Electrical Scan Gauge II
Old Aug 20, 2007 | 11:32 AM
MaxMini81's Avatar
MaxMini81
Wanderer
Scan Gauge II
I just ordered a scan guage 2 and i was curious where you guys have situated it, and what 4 functions you use it to display
Old Aug 20, 2007 | 11:37 AM
Loony2N's Avatar
Loony2N
I mounted mine in the "cubby" at the bottom of the center stack (R56). It's mounted to the bottom of the toggle switch bezzel, so I can still use the cubby, somewhat. It's a perfect fit and angled up perfectly. I display water temp, MAP, gallons per hour and volts. I was using the blue background, which sort of matched my pacific blue interior pieces, but it was too hard to see. I switched to the orange backlight, which matches the dash lighting.
Old Aug 20, 2007 | 12:28 PM
BBCooper's Avatar
BBCooper
Check out this thread..
link..
I have one of these units and use it a lot... I was helping to discuss the topics you were looking for in that thread...
Enjoy
Old Aug 20, 2007 | 02:22 PM
kapps's Avatar
kapps
I plan on getting one myself. They are a handy tool for a good price.
Old Aug 20, 2007 | 07:06 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I just made a simple bracket for in front of the tach...
...I display IATs, coolant temp, volts and switch back and forth between timing and MAP.
I also have a air box/filter temp gauge mounted on the dash in the empty space just to the right of the vent.
Old Aug 24, 2007 | 12:01 PM
jwardell's Avatar
jwardell
I keep mine on the top-left of the dash, and my speed is now much closer to my view of the road (and much more accurate).
Here's my writeup
Old Aug 24, 2007 | 05:07 PM
NMgokart's Avatar
NMgokart
Nice setup, Josh! That's where mine will be living, once it gets here.
Old Aug 25, 2007 | 07:10 PM
ekim's Avatar
ekim
Here's my writeup
Ditto....
Old Aug 25, 2007 | 09:49 PM
MaxMini81's Avatar
MaxMini81
Wanderer
MAP on ScanGuage.
Quick question... If bar is 14.3 PSI, and the atmosphere is naturally 1 Bar, why would the manifold absoute pressure ever drop below this? I dont need a lot of science, I just wanna make sure nothings wrong.
Thanks for your responses too, BTW. I put mine on the dash face to the left of the steering column and display MAP, Intake temp, Water Temp, & Volts
Old Aug 26, 2007 | 01:30 AM
JSWMCS's Avatar
JSWMCS
1 Bar= 14.7Psi
it's called vacuume!
Old Aug 26, 2007 | 08:24 AM
kapps's Avatar
kapps
When sitting at idle, cruising, or other light throttle applications, the supercharger is in bypass mode (so it's not making boost). The throttlebody is barely open and the pistons are sucking air into the combustion chamber. The intake manifold is under vacuum, thus, causing the MAP to read lower than atmospheric pressure.
Old Aug 26, 2007 | 03:14 PM
miniconcarne's Avatar
miniconcarne
Did a little searching and the price for the Scangauge II is about the same everywhere. Where, if you don't mind, did you guys/girls order your's? Are they realy this easy to use? Had considered new gauges and my own scan tool but this seems better!?!
Old Aug 26, 2007 | 03:42 PM
MaxMini81's Avatar
MaxMini81
Wanderer
I orderd my scan guage direct from Linear Logic at scanguage.com. They actually covere shipping s well. Its is a simple plug and play gadget. It figures almost evrything out by itself, all you need to do is enter engine and fuel tank size, and specify farenheight or celcius/miles or km. I love it. The setup is very user friendly and you basically have access to 14 guages. If you look at the cost of four autometer (my preference) gauges, and the bezel, or other means of mounting them, this is way more cost ffective. I mounted mine with 3M mounting tape to my dash and have it displaying Volts, Intake Air Temp, Water Temp, and Manifold Absolute Pressure - which is basically Boost plus the 14.3 psi of the atmosphere.
Old Aug 26, 2007 | 04:30 PM
miniconcarne
Fantastic, thank you! Plus, no running lines or electrics .
Old Aug 26, 2007 | 04:45 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Yeah, all you have is the OBD 2 Port, I ran the line down through the steering column opening, bundled it with a zip tie under the dash, and plugged it in... actually, ill go take a pic gimme a few. Also you can adjust the color of the display. I'm gonna wait til its darked so you can actually see the backlight. mine matches the guage light color perfectly
Old Aug 26, 2007 | 04:56 PM
miniconcarne
It gets better??
Old Aug 27, 2007 | 12:14 PM
FL_blue_MINI's Avatar
FL_blue_MINI
you all are a bad infulence(sp?)!!!!! I just ordered one after telling my self i didn't need it. but what the heck.... its a cool gadget!
Old Aug 27, 2007 | 05:07 PM
NMgokart's Avatar
NMgokart
So, after the first full day with the Scangauge in my car, I have a question. Have any of you who have had one for a while had an issue with the display going dim (almost invisible) when the car interior is very hot? I started mine up after work today (97F) and while it displayed normally at first, it went invisible on me for about 15 minutes. I'm guessing the heat was the problem, but not sure.
Old Aug 28, 2007 | 06:00 AM
Loony2N's Avatar
Loony2N
I haven't had that problem, but it is a known problem with LCD displays, when temperatures are extreme (hot ot cold). Have you had this problem: Every so often, when I start the car, the gauge reverts back to the main screen, instead of the gauge screen I use. However, when I hit the gauge button, it goes back to my screen, with the display choices I set intact. Only happens occasionally. Any idea why?
Old Aug 28, 2007 | 06:43 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
I have mine mounted in the same place as above and was a bit worried about the temperature having an effect on the LCD display. Luckily I have had very few problems. So far this summer there have been a few times were it was a bit hard to read, light was dim, same as you described. But as the cabin came back to a normal temp it became normal again. I think that temp and direct sunlight have do have an effect on the screen. But as far as it being invisible, I don't know. They touch upon it on page 13 of the manual.
http://www.scangauge.com/support/pdfs/SGIIManual.pdf
Oh, if it matters I am runing m display with this config:
Volts--------fWT
RPM----------fIA
Old Aug 28, 2007 | 06:47 AM
Loony2N's Avatar
Loony2N
Volts--------fWT
RPM----------fIA
Just out of curiosity, is there a noticeable correlation between your FIA and outside temp, as measured on your MINI thermometer? I run FWT, Volts, MAP & GPH.
Old Aug 28, 2007 | 07:11 AM
golden_child
Yup. Mainly on cooler days like we had last week the temps IA temps stayed down ~87-92 degrees. But on these really hot days they have been closer to ~98-100 degrees. My water temps seem to be pretty consistant.
My main concern if for water temps, since we hav a dummy temp guage.
Old Aug 28, 2007 | 07:14 AM
Loony2N's Avatar
Loony2N
We don't have a temp gauge at all!
Old Aug 28, 2007 | 09:47 AM
FL_blue_MINI
what did you all program for the fuel tank?
Old Aug 28, 2007 | 11:18 AM
Loony2N's Avatar
Loony2N
What do you mean? I just entered the number of gallons per the pump, as the instructions stated.
