT are there to be changed. I got misled in thinking one variable was in each module.
Old Aug 14, 2015 | 07:46 PM
  #121
cactusjk's Avatar
cactusjk
On your 2013 R56 JCW assume you did not have to do any hardware mods? Just recoding?
Old Aug 15, 2015 | 09:17 AM
  #122
walk0080's Avatar
walk0080
Old Jan 25, 2016 | 05:09 PM
  #123
Hairbyangel's Avatar
Hairbyangel
hi,
did you find an answer.
Old Aug 5, 2020 | 03:32 PM
  #124
jwzimm's Avatar
jwzimm
In case someone comes across this later, I just tried to code on the LED and...no dice. Looks like I need to add the wires to get this working. Graphic below is shameless copied from previous post. I did find that you can order the required wire terminals from ECS tuning to fabricate your own harness though. You would order qty (4) of P/N 61130005197 (available here: https://www.ecstuning.com/b-genuine-...h/61130005197/) You can extend the leads on the wire ends to be able to route from the FRM to the steering column.
Originally Posted by alpalpha
Old Aug 19, 2020 | 05:48 AM
  #125
jwzimm's Avatar
jwzimm
Just to update, I fabricated and installed the jumper wires from the SPEG to the KOMBI per above and my LED now lights up!!
