Eastern Iowa MINIs Eastern Iowa MINI enthusiasts group
EIM Wintertime Chat Room
Old Mar 10, 2010 | 11:58 AM
  #351
Gil-galad's Avatar
Gil-galad
Originally Posted by Smokin' Jo
I've got a noise/rattle type when i'm in neutral. (similar to cold start death rattle) this happens after the car is warmed up. when i push in the clutch it goes away. any ideas anyone? i'm due for servicing in 2400 miles but might take it in once it gets below 2k.
I didn't get a whole lot of concrete diagnoses searching the various forums, but it seems the most likely suspects are: (1) worn out throw-out bearing; or (2) broken spring on the dual-mass flywheel.
If you're still under 48K miles I would think that it would be a warranted item.
Old Mar 10, 2010 | 05:13 PM
  #352
Miah34's Avatar
Miah34
does this apply:
The customer complains of a rattle noise from the engine during cold start-up. The rattle noise will occur more frequently when driving short distances. The rattle noise will increase with RPM, but will dissipate after approximately three seconds if left to idle. Increasing the RPM slightly will increase the intensity, but will also shorten the duration of the rattle noise. The noise is more prevalent when the outside temperature is approximately 15°Celsius or below.
If not, the thow out bearing sounds like and accurate diag with out hearing it or seeing it.
have head of that before aswell
Old Mar 11, 2010 | 06:59 AM
  #353
Smokin' Jo's Avatar
Smokin' Jo
I will most definitely bring it up when I take it in for servicing soon. I have brought it up before but they just blow it off with some lame technical or not so technical jargon. This will be last servicing under warranty and to have my MINI running like it just came off the showroom floor is not asking too much is it? Ofcourse not. But will Patrick MINI see it that way?
Thanks for he info guys.
Old Mar 11, 2010 | 09:01 AM
  #354
Gil-galad's Avatar
Gil-galad
Just make sure your specific complaint is documented on the service invoice. That way, if they blow you off and later (post-warranty) the noise evolves into a larger issue you'll have evidence that the problem should have been taken care of during the warranty period -- when you first complained about it.
Old Mar 12, 2010 | 03:23 AM
  #355
Miah34's Avatar
Miah34
I know that is how we do things at PMC. Usually if it is noted that there was an issue with something and we can not get it fixed or can not duplicate it under warranty and it was noted, we can do a "goodwill" post warranty and still cover it.
Old Mar 13, 2010 | 06:20 PM
  #356
Gil-galad's Avatar
Gil-galad
This thread goes dormant in less than a week...
Old Mar 13, 2010 | 07:10 PM
  #357
Gil-galad's Avatar
Gil-galad
Put the summer shoes on this evening. Hope I didn't jinx the weather by doing so...
Shadowfax needed a bath real bad, so I decided to stop off at the power wash to remove the worst of the gunk before coming home and doing the bulk of it in the garage. I ended up spraying my "cyclops" LED third brake light too closely with the high pressure stream; when I got home I discovered it had pools of soapy water in it and the lens was fogging up. Fortunately the thing is pretty easy to remove and disassemble, so I washed out the lens under the sink and I used my air compressor to blow out all of the moisture. Let it dry, put it back together, reinstalled it, and it works fine. Disaster averted.
OBTW, for anyone who uses iGoogle as their Google interface I created a nifty theme using the lineup pic from our meet in Balltown last November. Just click on the "change theme" link in the upper right and do a search on "Iowa MINI Cooper" and you'll find it.
Old Mar 14, 2010 | 04:45 AM
  #358
deanman's Avatar
deanman
Originally Posted by Gil-galad
I created a nifty theme using the lineup pic from our meet in Balltown last November..
That is the coolest thing! You should to win a prize for that. Excellent!
Old Mar 14, 2010 | 06:31 AM
  #359
05MINI's Avatar
05MINI
I agree!
Old Mar 14, 2010 | 08:47 PM
  #360
Smokin' Jo's Avatar
Smokin' Jo
That's awesome Gary
Old Mar 14, 2010 | 08:53 PM
  #361
Smokin' Jo's Avatar
Smokin' Jo
Originally Posted by Miah34
does this apply:
I'll try to have you guys take a listen at the M&E this weekend.
Old Mar 16, 2010 | 06:41 AM
  #362
MariaChick's Avatar
MariaChick
Going Mini shopping in Chicago
Old Mar 16, 2010 | 06:50 AM
  #363
05MINI's Avatar
05MINI
Saying "have fun" would just be redundant!
Old Mar 16, 2010 | 07:25 AM
  #364
D3m0N's Avatar
D3m0N
Replacement to current one or another in the stable?
Old Mar 16, 2010 | 07:39 AM
  #365
MariaChick's Avatar
MariaChick
This one is Maria's so yes to the two Mini, Charlee needs a friend
Old Mar 16, 2010 | 07:46 AM
  #366
Gil-galad's Avatar
Gil-galad
Congrats! Exciting!
Old Mar 16, 2010 | 08:23 AM
  #367
deanman's Avatar
deanman
Why?????????? What's wrong with Charlee? Did I miss something (again)?
I want to go MINI shopping, too.
Old Mar 16, 2010 | 09:16 AM
  #368
R56MINICooper's Avatar
R56MINICooper
Ooooh a second MINI! Too much fun! Naperville has a really good selection on hand at BillJacobs. Go see Rachel and tell her I said hi!
Old Mar 16, 2010 | 10:52 AM
  #369
deanman's Avatar
deanman
MINI Article
Interesting MINI article in the Wall Street Journal.
http://magazine.wsj.com/gatherer/beh...small-victory/
Old Mar 16, 2010 | 04:59 PM
  #370
TasmanianBlu's Avatar
TasmanianBlu
MOTOR ON
Will there be a premier appearance at the Granite City?
Old Mar 16, 2010 | 07:12 PM
  #371
MariaChick's Avatar
MariaChick
Were are working on it
Old Mar 18, 2010 | 01:11 PM
  #372
MariaChick's Avatar
MariaChick
No luck shopping today,Rob i did see Walt today gave him a pat on his headlight.Still looking if anyone knows of any give us a holler,
Old Mar 18, 2010 | 01:17 PM
  #373
05MINI's Avatar
05MINI
Are you looking for a red one? Any specifics?
Old Mar 18, 2010 | 02:12 PM
  #374
MariaChick's Avatar
MariaChick
red,yellow, black, S
Old Mar 18, 2010 | 02:25 PM
  #375
05MINI's Avatar
05MINI
http://dubuqueautoplaza.com/Inventor...r=-1&Make=MINI
There is a black one at Dan Kruse in Dubuque. He has been there a while. The dealership is right across the street from our Dubuque office. I think he needs a good home!
