Drivetrain Madnees JCW intake fitment???
Old Apr 14, 2007 | 06:53 AM
meb's Avatar
meb
I tried to install the Madness JCW intake this morning - typical replacement of the stock filter is very easy.
However, what holds the smaller diamter end in place? Once the larger end is installed, it fall off with the sligthtest movement. There are not other components that fit the small end...
Old Apr 14, 2007 | 06:59 AM
buzzsaw's Avatar
buzzsaw
The OEM filter has the triangular indent at the non intake end that is secured by a similar shaped screw attachment. Will that work on the Madness filter?
Old Apr 14, 2007 | 08:15 AM
cooldaddy's Avatar
cooldaddy
the Madness filter should have come with a large dia band clamp, as their filter cannot be held into place by using the little plastic OEM thingamajic
Old Apr 14, 2007 | 08:55 AM
goaljnky's Avatar
goaljnky
The trick is not to over tighten the clamp. Per Mini-Madness instructions and my personal experience.
Old Apr 14, 2007 | 08:09 PM
meb's Avatar
meb
Agreed, the large clamp should not be over tightened...or the filter will just pop off. However, there is no way to secure the other end...the piece that fastens the JCW filter at the non intake end does not fit the Madness filter.
One extra small clamp and a screw came with the filter...for what, I don't know as these parts fit nothing.
And, no instructions. The Mini world, unlike others I've experienced, have a rather large number of venders who think we do not need or like instructions.
Old Apr 14, 2007 | 09:08 PM
goaljnky's Avatar
goaljnky
meb, here are the instructions:
http://www.mini-madness.com/pdf_file...structions.pdf
Although there is nothing in it about the extra screw, or the extra clamp.
Old Apr 14, 2007 | 09:48 PM
Fassbinder's Avatar
Fassbinder
I think the screw is intended to plug the vacuum line (not needed if you are still using the "flap". Do not overtighten the clamp. I also placed some self adhesive rubber pads on the filter so the original bracket makes contact.
Old Apr 14, 2007 | 10:29 PM
MINICHEF's Avatar
MINICHEF
why not call and ask george at madness?
i havent installed mine yet but it did come with a cd that is labled instructions.
Old Apr 16, 2007 | 08:25 AM
meb's Avatar
meb
Thanks for the instructions! But no CD...
I have to devise an elegant way to attach the stock JCW thingy at the non-intake end to the Madness filter...it still moves around too much for my taste. I don't want it detaching during a track event...or anywhere else.
...call Madness, yes! But I was trying to cure the problem over the weekend - hey loook!!! It's Monday
Old Apr 16, 2007 | 09:18 AM
YakiMini's Avatar
YakiMini
Were you able to get it taken care of?
Give us a call & we should be able to walk you thru the install.
888-783-6294
Good Luck & Motor On!
Old Apr 16, 2007 | 12:47 PM
meb's Avatar
meb
I tried, but keep getting the answering machine. I'll figure this out.
I may just cut the tab off the JCW filter and epoxy it the the Madness intake so that the JCW clip works...or just fasten a screw thru the JCW clip into the non-intake end of the filter...or cut a triangular shpaed hole in the Madness filter so the JCW clip fits into it. Three options! Where's my Dremel tool???
Old Apr 16, 2007 | 07:11 PM
YakiMini's Avatar
YakiMini
The Madness boys were out Dyno'ing an 07' "S" today. Try to give them a call early tomorrow morning (West Coast Time)
Motor On!
Old Apr 17, 2007 | 05:10 AM
meb's Avatar
meb
Just to be clear, the filter and poly engine dampener inserts I recieved are top notch! This is not a complaint about the product. I am at times a worry weenie; I would prefer to mechanically fasten the non-intake end.
bjcarter2
Aug 31, 2015 04:03 PM
The_Kid
Aug 28, 2015 04:50 AM
ASRman
Aug 13, 2015 09:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
