Drivetrain DFIC numbers
Old Aug 15, 2006 | 07:34 AM
  #326
Bahamabart's Avatar
Bahamabart
Originally Posted by TonyB
I'll be there Sat and Sun, in the M7 tent, so I'll take some photos of that, and the M62!
You lucky dog
Old Aug 15, 2006 | 01:12 PM
  #327
stevecars60's Avatar
stevecars60
Originally Posted by obehave
Cool
Here you go. This thing seems to work very well, no presure loss & quick recovery. The core design is interesting, not too sure what to think about it. The bad thing is there is no where you can put any temp sensors ( that I have ).
Old Aug 15, 2006 | 01:17 PM
  #328
obehave's Avatar
obehave
Tube design looks very similar to the GRS. A bit more crude in attaching them to the end plates though.
Forge
GRS
Old Aug 15, 2006 | 01:19 PM
  #329
curv872's Avatar
curv872
Anyone have a similar picture of the DFIC core design?
Old Aug 15, 2006 | 01:22 PM
  #330
Dr Obnxs's Avatar
Dr Obnxs
Not sure I agree...
The inside of your GRS is like what I expected. A good high flow design.
This, and the forge posted later, look like extrusions. The problem with that is they don't break up laminar flow as well. So while the pressure drop is small, the thermal efficiency isn't what it could be. I think it's better to have a lower density of turbulators that break up laminar flow than a higher density of ones that don't. I'd really like to get my hands on a stock unit, except with a row or two extra, and about 1/5" thicker. The ends of the tubes inside are great, and the turbulators are very thin (low heat capacity, don't take much flow cross section) and wiggly (break up the laminar flow).
I read somewhere (I think) that the GP has a slightly different IC... Wonder if they did that to decrease the pressure drop.
In general, I'm more a fan of brazed or bonded fins than extrusions... But to each their own.
Matt
Old Aug 15, 2006 | 01:30 PM
  #331
SpiderX's Avatar
SpiderX
Matt
I have a stock unit in a box at home
Old Aug 15, 2006 | 01:57 PM
  #332
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I can't post a photo as Im away from my server, but the internal fins on the DFIC are extremely similar (exactly?) to those in the stock IC, and not at all like those in the photos of the GRS or Forge.
Old Aug 15, 2006 | 02:04 PM
  #333
stevecars60
"Tube design looks very similar to the GRS. A bit more crude in attaching them to the end plates though"
Yes they are similar, both extrusions. As far as the end plates, 2 different ways of attachment ( hard to know why - the GRS looks like a better method ).
The thermal efficency would depend on how much transfer there is between the fins on the 2 extrusions to the honey comb. Break of laminar flow can be very good or very bad. Like the OE unit tubulaters, if the IC is cool the break up is very good but as the IC becomes heat soaked, you end up using the intake air to cool the IC. Yes? I belive with a larger area, IC, the laminar flow break up is not as important as the volumn of air is dictated by the TB - engine demand & held in the IC for a longer period of time.
"I read somewhere (I think) that the GP has a slightly different IC... Wonder if they did that to decrease the pressure drop." I'de bet on it.
Old Aug 15, 2006 | 03:21 PM
  #334
maxmini's Avatar
maxmini
This quick snap shot of the DFIC might give you all more to talk about . Its all about the details
Randy
M7 tuning
Old Aug 15, 2006 | 03:55 PM
  #335
Dr Obnxs's Avatar
Dr Obnxs
Where did the heat come from?
It came from the compressed intake air....
but anyway, the idea of optimizing the air-turbulator interface for maximum heat exchange is somewhat decoupled from the thermal mass of the unit. I say somewhat decoupled, because I think you can use thinner turbulator materials with braze or bond than you can with extrusions, so extruding tends to have more mass if they are made of the same material. But you could design a brazed or bonded turbulator fin set that was more massive if you wanted too..
I don't know for sure, but I'd guess that extruded cores are less expensive to make.
Matt
Old Aug 15, 2006 | 04:01 PM
  #336
stevecars60
Are we looking at the outside?
Old Aug 15, 2006 | 04:06 PM
  #337
DrPhilGandini
As I stated earlier, the fins on the inside of the DFIC look almost exactly the same as those on the outside.
Old Aug 15, 2006 | 04:20 PM
  #338
stevecars60
Yes, I know. Just wondering why there is a pic of the outside. As I have been saying all along the M7 looks like the best design for the job ( since it first came out, for that mater ). There is merit in the other designs as well. If we discover where they are, we may improve on their strength. I started with a 1952 Singer and it never was much of a car but I could beat some MGAs with it ( on a realy good day ).
Old Aug 15, 2006 | 04:33 PM
  #339
stevecars60
"I don't know for sure, but I'd guess that extruded cores are less expensive to make." Matt, Yes they are, but not by as much as you would think. Wall thickness can be uneven with certain extrusions. There is no way to measure wall thickness unless you cut the tubes. Some of the latest extrusions are CNC'd to very thin walls with very close tolerance. I can't say that either GRS or Forge are using ultra thin walls, the fins are the only tell tail. I don't think either company would volunteer any of that info.
Old Aug 15, 2006 | 04:48 PM
  #340
maxmini's Avatar
maxmini
That was a quick photo of the passenger side of the DFIC facing front. The basic shape of the vanes is similar to the stock but the frequency is different
Old Aug 15, 2006 | 05:05 PM
  #341
stevecars60
Thank you maxmini. That makes perfect sence, different frequency for different flow. I'm sure you guys are taking advantage of every sq" that IC will flow.
Old Aug 21, 2006 | 03:38 PM
  #342
Dr Obnxs's Avatar
Dr Obnxs
Hi all,
just to let you all know, I picked up a unit for testing this weekend. Should have everything closed in about a week.
Matt
Old Aug 21, 2006 | 03:58 PM
  #343
obehave's Avatar
obehave
Matt
Old Aug 21, 2006 | 04:29 PM
  #344
62Lincoln's Avatar
62Lincoln
x2
Old Aug 21, 2006 | 05:49 PM
  #345
Larry Clemens's Avatar
Larry Clemens
Old Aug 22, 2006 | 03:03 AM
  #346
stevecars60
X 3..... Oh boy
Old Aug 22, 2006 | 04:21 AM
  #347
mdsbrain's Avatar
mdsbrain
Matt
Oh snap
Old Aug 22, 2006 | 06:28 AM
  #348
Bahamabart's Avatar
Bahamabart
Matt
Let the games begin
Old Aug 22, 2006 | 07:26 AM
  #349
obehave's Avatar
obehave
So?
Has it been a week yet??
Old Aug 22, 2006 | 09:11 AM
  #350
DrPhilGandini
Where's that popcorn icon? I *know* this is going to be good, just to sit and wait as the anticipation rises, and rises...to a gigantic swell to the conclusion that it's not all smoke and mirrors. (That last bit is what I expect, anyone taking bets yet?)
lookin' good, Dr O.
