Drivetrain Fuel has relation to SC boost?
Old Sep 12, 2006 | 07:24 AM
2005MCS/KK's Avatar
2005MCS/KK
Since I had the autometer boost meter installed, I tested to see if different brand of fuels will have different effect on performance...
So far, I tested with the Petro Canada and Shell V-Power, each for 3 weeks, what I found is:
Petro Canada 94 octane > Max boost = 13~14psi at redline.
Shell V-Power 91 octane (Some said it is 93) > Max boost 16psi at redline.
I remember last year when I was on track, I used the ELF octane booster and my MCS reached 16psi before redline...
So the fuel does have relation to SuperCharge boost?
Old Sep 12, 2006 | 07:26 AM
1nf3rn0's Avatar
1nf3rn0
It seems to me that you should be boosting alot more than that with a 17% pully... I would imagine your gauge is off... You never know, though....
Old Sep 12, 2006 | 07:51 AM
GBMINI's Avatar
GBMINI
How could the fuel affect the boost? There's no "dump valve" so the only thing generating pressure is the RPMs and vehicle speed? Sounds more like measure-to-measure variation
Old Sep 12, 2006 | 07:53 AM
etalj's Avatar
etalj
16psi with a 17% in second gear at redline is about right
Old Sep 12, 2006 | 07:55 AM
1nf3rn0's Avatar
1nf3rn0
Then why do i get more than that wth my 15% at redline?
Old Sep 12, 2006 | 08:14 AM
etalj's Avatar
etalj
:D cos ur special
but seriously, atmospheric conditions and other variables are important.....
temperature, even mods like air intake (greater boost), headers and catback (less boost if there's better flow), and even the height above sea level all make a difference...
just out of curiosity, what boost do you see at 2nd gear and at what redline? stock or modified?
Old Sep 12, 2006 | 08:21 AM
2005MCS/KK's Avatar
2005MCS/KK
:D cos ur special
This is true, I remember when we are at 38C since last month, my Max boost was only 14~15psi, now actually with cooler weather (18~20C) I get 16psi (redline, 4th gear) or a bit higher boost (which cause the DSC light on).
I still don't understand why, but it is true that when I used the Petro Canada 94 fuel, I can never go up to 15psi... In summer, it was even worst... It can only go up to 11PSI! Then I switch back to Shell V power and will never go back....
Old Sep 12, 2006 | 08:32 AM
etalj's Avatar
etalj
ok i think i might understand why.....(someone correct me if i'm wrong)
your supercharger is driven by the crankshaft. If you're making more power (which you would with both better fuel and colder weather), you're spinning up the SC faster, and thus have more boost earlier (at say 3-4kRPM) then you usually would. When you're upping the engine speed, you up the supercharger speed. Since roots blowers make boost post-SC (because they're trying to cram more air into a smaller space), the more boost you start with, the more air you're increasingly cramming in, and thus the higher boost you make
yes, no, anyone?
Old Sep 12, 2006 | 09:15 AM
Soul Coughing's Avatar
Soul Coughing
yes, no, anyone?
Thats kinda true, but the S/C is belt driven to the crank, which means it pumps a certain amount of air directly proportional to what rpm the motor is at. At 2500rpms the s/c will always be spinning at the same rpm. The only variants are atmospheric, so things like your IAT's etc... dictate the amount of PSIg you'll make. I boost 2-3psig more when the temp changes from 90 degrees F to 50-60F.
Old Sep 12, 2006 | 09:26 AM
etalj's Avatar
etalj
yeh, but what i meant was if you are making more power, you get to a certain rpm more quickly. If you take longer to hit a certain rpm the air that has been jammed into the pre-IC horn gets used up before more air gets pumped in...if you're spinning it up quickly, the car has less time to use up all that air, and thus have more boost? Is that at all correct?
Old Sep 12, 2006 | 09:40 AM
stevecars60's Avatar
stevecars60
Air density....
Old Sep 12, 2006 | 11:35 AM
CCCP-MCS's Avatar
CCCP-MCS
What Brand Of Gasoline Gives The Most Boost? I Want More Boost. Can I Add Octane Booster To Get More Boost?
Old Sep 12, 2006 | 11:37 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Because MTH software raises the redline to 7200rpm...
The higher you rev the supercharger, the most boost you get.
Old Sep 12, 2006 | 11:43 AM
MGCMAN's Avatar
MGCMAN
Yea, air density and not octane should be the controling factor. Only if the lower octane is causing pre-detonation and the ECU retards your timing to avoid it would (lowering maximum rpm in the process) would octane be a factor, but as you are reaching redline with both kinds of fuel, I suspect that all the difference is made by the atmospheric conditions.
Old Sep 12, 2006 | 01:45 PM
herbie hind's Avatar
herbie hind
fuel density?
Old Sep 12, 2006 | 01:55 PM
stevecars60
Exactly
Old Sep 12, 2006 | 02:08 PM
Bahamabart's Avatar
Bahamabart
at 15 pulley produces 14.5lbs of boost - yr gauge is off.
Old Sep 12, 2006 | 02:34 PM
CCCP-MCS's Avatar
CCCP-MCS
What Is The New Redline When The Ecu Retards The Redline?
Old Sep 12, 2006 | 02:52 PM
2005MCS/KK's Avatar
2005MCS/KK
What I think is, it could be the fuel quality makes different? I remember that in Fifth gear (UK car channel) they did test different kind of fuels with different kind of cars. For NA cars, the quality of fuel will not make any different, but as for any F/I cars, it makes almost a 50BHP different if I remember well (with a Subaru STI).
So, could it be the quality of fuel which makes the supercharge blower runs slower, which cause less boost? I did test both Petro Canada and Shell V power for a while in same condition (Shell V power was test under 34C and almost 80% of humidity ).
But at the end, I am still not sure...
And yes about the MTH does help the redline to run over 7000~7200 rpm, my 16psi + happened right after the 7000rpm The MTH tuner is a great product.
Old Sep 12, 2006 | 04:52 PM
herbie hind
the denser the charge the stupider or just slow?
Old Sep 12, 2006 | 07:22 PM
etalj's Avatar
etalj
Turbo's are different. They run on exhaust gases. More complete combustion (due to the higher octane number) means hotter, and thus faster exhaust flow with more volume, which in turn means faster spinning turbines, which means more boost...
dinomaniac
Sep 18, 2018 04:19 AM
potterstein
Sep 13, 2015 09:57 PM
potterstein
Sep 11, 2015 09:24 PM
mbatech
Sep 10, 2015 03:40 PM
Sep 2, 2015 11:15 AM
