Electrical LED Bulbs
Old Jun 29, 2012 | 10:01 AM
  #101
Koopah's Avatar
Koopah
Originally Posted by pjdaustin
Any bulbs on the side and inside of the car can be replaced w/o using resistors. Any bulbs on the front or rear of the car will require led with resistors- this includes the license plate bulb.
I'm not sure about the "side" lights; have you verified this? I believe the scuttle indicator (and other indicator lamps) and the puddle (door) lamps all have warm and cold checks performed by the FRM module. I needed to disable these checks using NCS Expert when I replaced them with LEDs.
Let me know if your LED replacement experience proves different...
Old Jun 29, 2012 | 12:00 PM
  #102
pjdaustin's Avatar
pjdaustin
You can scroll thru the post for confirmation- check your model in the thread. I have '10 R56 and I have no issues replacing the bulbs w/ leds.on the sides or inside of the car.
Old Jul 2, 2012 | 05:26 AM
  #103
GeoffreyM's Avatar
GeoffreyM
Puddles and side scuttles do not have bulb checks. Rule of thumb is if it faces forward or back it has a check. Side or down does not.
Old Jul 2, 2012 | 06:46 AM
  #104
Koopah's Avatar
Koopah
Yes! I agree; I confirmed this yesterday. I stand corrected!
Put my old turn indicator/puddle bulbs in, turned on the cold and warm checks, and replaced the scuttle/puddle bulbs with LEDs. Ran errands and DID NOT see any warnings!
Thanks to all! The fewer NCS Expert overrides the better when it comes time to re-enable after a dealer reset!
Old Jul 3, 2012 | 07:58 PM
  #105
nguyenduylam's Avatar
nguyenduylam
Have HID headlight, fog , driving light , back up , license plate installed today . Flickering when car start !!!! Any body have a solution beside NCS overide the code for 2012 Country man. Thanks
Old Jul 4, 2012 | 06:42 AM
  #106
Koopah's Avatar
Koopah
That's perfectly normal. It is the lamp testing sequence executed by the FRM module when the car is started. It should only last a couple of seconds and will not repeat until you restart the car.
HTH,
Old Jul 4, 2012 | 10:21 AM
  #107
52804x4's Avatar
52804x4
So, the canbus LED's I put in the parking/driving light above the fogs a few months ago have started throwing an error!? They worked fine for a month or two. Could it be that the transistor blew out? The light still works other than the error at every start up!
Old Jul 5, 2012 | 08:51 PM
  #108
nguyenduylam
For CM 2012 owner . I have change license plate bulbs to T10 LED today . No error code
LDN,
Old Jul 6, 2012 | 04:00 AM
  #109
couper1's Avatar
couper1
Hi Guys I have 2012 mini countryman cooper s all4 R60 I want to change interior lights and some of outside lights. (park light, fog lights, plates lights) Is it possible to change them without error code, just plug and play? Can I buy those without installing problems? http://www.ebay.com/itm/5-SMD-LED-XE...item1c25f0ee45 http://www.ebay.com/itm/290734636455...S:1123&vxp=mtr
Old Jul 6, 2012 | 05:27 AM
  #110
Koopah's Avatar
Koopah
For CM 2012 owner . I have change license plate bulbs to T10 LED today . No error code...{snip}
Interesting...
Old Jul 6, 2012 | 06:11 AM
  #111
Koopah's Avatar
Koopah
Originally Posted by couper1
...{snip}...I want to change interior lights and some of outside lights. (park light, fog lights, plates lights) Is it possible to change them without error code, just plug and play?
Park (city) lights, fog lights and plate lights have traditionally been among those that are checked at startup. Interior lights, puddle lights, and scuttle lights should be no problem.
I'd just like to comment that there is a wealth of knowledge in this and other threads about LEDs and lamp checks that has been given to us by some very dedicated folks. If you have questions about the use of LEDs, LED types for the various locations, or about which ones require resistors/coding, please search the following threads; I'm sure your answers (and some other "illuminating" information) will be found there:
1. This thread, obviously;
2. LED Switchback Bulbs - Do Not Use;
3. LED Resistors;
4. And, of course, the encyclopedia of NCS Expert and the R60's programmable settings (including lamp checks): Countryman-Specific Coding - R60 Guide.
You will also find some valuable information in the 2nd Generation MINIs::Modifications forum's Electrical thread.
Please understand that as our R60s progress through time, MINI is free to change the behavior of the various control modules' programming by releasing new datens versions (and, perhaps, modified code). Thus, a newly-delivered R60 may "behave" a bit differently (vis-a-vis lamp checks) than an earlier R60. This may be what is happening to Nguyen. However, I am using what I believe to be the latest datens (V.46) and my license plate lamp checks were set to aktiv. Perhaps Nguyen purchased a lamp with a built in load???
FWIW,
Old Jul 6, 2012 | 07:11 AM
  #112
nguyenduylam
Couper1 do not buy the light from second ebayer from China cause I have to return to him . The light he sell u n not gonna use half of it because most of interior use T10 wedge bulbs . I got all interior about 50 cents a piece for all T10. Exterior please check with superlightled.com and get 2011 model cause they did not update for 2012 yet. And I believe they r the same bulbs. I have Hid installed for head light and led for fog, driving light and reverse . They r look fabulous and they all need resistor for error code. Hope it helps
Ldn
Old Jul 6, 2012 | 07:14 AM
  #113
nguyenduylam
Koopah ,
The lamp I got for license plate just a regular T10 wedge . They may update the 2012 model
Old Jul 6, 2012 | 07:44 AM
  #114
couper1's Avatar
couper1
Mine produced in 2011 actually.
I'm from Turkey, can you provide me an ebay link to buy;
Interior bulbs
Park (city) lights
Fog lights
Plate lights
Can these lamps make any harm, or if they gives error code I simply remove.
How hard to install these, where can I find diagrams?
Old Jul 6, 2012 | 08:03 AM
  #115
nguyenduylam
Hidguy.com or superlightled.com for info. They even sell resistor for installation . Look for item 160834608428 right now on eBay.com. U can use it for your interior. Good luck
Old Jul 8, 2012 | 01:06 PM
  #116
couper1's Avatar
couper1
Hi
I ordered them thank you.
Can you supply link for Park (city) lights?
How can I disassembly, is there any how to or diagrams?
Old Jul 9, 2012 | 07:39 AM
  #117
Koopah's Avatar
Koopah
Hi
Assuming that you have access to the internet and know how to use one of the many search engines, check the first post in this thread for the lamp designations for the city lights and then search the internet for that bulb type. Superbrightleds is a source for LEDs as has been mentioned in the thread before.
Your Countryman manual has instructions for accessing the city light lamps.
Old Jul 18, 2012 | 03:00 PM
  #118
nguyenduylam
Change Fog led and moisture got into lamp housing ( fog light area only ) . Anybody has any idea ?? Maybe bad led lamp ??
Old Jul 18, 2012 | 03:38 PM
  #119
countryman-s's Avatar
countryman-s
that sound like what has happened.
Old Jul 18, 2012 | 03:46 PM
  #120
countryman-s
sounds like the seal on the back was not re-installed correct. if i remember there is a rubber boot and a screw on cap. the cap will go on even if you did not align it correctly. make sure you align all three tabs on the cap with the correct size slots. they are all three different sizes, so make sure you put it back on correct. only thing else i can think of is a crack on the front.
Old Jul 21, 2012 | 09:57 AM
  #121
hooray4kurt's Avatar
hooray4kurt
Is there anyone that can help me code out some of my LEDs? I live in the bay area california near SF... message me! Thanks in advance!
Old Jul 27, 2012 | 11:14 PM
  #122
hooray4kurt
So I decided to screw the damn NCS (no one with experience with me) and went all canbus on the outside and I'm really happy with my bulbs. The things are built like tanks... Interior brightness is INSANE right now... No error codes as of now... Been a few weeks... but anyone else experiencing the front map LEDs not turning truly off? They are always on (even with the car shut off) in a very very dim mode...
Old Jul 27, 2012 | 11:19 PM
  #123
DrZ's Avatar
DrZ
To be pedantic, there is no "CANbus" involved in those LEDs; just load resistors.
Old Jul 27, 2012 | 11:41 PM
  #124
hooray4kurt
I accept correction... I'm just happy they work!
Old Jul 28, 2012 | 05:50 AM
  #125
countryman-s
That's what I decided to do with NCS also. I looked into it deeply but honestly scared to pull the trigger and mess something up on a brand new car. I have not done LEDs on the map lights yet. Do they even require resistors for sure?
