Drivetrain DFIC numbers
Old Aug 13, 2006 | 02:58 AM
  #301
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Thanks Randy. I figured out the bungs, I was just trying to take the quick route to buying the thermal probes that fit the NPT bungs. Any recommendations would be most appreciated. I think Sid (MSFITOY) is using the MM digital thermometer but I don't know what probes he's using.
I'll keep looking,
Old Aug 13, 2006 | 03:11 AM
  #302
TonyB's Avatar
TonyB
Besides SPA, who makes a dual digital gauge? It would be nice to have one gauge that show both temps (pre & post IC)...
Old Aug 13, 2006 | 03:19 AM
  #303
DrPhilGandini
Is the MiniMadness Intercooler Temperature Gauge the same one you refer to as a "SPA" Tony?
I found some 1/8 NPT bungs that are predrilled for temperature probes, and I found some inexpensive probes (I posted the link elsewhere and can't find it now, but will look again.) Problem with this solution is each probe comes with its own meter and digital readout so there's more gauges to mount on the dash. The single meter is a great idea but $300 (plus probes) is too rich for me.
cheers,
Old Aug 13, 2006 | 06:07 AM
  #304
SpiderX's Avatar
SpiderX
cheers,
Peter sent me a very nice gauge that we used but I did not notice make and model....maybe he could give you some info.
Old Aug 13, 2006 | 07:56 AM
  #305
Bahamabart's Avatar
Bahamabart
Its my understanding the a single guage with dual temp readouts is being developed.
Old Aug 13, 2006 | 08:17 AM
  #306
MSFITOY's Avatar
MSFITOY
Originally Posted by maxmini
cheers,
PS--does anyone know of a thermocouple or probe that will fit in the bungs on the DFIC? thanks, I want to start taking measurements.
As mentioned one the web site for you number's guys
Included on the intercooler are two 1/8th inch NPT threaded bungs which will allow thermal couple placement for pressure testing instruments or boost gauges pre-core and post-core.
Randy
M7 Tuning
You're asking us?
I'll keep looking,
dr. phil
I found a few searching the net that had NTP threads but assembling two probes and sending unit were prohibitively expensive. I ended up using Vivid Racing's IN/OUT intercooler gauge with dual probes. They are not NTP fittings so I drilled two holes () up into the DFIC at the center line pre and post core from beneith and then sealed with silicone...sorry, but I don't have images of the probes...
Old Aug 13, 2006 | 10:03 AM
  #307
TonyB's Avatar
TonyB
I've seen that In/Out/Diff on the Subaru and a few other forums, and Madness offers it. I'd like to see not just one temp at a time though...
Here's a link to the SPA duals:
http://www.scienceofspeed.com/produc...n/dual_gauges/
In group B, the temp/temp one would seem to be appropriate...
Not cheap, but has some pretty slick options.
Old Aug 13, 2006 | 11:21 AM
  #308
Dr Obnxs's Avatar
Dr Obnxs
None of these are what you want...
Close, but not quite..
But for those of you who really want to log this stuff well, there are some things to look out for....
The cheaper probe/thermometors are slow. Both in update speed and thermal response. Think of this as a massive low pass filter on the data stream. Sad thing is to make some fast response stuff isn't that cheap. For example, the Tc that PLX sells for the EGT probes is over $80, it's a faster probe than others (But it is threadded for metric threads, sorry). The $250 price point for the dual temp IC monitor isn't really that bad a price, if you look at what it takes to put it all together.
Matt
Old Aug 13, 2006 | 11:32 AM
  #309
M7's Avatar
M7
Just a heads up...
M7 is working with SPA for a custom Pre/Post DFIC gauge, and we
will have it on our car at the Monterey Historics.
peter
Old Aug 13, 2006 | 01:21 PM
  #310
TonyB's Avatar
TonyB
Man, you guys don't miss a beat! I should have guessed when you alluded to something... Look forward to it!
Old Aug 13, 2006 | 01:35 PM
  #311
DrPhilGandini
This is great news! I hope it's a reasonable price. I found a Pace Scientific logger and 2 probes with NPT fittings, but...
http://www.pace-sci.com/data-logger-xr440.htm
It's $499 and $38 or so for each probe and then $20 for the data cable. Mmm, I think that represents too little a return for my investment since I can feel the effect of the DFIC and associated placebo without any instruments.
I'll wait until m7 offers the gauge. I hope someone attending Monterey will report on what they see and hear regarding the gauge? (please...)
Old Aug 13, 2006 | 01:39 PM
  #312
TonyB's Avatar
TonyB
I'll be there Sat and Sun, in the M7 tent, so I'll take some photos of that, and the M62!
Old Aug 14, 2006 | 03:54 AM
  #313
Peter@M7Tuning's Avatar
Peter@M7Tuning
Originally Posted by obehave
Undoubtedly the thinner but we are not talking about 2 objects of the same mass. If you thinned out a 2 lb block to .050" and a 1.75 block to .050" which will reach ambient sooner? Thats what we're talking about.
If they were the same thickness, it could be 1 kg, or 20 kg, and they'd cool at the same rate, and reach ambient at the same time (provided they were essentially suspended in a big room. a flat 20 kg piece of metal would be big! ) Why?
I think stevecars60 mass to surface area ratio comment makes the most sense.
Taking that into consideration there might not be as great a time differential as I first thought but there still would be one.
If the mass goes up 20% but the surface area only goes up 15% then there is a loss. Made up figures but they demonstrate my intention.
Bear in mind that a large portion of the mass increase will be in the end tanks,including the tube ends, which assist very little in cooling the charge or the entire unit for that matter.
Back to my comfy chair
Exactly, which was the point I was very poorly trying to make.
Of course, we're still assuming ideal flow rates. With the GRS being a larger intercooler, you need to increase the size of the scoop to provide more air, or the cooling efficiency will ultimately suffer because you'd only be feeding it enough air for the stock IC. Even then, the stock scoop is probably not gulping enough air even for the stock IC.
Ok, so now that we're all on the same page...
Old Aug 14, 2006 | 04:23 AM
  #314
stevecars60's Avatar
stevecars60
Note: From memory the aftermarket unit are 10-20% larger. My GRS for instance has a ~ 13% larger area on the top surface over stock. Measuring fin area only. ~18.4% greater cu/i
Stock = 10.875 x 6.375 x 1.875 102.5 sq/in and 205.3 ci/in
GRS= 11.250 x 9.125 x 2 89.33 sq/in and 167.5 cu/in
Obe, time to get out of your chair.
Take a look at the tubes in your GRS & compare with the stock unit. Are they the same ( IE - do they have any internal fins )?
Maybe M7, Gandini or TonyB can tell us what the tubes look like on the inside of the DFIC. Forge's new IC has extruded tubes with fins on the inside.
Old Aug 14, 2006 | 05:05 AM
  #315
obehave's Avatar
obehave
I've inspected the IC quite thoroughly thank you.
Remember I used to build and run QA on radiators and heater cores for a living.
Once again all I am talking about is that a larger mass will take longer to cool. Period. You guys keep adding extra stuff. Most of it not germane to that simple fact.
Old Aug 14, 2006 | 05:23 AM
  #316
stevecars60
Made a ton of radiators myself. Hey, just thought I'de throw something different at you. I'm not going to mass v surface anymore. Done. Just something different to think about ( like there is more to think about ).
What I'm wondering is, the stock unit has a typical honey comb of aluminum & since I don't have a DFIC or a GSR to compare, what the make up of the tubes in GSR & DFIC.
Old Aug 14, 2006 | 05:57 AM
  #317
DrPhilGandini
The fins between the core plates on the DFIC look the same as those on the stock IC, from a -non-radiator- guy. I said in a previous post that the internal fins looked more dense than the external ones, but after looking again last night (I'll have many nights to look at them as I'm away from home and can't install the thing for a week -- darn it) they appear very similar. The density just looks greater looking down the long axis of the IC rather than across the short axis (duh, phil.)
cheers,
Old Aug 14, 2006 | 06:34 AM
  #318
stevecars60
cheers,
Thanks Phil. I'll take a pic of the Forge, it has fins on the internal extrusion, not the honey comb. Interesting.
Old Aug 14, 2006 | 07:09 AM
  #319
obehave's Avatar
obehave
Good question. If it doesn't rain or somebody posts them first, I'll pull the GRS and take pics. My Stock unit is setting in my shed so I can do that easily.
Old Aug 14, 2006 | 08:36 AM
  #320
stevecars60
Thanks, Obe, I should have taken a pic of the Forge before I put it on the car. The Forge is a different animal. It's interior design is nothing like I've seen ( not at all like the stock or the DFIC ), however, it is still a vertical flow IC.
Old Aug 14, 2006 | 09:22 AM
  #321
flyboy2160's Avatar
flyboy2160
Originally Posted by Dr Obnxs
....Strip all the other stuff off, and these things (DFIC and Alta flow through design) work because the improve the flow of the cooling air...
Matt
how do you know this is true? has anyone measured it? has anyone done a fea cfd/thermal analysis or even hand calcs? (please spare me the m7 ram air cfd plot. anybody claiming 16+ psi obviously hasn't done their homework..)
the cooling does NOT just dpend on the airflow available, it also depends on the actual shape of the ic. this has been mentioned many times before: there is a good reason that almost every radiator is much thinner in the direction parallel to the cooling flow than than it is normal to the flow; the air picks up heat as it passes through the device, thus reducing its ability to cool.
the thicker alta/m7 design is trading off less cooling efficiency through the thickness for a hypothesized better flow through. but until you run the numbers comparing the stock style flow path to the alta.m7 path, making claims about "better" or "best" is just yet more unsubstantiated marketing hype, not engineering and not science.
Old Aug 14, 2006 | 09:29 AM
  #322
Dr Obnxs's Avatar
Dr Obnxs
From testing...
But you are correct. The Alta flow through works better due to lower pressure losses. That was the first prototype and I don't know what Jeff did to the design after that. GRS made power with lower back pressure, not lower temps.
There are flow models that Will did that are posted.
But another answer is common sense. If the same amount of air flowed through the flow through ICs, the cooling air would heat as it went through the core, not really cooling the air at the back of the IC. Initial data says the air coming through the IC is cool, ergo there is enough flow to cool it.
Matt
More....
This just isn't true. TonyB has posted IAT numbers that show the DFIC lower than his modded/extreme scooped GRS, and the temps are down. I don't need a flow model or FEA to tell me what's going on. Thermal efficiencies are up. But you also say modeling is the only way to get the answer. I don't agree, you can also experimentally verify the function.
Old Aug 14, 2006 | 03:56 PM
  #323
obehave's Avatar
obehave
As promised
GRS and stock tube shots. Stock is a bit fuzzy though.
I tried to do a shot of which passed the most light(GRS) but turned out not so good so take my word for it the GRS passes more light down each tube.
Left is the GRS, right is stock
Old Aug 15, 2006 | 05:37 AM
  #324
stevecars60
As promised
The inside of your GRS is like what I expected. A good high flow design. It's raining here, I'll get you a pic of the Forge ASAP.
Old Aug 15, 2006 | 05:40 AM
  #325
obehave's Avatar
obehave
Cool
