Drivetrain Replacing MCS wheels and tires
Old May 20, 2003 | 01:10 PM
mikehome1's Avatar
mikehome1
I need to replace my 17" runflats and wheels,two were damaged.The insurance co.is paying for them or I may take the $ and purchase different tires and wheels.Suggestions for affordable alternatives.I'm not happy with the harsh ride and weak handling of my current setup.I must do something quickly,I'm in Cincinnati.I serched wheels/tires and found only too much info.
Old May 20, 2003 | 01:32 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Get some non-runflats and a can of fix-a-flat. How much was the quote for replacement runflats?
Old May 20, 2003 | 02:39 PM
TwOMINIs's Avatar
TwOMINIs
Do you care to share the details on how the tires and wheels got damaged such that your insurance carrier is covering replacement costs? I would also be interested in what the quote was per tire/wheel?
His, Chile REd all over / Hers, EB UJ on top.
Old May 20, 2003 | 03:48 PM
mini4usa's Avatar
mini4usa
you will be happy with any 16" normal tire. I just replaced my 17" runflats and my
new 16" normal tires are so much softer to ride on. The run flats are a mini USA suck along with mitch PR effort.They talk but provide no manuals or help.
Old May 20, 2003 | 05:31 PM
RonR's Avatar
RonR
mikehome1
Check out the Wheels & Tires forum. A lot of great info !!
Ron
Old May 20, 2003 | 07:59 PM
BlueMCS's Avatar
BlueMCS
Look at Randy's site. He has a nice selection in several different price ranges.
http://www.mini-motorsport.com/suspension.php
Change to light 16" wheels and NON-runflats. Much better ride and the smaller diameter is like adding about 7 hp. Looks a little goofy at first w/o lowering springs but you get used to it quickly. They look great with the springs.
I should have bought the AK Monzas. They are cheap and light and look MUCH better on a car than they do in any picture. With the money you save you can have them powder coated to any color you want (like gunmetal) and make a personal statement for a little more than a grand for the whole package. AK needs a new marketing director.
If its a low milage toy and you don't mind buying a set of tires for the winter, go with the Falken Azenis Sports. They are wild. Otherwise there are a lot of good high performance tires out there. Check out what other people have.
Have fun with it as it is a big ticket item that makes a significant difference in ride, handling and looks if you do it right.
Old May 20, 2003 | 08:14 PM
QBear's Avatar
QBear
I totally concur with BlueMCS. I sold the runflat Pirelli's mounted on the HEAVY S-Lites and replaced em with the Monza wheels and Falken Azenis that Randy sells. I'm totally pleased w/what I got for the $$$ spent. I chose the white ones over the silver, and they are a difficult proposition to keep clean. But, hey, you only go around once and I wanted something that REALLY looked sharp!
A suggestion: whatever wheels you purchase, put a good, heavy coat of wax on em before you install as this will make cleanups much easier.
Old May 21, 2003 | 07:08 AM
sjbartnik's Avatar
sjbartnik
I concur, the Monzas really look great on the car, especially if you have a white roof/mirrors and you go for the white Monzas.
Looks like they will be easier to clean than the v-spoke 16" wheels at any rate!
With my Monzas I got Falken Azenis tires in 215/45R-16 (compared to stock tire size of 195/55R-16) and they really look great. The wider tires give the car a much more aggressive look, and are much grippier than the stock tires too :smile:
EDIT: Here are the white Monzas on my car
_________________
Sean Bartnik
Springfield, MA
2003 MINI Cooper S
Old May 21, 2003 | 07:18 AM
MGCMAN's Avatar
MGCMAN
Silver, white or any other color?
Check out Tire Rack for sizes, I'd recommend a 16" non-runflat if the previous wheels were too harsh.
Old May 22, 2003 | 06:51 PM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
I just had to chime in with a "check out this" link also;
http://www.outmotoring.com/exterior.html
The Team Dynamics Pro Race 1 and the Centerline RMP are very light and look great. Prices on the TD wheels are great, and they offer many color options.
I have the Monzas on my car with 215/45/17's and have not had any wheel well rubbing or anything. Since I live in Ohio (crappy weather), I threw on some Yokohama Avid H4''s.
Hope this helps.
Old May 22, 2003 | 07:19 PM
Grinder's Avatar
Grinder
I've got a set of 18" Centerline RPMs (sorry OutMotoring, i would've bought from you, but I got mine 6 months ago...) and I think they look great. I'm actually having a bit of a finish problem with them now, where they're getting slightly speckled (sorta like a slight pepper color to them), but I think i must've had a bad set of wheels. They're light, and stylish, and compared to SSR or Volk, downright cheap!!
Old May 22, 2003 | 07:58 PM
Casey's Avatar
Casey
>>Hope this helps.
What are the weights on the Pro Race 1 and 2. Are the Pro Race 2s available in 16x7 yet? It makes some mention to it on your site.
Old May 25, 2003 | 04:03 PM
OutMotoring
Vendor - 15 Years
The Pro Race 1 is available now in many finishes. The 15x7 weighs 13.2 lbs. The 17" weighs in at 17lbs. I need to check into the availablility of that wheel in a 16".
The Pro Race 2 - 15x7 weighs in at 12.2lbs, the 16" (not ready for a couple months) should weigh 13.7lbs and the 17" (again, not ready for a couple months) at 15.4lbs.
I spoke with Team Dynamics USA last week and they were running "first offs" of the Pro Race 2 in a 16" and the 17" would be cast in the next few weeks. Since they are manufactured in England, USA will not see any for a few months- after they have worked out any bugs. The weights they supplied are based on prototypes and/or computer generated (PRO-Engineer) models using the proper material weight specs to figure actual production weights based on material wheel volume. Are'nt computers great!!
The Centerline RPM is a great wheel also, but they sure do cost a bundle. They also have lots of nooks and crannies that like to store dirt (especially in white) The design is basically the Pro Race 2 with one more spoke.
Old May 25, 2003 | 04:41 PM
Azwed's Avatar
Azwed
I like the Mirage and the Tornado about how much do they weigh and are they durable enough for normal everyday dirving?
Old May 25, 2003 | 06:56 PM
d-mini-ero's Avatar
d-mini-ero
I dont' autoX...
I just enjoy driving...
These are 17" ROH Adrenalines w/ Toyo Proxes T1S's 215/45-17
Peace,
D
_________________
2002 MCS:PS/B, w/Lapis Int.
Old May 25, 2003 | 08:12 PM
Nobull60's Avatar
Nobull60
:smile:
_________________
My MINI was modified by MINI-Motorsport and Lamin-X Click It
Old May 25, 2003 | 11:27 PM
notpaddyhopkirk's Avatar
notpaddyhopkirk
ASA J5s in 18" with Yoko Proxes 215/35/18s
Old May 25, 2003 | 11:28 PM
notpaddyhopkirk
Oops... make that Parada not Proxes!!
Old May 26, 2003 | 05:49 AM
Mexibeetle's Avatar
Mexibeetle
Check out ebay. They have lots of brand-new take-offs for sale. I got a set of the very light brand new 7-holeys from the base Cooper for only $200.
I don't care for the S-lites (too heavy) but, if you bought another full set of them, you'd already have a couple of spares for the next time you hit those potholes!
Old May 26, 2003 | 08:08 AM
Rocketboy_X's Avatar
Rocketboy_X
Nice rims.. nicer than stock, but without being too flashy...
Rocketboy_X
Old May 26, 2003 | 08:40 AM
6f7's Avatar
6f7
Won't this make your rates go up!? I ruined a wheel a couple weeks ago and just sucked it up and bought a new one. I ordered a new wheel and I had the yoko avs (originally $110) replaced for only $14 at discount tire. It was covered under their standard prorated road hazard.
Old May 27, 2003 | 07:18 PM
HARMINI's Avatar
HARMINI
>>Hope this helps.
Will someone help OUTMOTORING to enable their signature to link to their very nice website?
Old May 28, 2003 | 10:00 AM
orbhot's Avatar
orbhot
Listen to mini4usa, he's got it right. Unless you really like the look of 17s, get a set of 16s. Try to go forged if you can. If you're on a limited budget you may not want to shell out the $$ for forged wheels, but they are stronger, hence they are also usually lighter since less material has to be used.
For tires, go for 205/50s. The Yoko AVS100s are the best for the $, but I don't think they grip as well or are as durable as Dunlop SP5000s. You may want to try the non-runflat version of those.
Old May 31, 2003 | 08:44 PM
Limey's Avatar
Limey
Nice one, I think they look great on my car as well
Old Jun 1, 2003 | 06:44 AM
c615586's Avatar
c615586
Does anyone have pics of the Team Dynamics Mirage on an MCS? Also, do you know how much the 16" wheels weigh?
zdw2082
Oct 5, 2015 09:59 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
nomar116
Aug 10, 2015 11:24 PM
nomar116
Aug 9, 2015 09:42 AM
