Drivetrain Help!!! Alta Big intercooler Air Diverter
Old Aug 10, 2006 | 02:25 AM
oceanstarBug's Avatar
oceanstarBug
I need a replacement of the black plastic hose which attached on the top of the Air Diverter...the rubber gasket that seals to the bottom of the hood!!!!! anyone know where I can get them??any alternative??? please advice!!!!
Old Aug 10, 2006 | 06:55 AM
minti's Avatar
minti
Ask ALTA
... I had luck, cause my dad works at a garage where they built custom lorrys and trucks. Sometimes this kind of rubber hose/gasket is used there to seal doors.
But my replacement has also been gone after a while.
So I built a complete new air diverter for the ALTA ic which utilises the BMW/Mini stock rubber foam gasket.
Old Aug 10, 2006 | 07:32 AM
obehave's Avatar
obehave
PEP Boys carries it. Whether it's the right dimension or not I don't know.
Old Aug 10, 2006 | 07:48 AM
MSFITOY's Avatar
MSFITOY
www.mcmaster.com
look for rubber seals...
Old Aug 10, 2006 | 07:59 AM
obehave's Avatar
obehave
Originally Posted by MSFITOY
www.mcmaster.com
I thought I saw that on Discovery Channel. Hieroglyphics in an Egyptian tomb or something.
Old Aug 10, 2006 | 09:50 AM
Koopah's Avatar
Koopah
Yes! That's it!
The Royal Seals
Theo
Old Aug 10, 2006 | 10:04 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I used #7 and #8 but #11 looks like it could be good!
Old Aug 10, 2006 | 11:54 AM
Crashton's Avatar
Crashton
[quote]
quote]
Old Aug 10, 2006 | 03:02 PM
norm03s's Avatar
norm03s
Or you can just go to the hardware store and buy1/2" or 3/4"water pipe insulation sleeve. use double sided 3M foam tape to stick it on.
Old Aug 10, 2006 | 03:14 PM
MSFITOY's Avatar
MSFITOY
Just curious what the end result of this would look like
Old Aug 10, 2006 | 04:04 PM
DrPhilGandini
Mmm, I'm with MSFITOY on this one. Might work, but after a while might look like *****...
Old Aug 10, 2006 | 06:03 PM
oceanstarBug
Please tell me that I am still safe to drive it around without the rubber gasket to seals the intercooler off!!!!!!
Old Aug 10, 2006 | 06:07 PM
obehave's Avatar
obehave
You're probably just going to spill air out and lose some efficiency with your IC. Not harmful.
Old Aug 11, 2006 | 04:55 AM
norm03s's Avatar
norm03s
It will work! As a temporary or permanent fix, in any event he did ask for HELP and alternatives. Just maybe he didn't want to wait or couldn't:impatient get to a junk yard where there's ton's of that stuff.
What did you think he was worried about not having a part on his diverter and getting gigged at a photo op or car show: sad:
Old Aug 11, 2006 | 05:01 AM
MSFITOY's Avatar
MSFITOY
I've done that by accident and without the seal, the IC is next to useless...ie, IAT rockets up and down with the go pedal...
Old Aug 11, 2006 | 06:19 PM
oceanstarBug
I am starting to making my own now.... will post pics when its ready thanks
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
