Electrical Scan Gauge II
Old Aug 28, 2007 | 12:13 PM
  #26
supercliff's Avatar
supercliff
is it hard to install?
Old Aug 28, 2007 | 12:18 PM
  #27
Loony2N's Avatar
Loony2N
Nope. Just plugs into the OBDC socket, which is under the dash.
Old Aug 28, 2007 | 12:20 PM
  #28
supercliff's Avatar
supercliff
nuts. There goes my excuse not to get one. The nice thing is that even though I'll keep this mounted in my Mini cooper, I can pull it out and use the code reader to check the status of codes in my other cars.....
Old Aug 28, 2007 | 01:16 PM
  #29
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Careful...The velcro can get a little tricky.
Old Aug 28, 2007 | 03:33 PM
  #30
NMgokart's Avatar
NMgokart
After the second day with the same dimness, I'm going to go with it being the nature of LCD displays. It comes back as the cabin cools down from the A/C.
I have speed showing as one of my gauge preferences and it seems to match the OEM speedo in the 50-60 MPH range, but gets way lower than OEM above that. Like oem will show ~75 and the gauge will show 70. Seems to be more difference as the speed climbs. Is the OEM that far off?
Old Aug 28, 2007 | 03:44 PM
  #31
FL_blue_MINI's Avatar
FL_blue_MINI
Originally Posted by LynnEl
What do you mean? I just entered the number of gallons per the pump, as the instructions stated.
I thought i read that it needs to be programmed for the total gallons. and every one seems to be able to get a different amount in.
Old Aug 29, 2007 | 12:43 AM
  #32
SayGoodbye's Avatar
SayGoodbye
Old Aug 29, 2007 | 12:34 PM
  #33
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
So now that all you guys and gals have ScanGauges, you have no excuse for not posting your approaches (difference between IAT and ambient temperatures.) We should start a logging thread. Particularly interested in the following data:
1. Car and mods
2. Altitude
3. Driving conditions (highway, traffic, rain, etc)
4. Gear and rpm
5. Any two of the following: IAT, ambient, approach
thanks!
Old Aug 29, 2007 | 12:52 PM
  #34
Loony2N's Avatar
Loony2N
Yeah, after a fill-up, you enter the actual gallons put in for the gauge to calculate fuel useages properly. First fill-up, you just enter "done." Next fill-up, you enter the gallons actually put in and then enter "done." A correction percentage is calculated, which reflects the difference between what the OBDC says and what the fill-up actually showed. If you want, you can do this for several fill-ups and then enter the average adjustment factor.
Old Aug 29, 2007 | 01:18 PM
  #35
FL_blue_MINI
OH. I got it. Thanks!
Old Aug 29, 2007 | 06:30 PM
  #36
mistro's Avatar
mistro
I will be glad to do this but with my Brockway I can measure IAT and Exhaust too!
Old Aug 30, 2007 | 11:40 AM
  #37
FL_blue_MINI
i just got mine in the mail!!! I can 't wait to put it in!
Old Aug 31, 2007 | 07:16 AM
  #38
Loony2N's Avatar
Loony2N
I just did a fuel calculation set-up on my Scangauge this morning. Gauge before adjustment indicated fule consumption of 12.5 gallons. Pump (using same pump at same fill rate as last fill-up) showed 12.3 gallons. I'd say that's a pretty accurate measurement.
Old Sep 3, 2007 | 07:52 PM
  #39
jwardell's Avatar
jwardell
1. Car and mods
2. Altitude
4. Gear and rpm
thanks!
I'd be more interested in what people's fuel and speed correction factors are. My fuel is at 14.1%, speed -2%, though my tires are almost done so it is more extreme than usual.
Old Oct 2, 2007 | 09:55 PM
  #40
SayGoodbye's Avatar
SayGoodbye
For now...just installed it...
1. 04' MCS - `15% pulley - Alta CAI - Alta Classic IC w/ Nitrominis rubber flap mod - JCW 380cc Injectors - NGK 8IEX Plugs - Mynes custom dyno tune - M7 Extreme Scoop
2. about 1100'
3. Local road - 50mph - steady for 2 miles
4. 6th gear - about 2000K RPM
5. Ambient = 89, IAT = 101
More Scanguage fun tomorrow
Old Oct 16, 2007 | 04:00 AM
  #41
markldriskill's Avatar
markldriskill
Okay, so does the connector for your SGII not get in the way, at least somewhat, of your left foot?
I found long ago that even if the OBDII connector cover is just off and hanging down, my left foot will tap it almost every time I move my foot. I just got an Auterra "Dyno-Scan for Palm OS" (plugs into the OBDII connector just as the ScanGauge II does) and I can't see how I can drive around comfortably with it plugged in to monitor live data unless I rearrange the OBDII connector so that the connector/cable does not extend so low under the dash. I have decided that with a Euro/parcel shelf installed, I might be able to move the connector so that it points to the right instead of down. Anyone else had similar problem or concern? What are things to watch out for in moving the OEM connector?
Are my feet just too big?
Thanks.
Old Oct 16, 2007 | 08:27 PM
  #42
markldriskill
Hello! Hello ello lo o
Echo! Echo cho ho o
Anybody home?
body home?
dy home?
home?
Old Oct 16, 2007 | 08:30 PM
  #43
jwardell's Avatar
jwardell
Yes your feet are too big
I find if anything I hit the door that hangs down just slightly, about once a day. Not a big deal, and I could just remove that ODB door if I wanted.
Old Oct 17, 2007 | 09:09 AM
  #44
markldriskill
Thanks!
When the panel is open, it appears that about the only thing inside is the OBDII connector plug. Seems that it should come apart some way and move without cutting and such, unless it is glued in place at the plant. I'm afraid to pry at it or anything for fear of breaking the stupid thing.
Old Feb 12, 2008 | 11:58 AM
  #45
pepegrande008's Avatar
pepegrande008
Originally Posted by PARTSMAN
I just made a simple bracket for in front of the tach...
...I display IATs, coolant temp, volts and switch back and forth between timing and MAP.
I also have a air box/filter temp gauge mounted on the dash in the empty space just to the right of the vent.
Just ordered mine, thanks Waymotorsports
Cant wait to put mine in. Is there any that i can get some better pics of your mount partsman?
Old Feb 12, 2008 | 06:34 PM
  #46
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Just so everyone knows I'm doing a group buy on the Scan Gauge for $150 shipped. Email or call to get one.
WAY
317.201.8670
info@waymotorworks.com
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Feb 16, 2008 | 04:23 PM
  #47
chpsk8's Avatar
chpsk8
WAY
317.201.8670
You should put up a post in the Vendor Group Buy section so you get some more visibility.
Great price btw!
PsychoRallye
21
Feb 17, 2019 06:08 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
