Drivetrain DFIC numbers
Old Sep 20, 2006 | 07:27 AM
  #576
JS's Avatar
JS
Originally Posted by 62Lincoln
Joel, if you're still in a sharing mood (), will this require cutting into the hood ala Sid's project?
As of now, yes there will be a hole in the hood. Much work ahead, as I just got the DFIC yesterday and installed it. I need to do studies on the hood and understructure before cutting and modelling begins.
Old Sep 20, 2006 | 07:52 AM
  #577
Bahamabart's Avatar
Bahamabart
..... will this require cutting into the hood ala Sid's project?
I think that is a pretty safe assumption .
Cutting the hood is not that bad , for the faint hearted like myself just pay someone else to do it and don't watch .
Old Sep 20, 2006 | 08:29 AM
  #578
obehave's Avatar
obehave
Here's how to do it.
Wait until there is a wind storm.
Have a small limb "fall" from a tree and hit the hood exactly where the vent needs to be.
File a claim, get a new hood and then cut up the old one.
If you like it sell the new hood. If not put the new one on.
Disclaimer:
This was an attempt at humor. It's success may be questionable.
To actually pursue this course would be fraudulent.
I am in no way responsible for any future actions taken based on this attempt at humor.
Old Sep 25, 2006 | 03:25 PM
  #579
Larry Clemens's Avatar
Larry Clemens
come on thread WAKE UP Any more data?? BUMP
Old Sep 30, 2006 | 09:36 PM
  #580
cabmeister's Avatar
cabmeister
Can any one point me in the direction of required probes /gauges you have to have for readings from the DFIC ports .
I have the DFIC installed with the M7 extreme scoop fitted with the standard diverter plate . I am in the process of having a new diverter plate fabricated to accomadate the differant line up on the RH side of the intercooler in regards to the extreme scoops design.Thanks
Old Sep 30, 2006 | 10:27 PM
  #581
Dr Obnxs's Avatar
Dr Obnxs
The easy way
to mount up probes is to get some 1/8" swagelok fittings in the right pipe thread (I think it's 1/8", but I"m not sure...) Then any 1/8" probe will work. Use plastic ferrules with metal nuts, but don't overtighten, otherwise the only way to get them off the probe will be to cut them off! While it's more parts, it really opens your way to using lower cost off the shelf probes.
Matt
Old Oct 1, 2006 | 12:01 AM
  #582
maxmini's Avatar
maxmini
Matt
To confirm, the good Dr. is correct it is 1/8 " fittings .
Randy
M7 Tuning
Old Oct 1, 2006 | 09:25 AM
  #583
herbie hind's Avatar
herbie hind
Originally Posted by obehave
Very cool link. I even understood some of it.
Let's try this.
We magically suspend 2 500º ICs in the middle of a room with no air moving. One large, one small.
Which will reach room temp the soonest?
How about with a 5 mph breeze?
Which one will store more heat energy?
Which one will have more energy to lose?
On my way to pick up my car from getting an alignment.
See ya in a couple hours
i vote the larger one cools quicker due to surface area exposed to the cooler room temp. air.
Old Oct 1, 2006 | 09:37 AM
  #584
herbie hind
The simple solution is a nice clean line from the DFIC to an appropriate place in the hood.
Someone more clever than me needs to do the design. Ramp angle, width and a way to accomodate engine movement will need to be considered.
The other part p&s answered very well.
why not just redesign the horns in and out so the i/c could be raised up out of the hood (shaker style) then the air could run right thru .
Old Oct 1, 2006 | 01:31 PM
  #585
Longboard Mini's Avatar
Longboard Mini
This is the best idea I have seen. If the horns pushed the IC up, you could design a hoop scoop/pass through vent that could look very cool.
Longboard
Old Oct 1, 2006 | 04:48 PM
  #586
cabmeister's Avatar
cabmeister
Thanks Dr.O , well that was a start . I think really though I am a little out of my depth with trying to select Hardware for this Monitoring project .
Old Oct 1, 2006 | 05:27 PM
  #587
MSFITOY's Avatar
MSFITOY
Sooo...where are you guys getting the probes to fit the bungs? Then what do you hook it up to to take a reading?
Old Oct 1, 2006 | 05:37 PM
  #588
obehave's Avatar
obehave
Longboard
Well, since we're bench designing
It'd be nice to have the IC scoop(for lack of a better term) down low. Like down in the upper section of the current grill and then have the air flow up through the IC and out over the hood.
Ducted properly it would reduce high pressure buildup under the hood at speed(track speeds that is) and would keep the hot air from dumping into the engine compartment for starters.
Old Oct 1, 2006 | 06:19 PM
  #589
cabmeister's Avatar
cabmeister
Thanks Sid ,I think that was the question I should have been asking .
Old Oct 1, 2006 | 06:47 PM
  #590
buzzs06s's Avatar
buzzs06s
waylen at WAY rocks !!!! Thanks again Waylen!!!
Old Oct 1, 2006 | 07:20 PM
  #591
herbie hind
Longboard
wasn't it a hemmi cuda that used a shaker? or trans am ? those were nice they were water proof too . just redesign the scoop to let air out the back . it would pass straight thru .
Old Oct 2, 2006 | 08:21 PM
  #592
Longboard Mini
I think it was the Cuda. What a great car. I really think this is a great idea.
I also like Obehave's idea. (It'd be nice to have the IC scoop(for lack of a better term) down low. Like down in the upper section of the current grill and then have the air flow up through the IC and out over the hood)
LongBoard
Old Oct 2, 2006 | 08:25 PM
  #593
norm03s's Avatar
norm03s
Gee,why didn't I think of that.
Old Oct 3, 2006 | 05:24 AM
  #594
obehave's Avatar
obehave
Are we reinventing the wheel? aka "Someone said that before"
that's never happened to me
Old Oct 3, 2006 | 05:44 AM
  #595
chaincoopers's Avatar
chaincoopers
Man, reading all these DFIC discussions, I can't wait to get my hands on mine....
Old Oct 3, 2006 | 12:52 PM
  #596
herbie hind
obes' idea is more feasable . is there room for a snorkle under the hood down low ? then mount a cowl type scoop up towards the back as an outlet . we're talking cooper hood now not s . wait there is no room unless some cutting . that was stupid cutting hasn't stopped anyone here yet.
Old Oct 3, 2006 | 01:07 PM
  #597
herbie hind
how's this ...is the air now comin' from the back of the dfic going smack into the fire wall or is it diverting to the header ? i would like to see it diverted to the header to reduce some under hood temps and possibly force heat out thru the bottom of the car .
Old Oct 3, 2006 | 01:34 PM
  #598
jymontoya's Avatar
jymontoya
Damnit, that was my idea!
I'm working on a vacuum formed piece to divert air down the header tunnel.
Old Oct 3, 2006 | 01:46 PM
  #599
Bahamabart's Avatar
Bahamabart
edit - see below
Old Oct 3, 2006 | 01:48 PM
  #600
Bahamabart's Avatar
Bahamabart
The air is clearly departing via the header. A diverter might help it along but a better solution is to vent via the hood for not only could you push the DFIC out bit it would also work when stopped/ parked - allowing engine heat to escape.
