Drivetrain M7 DFIC
Old Mar 30, 2006 | 06:08 PM
  #201
Peter@M7Tuning's Avatar
Peter@M7Tuning
Jeff,
We all appreciate your interest in the M7 DFIC, and we'll be happy to help. At M7 we put as much effort as is needed to bring the best products to our fellow motorers, and the DFIC is not different. Literally months of development effort has gone into bringing the Direct Flow Intercooler to our customers, through every process from CAD modeling, to computational simulations, to prototyping and finally the released product so that it works as expected when delivered. As with any company producing innovative parts, we like to protect the investment of our time, and patents are one way to do this. The M7 DFIC has been assigned the US Patent Pending number US60/749,682.
The AGS patent is currently undergoing revision for a CIP. We can forward you the original documentation if you like.
If you are concerned about stepping on our proverbial toes as far as product development goes, feel free to give us a call. We're always available to answer any questions you might have. Contact information can be found on our website at www.m7tuning.com
Again, thank you for your interest in our products. Let us know if we can help further.
Will
M7 Tuning
Originally Posted by ALTA2
Peter, Will, and Randy
Originally we were going to send you this message privately but we thought that other members would be interested in the information.
It would appear that our companies have been developing a similar top mount intercooler. Before we finalize our design can you publish your patent number(s) so that we make sure not to infringe on your patent.
Also please specify your AGS tube patent number(s) as we are continuing to develop new silicone products for the MINI. I don’t think that anything we have in the works is similar to your tubes(s), but its always nice to double check.
Hope everyone can learn a bit about patent from these quick questions.
Jeff
To refresh you on the ALTA Sidedraft
https://www.northamericanmotoring.co...ad.php?t=56802
Old Mar 30, 2006 | 06:18 PM
  #202
neilgj's Avatar
neilgj
Originally Posted by Will @ M7 Tuning
The M7 DFIC has been assigned the US Patent number US60/749,682.
I think there's a typo in that patent number
It should be a seven digit number less than about 7,100,000 and probably greater than about 6,500,000 if it was recently issued (sometime after 2003)
Old Mar 31, 2006 | 03:41 AM
  #203
Peter@M7Tuning
You might be right. However, the process for moving from Provisional Patent Pending status to full Patent award is not a quick process. It's possible the number is wrong, and I'll double check with our patent attourney on this, when he wakes up. I'm willing to bet it's the status that is throwing you off, however.
Old Mar 31, 2006 | 05:48 AM
  #204
SpiderX's Avatar
SpiderX
when will we see numbers
enough of the BS..... when will we see numbers.....
I got a PM from a friend that said that he felt the M7 would only be better at speed... that the Alta due to its sheer size will perform better at lower speeds..... what do you all think of this?
Old Mar 31, 2006 | 05:57 AM
  #205
Peter@M7Tuning
Originally Posted by macncheese
How is constant mass a "variable" ?
Usually it's m, but that's not really the point. Point is that the calculations of thermal efficiency are made with the assumption that everything else is held constant. Now, tell me how many intercoolers have 0 pressure loss across the core? Is mass flow really constant? I think you'll agree that the answer is most likely no. So, in your calculation of thermal efficiency, you do not take into account the possibility that pressure may drop across the core. So take the condition where there is a 100% thermal transference to the ambient air as it flows through the core. Now, with a pressure drop it certainly possible to have, say, another 2% decrease in temperature. So now when you measure the air coming out of the intercooler, you would have a 102% thermal efficiency, because you didn't include pressure as a component of the calculation.
Now you have achieved higher than 100% thermal efficiency by definition and assumption. A true calculation of intercooler efficiency would have to account for temperature, pressure, mass flow, etc. as well as maintaining accurate readings of the true "ambient" temp, etc., and could not exceed 100% efficiency. I understand, however, that not everyone wants to tackle that complex of a calculation. If one insists on using the simpler approximation of thermal efficiency, one has to expect "strange" conditions, like over 100% thermal efficiency, to arise.
I think you mean temperature and not heat, but yes, we're looking at a thermal efficiency. I still dont understand over 100% thermal efficiency without some 3rd party energy source.
And since we're nitpicking, "temperature" is a scale applied to the heat (energy) density of a material. From www.m-w.com:
Main Entry: tem·per·a·ture
Function: noun
2 a : degree of hotness or coldness measured on a definite scale -- compare [SIZE=-1]THERMOMETER[/SIZE]
Main Entry: 2heat
Function: noun
Etymology: Middle English hete, from Old English h[AE]te, h[AE]tu; akin to Old English hAt hot
e (1) : added energy that causes substances to rise in temperature, fuse, evaporate, expand, or undergo any of various other related changes, that flows to a body by contact with or radiation from bodies at higher temperatures, and that can be produced in a body (as by compression) (2) : the energy associated with the random motions of the molecules, atoms, or smaller structural units of which matter is composed
So thermal efficiency is a measure of the efficiency to transfer heat from one material to another, not the transference of temperature.
Old Mar 31, 2006 | 07:02 AM
  #206
Peter@M7Tuning
Workin on it.
As far as the Alta unit working better, without data no one can say for sure, but who told you size mattered?
The DFIC should work fine at lower speeds due to very large surface area. I'm not sure how size would factor in when you are looking to have the largest exposed surface to facilitate heat transfer. I'm not worried about poor low speed performance. The preliminary testing shows very fast recovery time coming off of a stop. But again, we'll have to wait for more data.
Old Mar 31, 2006 | 07:15 AM
  #207
SpiderX's Avatar
SpiderX
Workin on it.
Old Mar 31, 2006 | 08:07 AM
  #208
neilgj's Avatar
neilgj
Oh, I see. I misunderstood. I thought you already had a patent approved. In fact, you haven't yet been granted a patent, you have submitted an application. And it is true, it could take 3 to 5 years until the patent is approved. Also, if you just submitted the application, it won't be online for a couple of months or so. Now it all makes sense.
I just might add that calling the technology "patented" (as is done on your web site and the posted announcement) is a bit misleading since you have only applied for your patent. It could be rejected or the claims could be narrowed to such an extent that the patent is quite limited. It will be a few years until we know this outcome. Good luck!
Old Mar 31, 2006 | 08:37 AM
  #209
FlynHawaiian's Avatar
FlynHawaiian
The wonders of Patent Law . I took a class in college on this, fun stuff. Most likely, I'm going to take a jump at this. Idealistacally, we are reducing the air temps. So Stupid question, what is the delta temp difference between stock and this unit on the air, going into the engine?
The colder the air, the more compact it can be, and the more you can shove into the cylinder. Thus the more power you get out. Just a few stupid things, but what kind of temps are we talking at idle and freeway speeds?
I figure that in due time the test results will be delivered, just a question if you had these during development though.
Old Mar 31, 2006 | 09:44 AM
  #210
Dr Obnxs's Avatar
Dr Obnxs
Here's what I've seen...
At idle, the air is going around and around the SC, because of the bypass, ans it's about 60-80 C. But this isn't aproblem, because the motor is under so little load.
At WOT and redline in 2nd gear, I'm seeing temps out of the SC of 100-120 C, with an ambient of 40-50 F (just to mix units...). At 70 MPH and WOT, the stock IC was testing at about 60-65% thermal efficiency, that is, reducing the temp gain from the SC 60-65%.
Eventually, I'll be getting a rig from M7 to test, and since they don't pay me, the numbers can be seen as independantly measured.
But that will take a while. Until then, we're just left with the "typewriter racing".....
Matt
Old Mar 31, 2006 | 10:13 AM
  #211
FlynHawaiian
when you say out of the SC, are you saying right before the air goes into the chamber? I'm interested to know, what kind of temps do you get before the sc and after it? How much thermal heat is going into adding boost?
Old Mar 31, 2006 | 10:25 AM
  #212
Dr Obnxs's Avatar
Dr Obnxs
Here's some data....
15.0.....93.2......43.4.....22.3.....63.7%
15.5.....105.3....50.9......43.0.....60.6%
15.5.....102.6....46.6......25.0.....64.3%
15.5......99.2.....43.0......21.0.....67.1%
16.0......99.0.....44.6......24.0.....65.5%
The first number is the ambient temp (all temp are centigrade).
The second number is out of the SC before the IC (measured at the rubber coupler).
The third number is post IC before the intake manifold (measured at the rubber coupler).
The fourth number is post IC before the HP run (as an indication of heat soak)
The 5the number is the IC thermal efficiency at redline, second gear (about 70 MPH)
This was a stock IC.
So you can see that I'm seeing temp gains of 80 C or so out of the SC.
Doing some more math, about a quarter of post SC boost is due to gas heating.
And about 15% of the post IC boost is due to gas heating.
But then, that's why we use an IC!
Matt
Old Mar 31, 2006 | 10:34 AM
  #213
maxmini's Avatar
maxmini
Workin on it.
Will with the delta's we saw at 30 MPH I do not think we will have a problem out performing any of the larger old school Ic's which still have to have the air make a 90 edgree turn before they even start to work. As a matter of fact I think that the lower the speed the worse it would be because they have even less pressure to try and make that turn. Of course I am just basing this on what we saw on one day of running. Hopefully the Dr. will be able to confirm this or perhaps you can go " high tech " on us and run some simulations when you get the time.
Randy
m7 Tuning
Old Mar 31, 2006 | 10:35 AM
  #214
FlynHawaiian
80-c to run through the sc... I mean if we could lower that to like 40-c and bring the thermal efficency higher, it would free up more power! And possibly more boost from the SC itself no?
Old Mar 31, 2006 | 10:40 AM
  #215
Dr Obnxs's Avatar
Dr Obnxs
Sure...
but you aint gonna be able to do that with a roots SC. The thermal efficiency of the SC is part of it's design. And that's just the way it is.
Also, the roots isn't a compressor, it's just an air pump. There are things called twin-screw SCs that compress while pumping, and they do have better thermal efficiency. The trend towards turbos is driven in part by the even greater still thermal efficiency. It's just the nature of the beasts.
One of the reasons that people port and polish the SC is to reduce the turbulence and reduce heating, but I've never seen real data on how well it works.
Our roots blowers are nice, in that they are affordable, and work pretty well, the IC makes up for some of the termal effeciency problems. The twin-screw is more expensive to make, and also has an issue of heating the charge even when the boost is low (like when the bypass is open) because it compresses even if you don't need it to.
I'm afraid that if you want much better thermal efficiencies, you'll have to wait for the turbo in 07.
Matt
Old Mar 31, 2006 | 12:04 PM
  #216
FlynHawaiian
hmm, how much trouble and benefit would it be to install a twin screw.
Old Mar 31, 2006 | 12:35 PM
  #217
obehave's Avatar
obehave
Matt
As a side note. I'm pretty sure centrifugal superchargers are as thermally efficient as a turbo. They should be. Their compression works them same the only difference is how the impellers are driven.
Anybody with manufacturing skills could replace the current SC with a shaft to drive the water pump as is and also use that shaft with properly dimensioned pulleys to drive a Vortech or Paxton unit.
You could replace those inefficient "horns" with some round mandrel tubing and pick up a crapload of HP just through flow improvements. Put the TB closer to the head in the induction path, etc.
Old Mar 31, 2006 | 11:45 PM
  #218
Cooper_Si's Avatar
Cooper_Si
Interesting idea regarding the vortech chargers, im originally from VW world and seen them fitted to Corrados and the like. I also owned a VW Polo G40 with a G-Lader supercharger, same as a G60 but slightly smaller. The only problem was that they need refurbishing every 50,000 miles. Quite costly. But the sound was gorrrrrgeous. BUT anyway i cant see where the space is in a MINI engine bay to fit one of these centrifugal chargers :(
Old Apr 1, 2006 | 04:13 AM
  #219
macncheese's Avatar
macncheese
I should have listened to obehave.
Old Apr 1, 2006 | 02:28 PM
  #220
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Hey who needs Andy .. look like Will is taking up the slack
Old Apr 1, 2006 | 03:04 PM
  #221
macncheese's Avatar
macncheese
what slack?
Old Apr 1, 2006 | 04:13 PM
  #222
///ACS330Ci's Avatar
///ACS330Ci
Originally Posted by M7
M7 DFIC testing
70mph
3400 rpm
11.7:1 air fuel ratio
Pre core 182˚
Post core 63˚
Peter
Team M7
562-608-8123
Peter,
What was the ambient temperature during this run?
Never mind, I found it. Guess I didn't read far enough
Old Apr 1, 2006 | 04:15 PM
  #223
MSFITOY's Avatar
MSFITOY
Originally Posted by ///ACS330Ci
Peter,
I heard 70F...
Old Apr 1, 2006 | 04:21 PM
  #224
maxmini's Avatar
maxmini
Between 68 and 69 .
Randy
M7 Tuning
Old Apr 1, 2006 | 04:28 PM
  #225
M7's Avatar
M7
68˚Fusing the internal MINI thermometer and 70˚F on our outdoor thermometer.....
peter
