Electrical LED Bulbs
Old Jul 28, 2012 | 07:24 AM
  #126
hooray4kurt's Avatar
hooray4kurt
I'm pretty sure a small amount of current is constantly passed through the bulbs so a resistor or. Another set of canbus bulbs may eliminate the dimness... I haven't yet decided what to do... But they don't require a resistor to prevent an error message..
Old Jul 28, 2012 | 07:26 AM
  #127
hooray4kurt
And by the way the front map lights have 6 torx screws to contend with... 2 different sizes... So prepare!
Old Jul 28, 2012 | 07:33 AM
  #128
DKIKK77's Avatar
DKIKK77
The 2 small covers for the map lights pop off without taking everything apart. It's not necessary to remove the 4 screws on the back. I used needle nose pliers to pull the original map lights out and just pushed the new LEDs in.
Old Jul 28, 2012 | 11:31 AM
  #129
hooray4kurt
I, being of very unsound body and mind most of the time, tried that and I was scared to death of breaking the bulb.. Someone also suggested using rubber tubing... That would probably work as well... AnyOne else getting the dim front map lights?
Old Aug 30, 2012 | 03:36 AM
  #130
couper1's Avatar
couper1
Hi
I managed to change doors bulbs.
But I can't remove the shelf on the roof and map light.
Any instructions?
Old Aug 30, 2012 | 05:01 AM
  #131
iriedevil32's Avatar
iriedevil32
Originally Posted by GeoffreyM
Puddles and side scuttles do not have bulb checks. Rule of thumb is if it faces forward or back it has a check. Side or down does not.
Geoffrey, I love those 4-series grill fog lights. I gotta ask if it is possible to get those installed on mine!
Old Aug 30, 2012 | 08:59 AM
  #132
pjdaustin's Avatar
pjdaustin
Originally Posted by couper1
Hi
Any instructions?
Next, by the shelf on the top do you mean the dome light lens ? IF so, it snaps on and off - there are 2 or 4 perforations on the edge of the lens. JUst push lens forward or backward with minimal pressure and pull down. If it does not move try it the other way using only your hand and "MINIMAL" pressure. It should come off easy using just 1 hand so don't get carried away with trying to remove it.
As for the map light, just use both hands and slide the map light bezel sideways toward each respective door. Takes a little strength, but it will slide/snap out. Slide/snap inward to replace. Wrap tape like an ice cream cone around the old bulbs to remove. Replace LEDS observing polarity.
Old Aug 30, 2012 | 10:21 AM
  #133
couper1's Avatar
couper1
Just front map lights left.
I can not remove them...
Any help?
Old Sep 2, 2012 | 12:17 PM
  #134
walk0080's Avatar
walk0080
Old Sep 2, 2012 | 12:32 PM
  #135
pjdaustin's Avatar
pjdaustin
Originally Posted by walk0080
Interior does not have bulb check. I just used regular LEDs from V-LEDS.com for map lights, etc.
Only issue is what to replace the visor mirror bulbs with??? I may just have to take one of mine apart to see.
Map LEDS do not require resistors. Any light on the inside or the sides of the car DO NOT require resistors. Those in the front and rear of the car MUST bereplaced with resistor laden LEDS. As for the vanity light they are ugly, but people have enough problems with them so I just going to leave them alone as the visors are quite fragile and problem plagued as per another thread.
Old Sep 3, 2012 | 05:58 AM
  #136
Koopah's Avatar
Koopah
Originally Posted by pjdaustin
{snip}...Those in the front and rear of the car MUST bereplaced with resistor laden LEDS...{snip}
OR...regular LEDs can be used if you (or someone) codes-out the lamp checks using NCS Expert. Since load resistors get quite hot, I'm not sure of the long term viability of an LED unit in such close proximity to such a heat source. Smarter folks than I can probably "shed more light" on the issue.
Old Sep 3, 2012 | 09:27 AM
  #137
pjdaustin's Avatar
pjdaustin
Excellent point. Cheaper resistors do not hold up well in hot unventilated applications. If anyone knows more about using the NCS expert to code out the lamp check please tell us more. I would not replace with an LED if it still required a resistor as that removes part of the reason (reduced energy consumption) to replace it anyway.
Old Sep 4, 2012 | 04:48 AM
  #138
Koopah's Avatar
Koopah
{snip}...If anyone knows more about using the NCS expert to code out the lamp check please tell us more...{snip}
Everything you could possibly want to know about using NCS Expert for settings changes on the R60 is contained in the following thread: Modifications::Electrical::Countryman-Specific Coding - R60 Guide. Theta and several other luminaries have assembled quite a thread and have provided guides, links, and support for the NCS Expert community. Start with the first post (a terrific introduction) and work your way forward. The software is free and requires an up to date datens file that gets posted to the thread fairly soon after it hits the MINI dealers. You will also need to purchase a cable that connects a USB port on your Windows PC (or Mac with a Windows virtual machine) to the OBD-II port on the R60.
Note that NCS Expert is not limited to turning off lamp checks. You can make settings changes for one-touch (actually, two-touch) auto sunroof open/close, keyfob open/close of whole car, weather radio activation, killing the key gong, etc.
Have fun!
Old Sep 4, 2012 | 06:44 AM
  #139
GeoffreyM's Avatar
GeoffreyM
I found it easier to remove the whole module. Then you can do it from the back with no risk of breakage. YOu can remove the whole switch/light/microphone assembly quite easily with torx bits. Then you unplug the wiring harness and can move to a workbench or your lap and have it all done fairly quickly and then snap it all back into place.
Old Sep 4, 2012 | 06:53 AM
  #140
xenor's Avatar
xenor
I removed the whole module. I did have a little panic attack when the rubber gasket flew apart spraying the little switch parts everywhere. Luckily it's an easy fix, but something to keep in mind after removing the last torx screws. It's a much safer bet to change the bulbs from the top, like it was designed.
I used 4 surface mount LED 194 bulbs. Not terrible bright, but they work.
I also changed the scuttle lights to 1.5w amber LEDs, and coded out the bulb check on the license plate lights to use 4 SMD downward facing PCB 194 bulbs.
Old Sep 5, 2012 | 06:02 AM
  #141
Koopah's Avatar
Koopah
Originally Posted by xenor
{snip}...coded out the bulb check on the license plate lights to use 4 SMD downward facing PCB 194 bulbs.
The nice thing about changing the license plate lights to high power 194 LEDs is the illumination on the ground behind the car. We were in a restaurant parking lot the other night and I lost my (precious) USB drive. There was enough light cast from the license plate LEDs for me to spot it on the ground before my foot "compacted" it! Think of them as rear "puddle lights".
Speaking of that, I'm surprised that there isn't a light on the hatch so that it illuminates things from overhead when open...hmmmm...
FWIW,
Old Sep 5, 2012 | 06:24 AM
  #142
xenor's Avatar
xenor
I did the puddle lights with the same LEDs...they are flat PCBs with 4 high power leds that point straight down. They really light up the ground much more than the incandescent 194 bulbs.
I did have to lightly use the dremel to sand the edges of the PCB for the 'bulb' for the license plate light holders.
Old Sep 8, 2012 | 03:09 PM
  #143
xenor's Avatar
xenor
Old Sep 8, 2012 | 03:40 PM
  #144
pjdaustin's Avatar
pjdaustin
Cool. IF you or anyone can give me the 411 on coding out the license plate bulb check and the gong I would be much obliged. I hate my gong. Thanks. If your in Austin and will do this for me I will make it up to you. I have to have shoulder surgery again soon and will be an unable to do anything for after Sept 21st for a while. Thanks in advance. Peter
Old Sep 8, 2012 | 04:41 PM
  #145
xenor's Avatar
xenor
Take a look at the Countryman Specific Coding thread. The entries that have to me set are listed there. You will need a cable (eBay also listed in the thread) and a copy of Windows XP.
Old Sep 9, 2012 | 09:58 AM
  #146
Rudeman422's Avatar
Rudeman422
Can anyone who has installed the 1156-R45-T Red SMD led bulbs from Superbrightleds.com tell me if they are brighter than the stock incandescent bulbs? I would like to tint the taillights on my Countryman, and I just want to get something a little brighter in there to offset darkening the lens. Are these worth the $25 each?
Old Sep 11, 2012 | 09:30 PM
  #147
Rudeman422's Avatar
Rudeman422
Anybody...?
Old Sep 12, 2012 | 04:13 AM
  #148
xenor's Avatar
xenor
Not I.
Old Sep 12, 2012 | 09:32 AM
  #149
GeoffreyM's Avatar
GeoffreyM
Yes they are brighter and yes they are worth it.
Old Sep 12, 2012 | 11:49 AM
  #150
Rudeman422's Avatar
Rudeman422
Thank you GeoffreyM!
