Electrical 3rd. Brake light pulsar
Old Jan 8, 2008 | 11:12 AM
  #76
giantjoe's Avatar
giantjoe
These things are the worst types of splicers on the market. Sure you don't have to cut the wire, but they're just plain unsafe to use.
Old Jan 8, 2008 | 11:32 AM
  #77
lacning74's Avatar
lacning74
Fire hazard or would the fuse blow first? Maybe I need to install a smoke detector to my headliner. Guess that's really not funny.
Now that I'm happy with my pulser location, I'll get around to soldering and heat shrinking the connections.
Old Jan 8, 2008 | 11:50 AM
  #78
giantjoe's Avatar
giantjoe
Well depending on the rated current on the fuse... My wife burned her foot on one of those on our old Hyundai. It could have burned the car up.
Old Mar 14, 2008 | 02:52 PM
  #79
basil49's Avatar
basil49
brakelight pulser with small mod
Originally Posted by Coffeeman
I got the 4 pulse version...installation was a little tricky. There is not room on the R56 to mount the circuit board next to the light. I extended the supply cable, and mounted it below the screw on the left side of the rear hatch. Took about 30 minutes total.
I bought the pulser for my '07 MCS and found the same issues with space inside the housing ... so I chose to remove the screw-connect terminal on the edge of the pulser that goes to the LEDs and soldered in a discarded cordless-phone-battery-harness in its place.
This little trick gave me a little extra wire to maneuver with, and allowed me to lay the pulser-board FLAT against the LED bar for most of the length of the pulser, which made for a much better fit inside the housing -- just make sure you match the harness polarity back to the original configuration.
Old Apr 8, 2008 | 11:19 AM
  #80
DaveTinNY's Avatar
DaveTinNY
I put the Pulsar (4) in while on my lunch hour at work. I like it. Really makes the braking stand out. Cheap but good looking modification with safety in mind.
Old Oct 16, 2009 | 09:08 PM
  #81
Dwight Walhood's Avatar
Dwight Walhood
Center Brake Pulsar Install Thanks!!
Thank you sooo much "JMike". Your post on 9-17-07 saved my sanity after installing the pulsar today. Couldn't get it to fit under the molding no matter what I tried. THEN I looked at this thread and there was the answer. Fit right in and so did the molding! BTW, brake pulsars were first used on motorcycles in the '70's. They really work and if they "annoy" the car behind, tough! They're supposed to make that tail-gating troglodyte pay attention.
Old Nov 7, 2009 | 12:41 PM
  #82
MiniKar's Avatar
MiniKar
Try Web Electric .com Its a 4 pulse
Old Dec 30, 2009 | 11:20 AM
  #83
trwxxa's Avatar
trwxxa
I just installed two this morning -- one each in my and my better-half's MINIs. Took about an hour total time, with a little time spent soldering the supplied wire extensions to the factory connector. I found that the flasher unit fits inside the trim piece a little easier with the wires lengthened.
The flashers are working great. Can't wait to see if I'm tailgated less in traffic.
Old Dec 31, 2009 | 09:37 PM
  #84
JMike's Avatar
JMike
A little late to say your welcome but, your welcome...
Mike...
Old May 12, 2012 | 04:31 PM
  #85
AAONMS's Avatar
AAONMS
Another satisfied customer of JMike’s 09/17/07 post.
Old May 12, 2012 | 05:10 PM
  #86
JoanieB's Avatar
JoanieB
We installed the GOMINIGO pulsar after going on a club run. It was really noticeable, being in a long line of MINIs, you could see which ones had it and which didn't. I have definitely noticed that the car behind me is more careful now. Here on the coast, people cross the street randomly and you are always stopping at short notice and unexpectedly!!
Old Nov 25, 2012 | 11:14 AM
  #87
gr8ful's Avatar
gr8ful
Anyone installed it on a R57? The Cabrio is a different light and location.
Old Jan 4, 2013 | 06:12 PM
  #88
gr8ful's Avatar
gr8ful
Still need help installing this on my 11 R 57. Which color wire go into the pulse unit?
I have a brown and a yellow/ black. If I connect one way I get nothing and if I connect the other way normal operation ( no flash )
Help
Old Dec 6, 2014 | 05:28 PM
  #89
Systemlord's Avatar
Systemlord
I installed my brake pulsar kit today that I got a Way Motor Works, very easy. Sorry for the fuzzy picture.
Attached Thumbnails 3rd. Brake light pulsar-20141206_152102-1-.jpg   3rd. Brake light pulsar-20141206_152039-1-.jpg
theblackfalcon
Oct 11, 2015 09:49 AM
Powershift
Aug 16, 2015 05:14 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
