Electrical Which wire in '04 Overhead Clock Console?
Old Feb 9, 2008 | 06:11 PM
adamslye's Avatar
adamslye
Apologies if this has been covered elsewhere, but I've scoured and couldn't find it. I'm all ready to attach the 12v connector into one of the three wires in my '04 MC's overhead clock console to hardwire a Valentine 1 detector, but which wire is the 12v line? All three are striped: I've got a brown/black (I'm thinking ground?), a red/green and a red/either grey or purple. I don't have a multimeter, anyone got a hot tip? Thanks!
Old Feb 9, 2008 | 06:49 PM
Crashton's Avatar
Crashton
Welcome to NAM
You've asked your question in the wrong forum. You need to be in the 1st generation forum. I'll ask a moderator to move your post.
Old Feb 9, 2008 | 07:55 PM
Krut's Avatar
Krut
moved
Old Feb 14, 2008 | 07:49 PM
chpsk8's Avatar
chpsk8
Anyone know? I'm looking for some power up there also...
Old Feb 15, 2008 | 08:08 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
There are three wires on the clock. One has 12 volts full time, another has a variable voltage used for the display (varying with brightness), the last is ground. While it's possible to tap off of the power at the clock, it will not go on and off with the ignition. You cannot operate anything from the display wire, the voltage is pulsewidth modulated (a square wave).
Old Feb 15, 2008 | 09:27 AM
Eric_Rowland's Avatar
Eric_Rowland
FWIW, it's easy enough to run an add-a-circuit from the fuse box and run the wire up the side of the dash and tuck it in behind the A pillar and headliner. Probably took longer to type that then it did to run wire.
Old Feb 15, 2008 | 10:23 AM
mini-rolls's Avatar
mini-rolls
I agree with Eric. Run the wire to the A-Pillar then under the door seal to the fuse box and use an add-a-fuse.
Old Feb 15, 2008 | 11:50 PM
Ancient Mariner's Avatar
Ancient Mariner
Yeah, wire tucked in behind the A-pillar (used a plastic spoon handle). Totally wired in 5 minutes. Out of sight, clean looking install. And the velcro thing to stick it to the roof liner is awesome.
Filmy
15
Jun 6, 2023 06:27 AM
minimofo
Sep 30, 2015 12:26 AM
patsum
Sep 15, 2015 09:14 PM
Sc00terbum
Sep 11, 2015 09:07 AM
Filmy
Sep 7, 2015 08:27 PM
