Drivetrain M7 DFIC
Old Mar 28, 2006 | 10:55 AM
  #101
haulinS's Avatar
haulinS
not just the best....but the best in the MINI universe!!!
Originally Posted by M7
Good Morning....
I wan't to appologize for a small number eff-up.....
THe foncusion.... come from a set of numbers that was non printable
as of now.....heheheh.
Pre-core 121 degrees
Post-core 63 degrees
These numbers are still incredibly good, proving that our design is
the best in the MINI universe.
peter
Team M7
562-608-8123
Old Mar 28, 2006 | 11:16 AM
  #102
maxmini's Avatar
maxmini
Im thinking that that might have been said in jest but if its what you want to beleive I am not going to stop you
Randy
m7 Tuning
Old Mar 28, 2006 | 11:25 AM
  #103
obehave's Avatar
obehave
Originally Posted by maxmini
I am gald you all are having as much fun with this information as we were yesterday when we were recording them. I can confirm that the ambient was 70 degrees . We took readings at several speeds including as low as 30 MPH which would put us in a disadvantage with some of the other units dyno results and the drop percentages were still VERY good . As for we , M7 , saying it is the best I do not recall seeing that anywhere and if we did then I apologize. It will be up to you all once the final numbers are in to decide that. Our feeling is that you will
Randy
M7 tuning
Believe me I'm not saying it's a bad product. I believe it's very well done and innovative on the MINI platform.
I'll gladly wait for more numbers since I've made it a bit obvious that I'm not quite sure about 114% efficiency.
Shutting up now
Old Mar 28, 2006 | 11:30 AM
  #104
SpiderX's Avatar
SpiderX
the laws of physics don't change...our understanding of them does - BB 06
Old Mar 28, 2006 | 11:31 AM
  #105
haulinS's Avatar
haulinS
I'll believe it until its proven wrong. after all this is America..innocent until proven guilty.
Randy
m7 Tuning
Old Mar 28, 2006 | 11:32 AM
  #106
obehave's Avatar
obehave
Holy Quantum theory Batman!!!
Old Mar 28, 2006 | 11:38 AM
  #107
RECOOP's Avatar
RECOOP
Reduction in temperature
Based on the numbers posted:
Stock IC - 54% reduction in temperature
GRS IC - 58% reduction
M7 IC (original, but in error) - 65% reduction
M7 IC (corrected) - 48% reduction
Now the new IC doesn't look so good. The efficiency number (114%) that was referenced for the M7 IC (corrected) is meaningless, because it is impossible, even in the Mini universe. "Obehave" expressed it quite well.
Obviously, testing conditions between the stock & GRS were different from the M7. Before anyone starts or continues to use extreme hyperbolic phrases in describing this new product, it would be prudent to see meaningful data, i.e., data obtained under appropriately controlled conditions. I believe that Matt will be doing this...
Old Mar 28, 2006 | 11:49 AM
  #108
Peter@M7Tuning's Avatar
Peter@M7Tuning
If you think 114% efficiency is impossible, then you don't understand the laws of physics, or perhaps you don't understand what's going on. Either way, that's a mighty bold statement from you. I believe if you think about it for a bit, you'll be able to come up with the answer that fits. Whether it's right or not, well, that's another question that can only be answered with more tests and more data.
So let's just accept at this point that so far, data shows that the intercooler works and works well. I believe in it, certainly. If you don't, well, don't buy one. But we aren't going to stop with a few tests and expect that everyone will jump at it. That's why Matt is going to test it, with the same methods as his previous tests, and you can go from there.
Old Mar 28, 2006 | 12:03 PM
  #109
RECOOP's Avatar
RECOOP
Originally Posted by Will @ M7 Tuning
If you think 114% efficiency is impossible, then you don't understand the laws of physics, or perhaps you don't understand what's going on. Either way, that's a mighty bold statement from you. I believe if you think about it for a bit, you'll be able to come up with the answer that fits. Whether it's right or not, well, that's another question that can only be answered with more tests and more data....
Thanks for the note, and you are correct that one can indeed get efficiencies greater than 100%. I shouldn't have used the word "impossible"; however, the basic content of my post still stands. We both agree that appropriate testing is indeed in order...
Old Mar 28, 2006 | 12:10 PM
  #110
obehave's Avatar
obehave
Poo all gone now
And thanks Will
  #111
ingsoc's Avatar
ingsoc
That's NOT how you measure IC efficiency. Read my post on the previous page and learn the real way.
Do you follow the weather? Are you familiar with how temperature is reported- specifically, "temperature" and "wind chill factor?" You know how wind chill factor is cooler than "temperature?" The IC uses wind to cool. It operates by wind chill. In so doing, it can achieve more than "100%" efficiency.
If you don't believe me, think of it this way [to be completely transparent, this is an educated hypothesis]:
Air flows through the IC's fins at, say, 50 mph at 70 mph. Charge flows through the IC at, say, 100 mph. IF the volume of air passing through the fins [speed of air * cross-sectional area of aperture] is greater than the volume of air passing through the charge tubes, you can achieve greater than 100% efficiency, since each unit air passing the fins can extract "x" amount of energy [heat] before it achieves an equilibrium with the charge air. The IC's front section area is greater than that of the pre-IC boot, judging from the photos provided. Therefore, it is possible that that is what is happening here.
If anyone would like to have further detail regarding my "back of the envelope" calculations, pm me.
Old Mar 28, 2006 | 12:16 PM
  #112
ingsoc's Avatar
ingsoc
Originally Posted by obehave
Don't get them in a twist
I never even said I was 100% right.
Once again you guys are looking for a fight that isn't there.
I even asked folks to check my math.
I've used self deprecating humor to indicate my lack of seriousness about this. Smilies and crap in appropriate places.
But now you've gone and started a pissin contest. Telling me I don't understand physics. That was Punkish and totally uncalled for.
You find me an article by anybody, anywhere that states an IC efficiency can exceed 100% and I'll change my mind and buy your IC.
Which BTW I was seriously thinking about buying. Thank you for changing my mind and saving me money.
I honestly don't think that that comment was directed at you, man. I can see how you read that, but seriously- don't be offended. We are all entitled to our own opinions. In the end, the truth always prevails. You're right to be skeptical, and it is the onus of a vendor to earn your money. But, again, I think this is a misunderstanding. I've only ever had extremely positive experiences with M7 when personally dealing with them. If I were you, I'd take the opportunity to call them up and ask them your question in person. I know that they will be more than happy to explain whatever it is that they know. Either way, have a great one!
Old Mar 28, 2006 | 12:17 PM
  #113
Peter@M7Tuning
Well, but I wasn't talking to/about you at all...
see:
And I wasn't trying to pick a fight or start a pissing contest at all. I'll be happy to discuss with you how the efficiency can be over 100% over PM/email, but my main point was that there's not enough data to draw such thick lines yet, and more is on the way. That's it. I'm sorry that it came off like I was attacking you, I really wasn't.
Old Mar 28, 2006 | 12:31 PM
  #114
MSFITOY's Avatar
MSFITOY
oooooooook....open door wide....ahhhh....nice fresh breeeeeeeeeze
Old Mar 28, 2006 | 12:32 PM
  #115
SpiderX's Avatar
SpiderX
I'm exposed........ I stand by the fact that neither the Alta nor GRS allow for air to escape/flow......nice heat sink.
How does the car feel....Peter said that Randy says it feels punchier with more low end and that the recovery is very fast..(I assume while moving)
  #116
obehave's Avatar
obehave
see:
Group hug.........
Old Mar 28, 2006 | 12:34 PM
  #117
Peter@M7Tuning
Group hug.........
awwwwwwww!
Old Mar 28, 2006 | 12:53 PM
  #118
maxmini's Avatar
maxmini
Feelings I am all about that We have a well known road in my area . I have been up it at least 300 times and pretty much know each stone, tree, branch and crack from top to bottom. Going up hill it is a constant climb with a variety of curves both with one almost 90% turn. Back in my stock mini days it was mostly a second gear climb with some touches of third. After about 2 years of development on the car and myself i was able to take most of it in high in third with a drop to second at the tight 90. With the new IC I made two runs in mid 4th with a drop down to 3rd for the tight one. Numbers ? I don't need no stinking numbers the damn thing works
Randy
M7 Tuning
Old Mar 28, 2006 | 01:08 PM
  #119
Partsman's Avatar
Partsman
Legion_of_Doom
Randy
M7 Tuning
That's all that really matters, when you think about it.
Old Mar 28, 2006 | 01:23 PM
  #120
SpiderX's Avatar
SpiderX
I won't say which mods I bought by "numbers" that have sucked (read disappointed)
I like my testing method.....which by the way has been painstakingly developed after spending lots of hours and $s on other less imperical methods............ pedal down.....uh,.... go fast.....pedal down with new mod....uh,,..... go faster..... mod GOOD.....
Old Mar 28, 2006 | 02:01 PM
  #121
Rally@StanceDesign's Avatar
Rally@StanceDesign
Definitely sounds like a good plan to me
Old Mar 28, 2006 | 02:03 PM
  #122
simplygriff's Avatar
simplygriff
Coordinator :: Tar Heel MINI Motoring Club
^^My kind of logic... The butt Dyno is usually enough for me.
-G
Old Mar 28, 2006 | 02:57 PM
  #123
Barnabas's Avatar
Barnabas
Can someone explain to me how the IC achieves outlet temps LOWER than ambient?? I know physics (I have a BS in it) but this is puzzling for an air-to-air IC. I'm not getting it at all
Old Mar 28, 2006 | 03:02 PM
  #124
SpiderX's Avatar
SpiderX
I think it is "general" rather than "special".
Old Mar 28, 2006 | 03:04 PM
  #125
Barnabas's Avatar
Barnabas
Either I'm REALLY tired, or my brain cells are dying off at an insanely quick rate. I have no idea what you're talking about. lol
Unless you're talking about just gen. phys vs. special phys(quantum theory etc), but that makes no sense...ARG! :impatient
