Drivetrain DFIC numbers
Old Sep 18, 2006 | 12:16 PM
  #551
TonyB's Avatar
TonyB
After installing and testing the DFIC, I did not provide my numbers in this "numbers" thread for two reasons:
1. Dr O was going to do so...
2. And as previously mentioned, the data-logging equipment utilized (CarChip E/X) only captures data at 5 second intervals; which is not exactly ideal. I simply started another thread, where the numbers were not the primary focus...
That all being said, the testing methodolgy was quite sound. Comparisons were done on the same car (my MCS). Runs were done on the same stretch of rural and canyon roads where I live. These runs were done during very similar environmental conditions, namely temperature. And I put the car through its paces in a very similar fashion, as the recorded speeds, RPMs and elapsed times would indicate. The only difference of note was the swaping of intercoolers, and from previous experiments, scoops as well...
From previous data-logging (BiMCom) that was provided on NAM:
- stock IC at 68F saw a max IAT of 133.25F
- stock IC at 98F saw a max IAT of 165.65F
- GRS w/ stock scoop at 68F saw a max IAT of 127.85F
- GRS w/ Extreme Scoop at 68F saw a max IAT of 123.8F
- GRS w/ stock scoop at 98F saw a max IAT of 153.5F
From my most recent runs with the CarChip E/X:
- GRS w/Extreme Scoop @76F saw a max IAT of 134.6F
- DFIC w/ included scoop @78F saw a max IAT of 116.F
I've learned that ambient temps do make a difference on IATs, no surprise of course. And that getting that air, and putting it to effective use is paramount. The DFIC does that well.
Old Sep 18, 2006 | 12:27 PM
  #552
Bahamabart's Avatar
Bahamabart
purely comparing these two IC w/ stock scoop then the GRS was 9% more effective than the stock IC.
On this day the difference between the two was 16%.
Very cool - thanks for sharing
Old Sep 18, 2006 | 12:47 PM
  #553
TonyB's Avatar
TonyB
Bart, I just added another data point that I found...
I'm currently trying to get a gauge set-up that should help for real-time info, but I want to learn more about thermocouples. Greatbear chimed-in this morning, and I still need to get back to him...
https://www.northamericanmotoring.co...86#post1138186
Old Sep 18, 2006 | 01:04 PM
  #554
obehave's Avatar
obehave
Originally Posted by stevecars60
You could make the argument that the frequency of the, tubulators & mass is very high defeating the TE & SC efficency. However, I can still take the 2lb (2"x1" ) block, put it in my rolling mill, roll it to .030 & it will heat & cool faster than the 1/2lb (1"x1/2") block.
All the TE data I have collected is not repeatable (that is I am not satisfied with it), therefore worthless info. The only real data colected is from the flow bench & all that can be determined is the core restriction.
As DMH Don says, the bigger the IC, the more air you are going to need & water to air needs big air, maybe bigger air, depending on the radiator being used.
Will it take the same amount of energy?
A flow bench is the ideal for sure.
The way I did the steady state cruising worked very well. If my ambient, inlet and outlet temps are stable within ±2º the results are pretty darned consistent. If I wanted a different inlet temp at X mph I just shifted into another gear.
Back to back day comparisons do suffer unless you're lucky enough to get similar days. I had many 88-90º days this summer although humidity was the most inconsistent variable.
Considering the gas I used a flow bench may be just a little more expensive
Old Sep 18, 2006 | 01:11 PM
  #555
obehave's Avatar
obehave
Puhleeese don't take this wrong.... You know I trust what you do, always have.
But without inlet and outlet temps this has less meaning.
Yes peak temps are meaningful but are only part of the picture.
I've logged enough of this to know it's easy to be mislead by peak alone. I'd think "man that should have been good" and then do the math and go WTF??
And again, to be clear, I am not saying the DFIC is a bad thing. It does a good job. Once the tinkering is done, better.
I am getting a bit tired of being apologetic though. I've done nothing wrong.
Old Sep 18, 2006 | 01:19 PM
  #556
obehave's Avatar
obehave
Originally Posted by MSFITOY
Just a slight one...
That's slight like the Grand Canyon is a ditch
Should have done them in lexan so you could be very Euro in showing off the motor
Old Sep 18, 2006 | 01:30 PM
  #557
TonyB's Avatar
TonyB
I understand obe, no offense at all. Temp is part of the picture, along with pressure (molecular density being the marriage). I am getting higher max boost with the DFIC than I ever got with the GRS, so temp takes center stage now...
This "testing" does not include inlet temps, and I understand the importance. I however did not neglect it either. Inlet temps are a function of conditions - ambient / environmental and driver input. I've controlled those quite well by:
1. Checking my home weather station before runs, and also with the MINI ambient temp gauge.
2. Hammering the car on a route that I drive daily in a similar fashion as I possibly can.
I am left with many WOT bursts in which to compare the IC's ability to cool what should be very similarly charged air. Until the other IC's have bungs to make for better comparisions of inlet temps, this is a valid method - in gear, and through gear WOT runs...
I think we finally have an intercooler that is better than a scoop alone .
Old Sep 18, 2006 | 01:53 PM
  #558
MSFITOY's Avatar
MSFITOY
I'm working on that...with greater opening as well
Old Sep 18, 2006 | 03:24 PM
  #559
obehave's Avatar
obehave
Should be fun
Old Sep 18, 2006 | 03:32 PM
  #560
obehave's Avatar
obehave
Hammering the car is good period
I understand the daily route test. Chunks of mine, although much more mundane than yours, are very familiar and have some nice features.
My biological, multidirectional asselerometer provides the feedback or lack thereof I need.
Speaking of scoop. Based on what I've found in measuring my IC with and without the asymmetrical scoop I have to give big creds toi the design.
It made enough consistent difference that I twisted ( well mildly twisted) Joel's arm until he sold it to me.
I'm sure that contributes to the effectiveness of the DFIC.
Old Sep 18, 2006 | 03:39 PM
  #561
TonyB's Avatar
TonyB
Indeed, it is a system; and the scoops make a difference, as with any TMIC, that's for sure. Joel is a nice guy, besides knowing his stuff! Refinement, I'm sure will continue, and I'll do my part there as well...
Old Sep 18, 2006 | 03:47 PM
  #562
stevecars60's Avatar
stevecars60
Will it take the same amount of energy? Here is the simple explanition, the surface will use the same amount of energy to heat & cool as the block, the difference is that the block will store more energy ( hot or cold ) than the sheet.
For sure.
The 1 important tool I can't find is my air dencity meter. It can be hot outside & you can have great air, likewise you can have the opposite. This summer the air quality changed by the hour.
Old Sep 18, 2006 | 04:08 PM
  #563
obehave's Avatar
obehave
For sure.
Thanks Steve. That helped.
Old Sep 19, 2006 | 07:52 AM
  #564
Partsman's Avatar
Partsman
Legion_of_Doom
I even suggested that this product will work better with a well designed exit duct.
Can you elaborate a little more on this?
Do you have an idea of what it will look like and exit?
PM if you want. Thanks.
Old Sep 19, 2006 | 02:47 PM
  #565
ChiliCooperS's Avatar
ChiliCooperS
The scoop makes a HUGE difference. I have a DFIC with both ceramic coats on it. Yesterday, after almost a month with the stock scoop setup with the DFIC and not noticing alot of difference I put it on. WOW. That's all there really is to it. So much torque, so much fast (well it feels like it anyway). Before the DFIC got so hot after hard runs that it would burn ur hand, it actually did i mean like my hand was sore for a day. Today it was barely warm at all. The temp here is about 60*. I ran it REAL hard after school, for a good 30minutes. I mean like hard acceleration, everywhere I could. Got home popped the hood. The intake horn before the DFIC was almost too hot to touch. The DFIC, barely warm. The output horn to the intake manifold? Room Temperature. Not a bit of heat. This ***** is amazing.
Mikey
Old Sep 19, 2006 | 02:51 PM
  #566
obehave's Avatar
obehave
Here's my limited understanding of it.
You want smooth laminar flow into through and out.
Currently there's a god effort to improve the first 2 bits but the third has been ignored to a large extent.
The air pre entrance on an IC is flowing faster than what it will through the IC core. You want the exit duct to accomplish the reverse of this. Take the turbulent air, make it laminar and then get it to accelerate and ultimately smoothly reenter vehicle flow.
If this is done well you may find that a smaller or thinner core will work as well as a, or better than heavier unit using poor ducting.
This wasn't really possible until the DFIC came along. The entrance scoop was changed for this purpose, the same amount of effort for an exit duct will potentially push this kit over the top.
Getting really out there....
They may want to look into using a splitter to route the boundary layer air( think of this as slow moving air that's kind of stuck to object it flows over) over the top of the unit and just have the laminar air reach the IC core.
Old Sep 19, 2006 | 06:28 PM
  #567
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks obe, for a little more insight.
Is there a way to find out where on the MINI is a good place for an IC duct exit? A location that might actually pull the exiting air out of the IC while driving.
What about routing the exit duct into a sealed air filter box or intake stream? The vacuum from the intake will help pull the air out of the IC. Pros? Cons?
Old Sep 19, 2006 | 07:25 PM
  #568
pure&simple's Avatar
pure&simple
The idea of smoothing the flow out of the DFIC could have merit, but I don't think you'd want to route it to the airbox... primarily because the air exiting the DFIC would be hotter than ambient, having just cooled the compressed air exiting the supercharger. Also, the faster you go, the more air is caught by the hood scoop and forced through the DFIC (to a point of course), so at a certain speed, the supercharger/engine assembly could actually become a bottleneck and hinder flow, especially at part throttle.
Old Sep 19, 2006 | 08:08 PM
  #569
obehave's Avatar
obehave
The simple solution is a nice clean line from the DFIC to an appropriate place in the hood.
Someone more clever than me needs to do the design. Ramp angle, width and a way to accomodate engine movement will need to be considered.
The other part p&s answered very well.
Old Sep 19, 2006 | 09:35 PM
  #570
M7's Avatar
M7
Ok ok okey......
We will have something very soon, my good friend JS is working on a solution
that will be visually stimulating and technically sound. Many of you DFIC owners, do own our Strut Tower Brace and this will also be considered in
the final product (space constraints). Will.......will (complicated) most likely have some CFD maps to show the exit scoops air flow characteristics and velocities.
M7 made the DFIC to be a system, with options like the bungs for testing,
and convenient pressure access (standard), or different coatings and future
uppgrades that will be available very soon. This makes the DFIC a very well rounded and thought out Intercooler system.
peter
Team M7
562-608-8123
Old Sep 20, 2006 | 06:47 AM
  #571
Gr8Force's Avatar
Gr8Force
Got the DFIC (polished/ceramic) on yesterday. The scoop has yet to be painted and installed and the thing still performed beautifully! You could really feel the power increase as you got going. It just kept wanting to go faster, as if that's bad thing. What the heck is this thing going to do when the scoop gets put on?!!! Great job M7!
Old Sep 20, 2006 | 06:51 AM
  #572
MSFITOY's Avatar
MSFITOY
Where will it exit? Will this interfere with my louvers?
Originally Posted by M7
Ok ok okey......
peter
Team M7
562-608-8123
Old Sep 20, 2006 | 07:02 AM
  #573
JS's Avatar
JS
Yup. Or so it looks like it might, from looking at your photos.
Old Sep 20, 2006 | 07:04 AM
  #574
MSFITOY's Avatar
MSFITOY
I guess this might be redundant for me then...
Old Sep 20, 2006 | 07:11 AM
  #575
62Lincoln's Avatar
62Lincoln
Joel, if you're still in a sharing mood (), will this require cutting into the hood ala Sid's project?
