Drivetrain How to reset the stock ECU ??
Old Mar 14, 2006 | 10:42 PM
cloudpicker's Avatar
cloudpicker
Hi all,
i have just installed a 15% pulley and a cold air intake lately, trying to re-set my ecu, and after my search, i seems to find different version of answers. can anyone point me to the right procedures?
Thanks in advance.
Old Mar 15, 2006 | 12:20 AM
etalj's Avatar
etalj
http://www.mini2.com/forum/showpost....98&postcount=5
Old Mar 15, 2006 | 01:56 AM
cloudpicker
did you try out this method yourself? because all i heard is pull off the +ve and -ve of the battary. anyone else?
Old Mar 15, 2006 | 04:06 AM
etalj's Avatar
etalj
i've tried it many times and its worked each time. Alternatively, you can disconnect the -ve terminal of the battery and leave it for about ten mins or so and reconnect, but this takes too long IMO. Good luck!
Old Mar 15, 2006 | 07:23 PM
Dr Obnxs's Avatar
Dr Obnxs
I cannot believe how many threads this information ends up in!
That's the OBC reset procedure. It's not the DME (ECU) reset procedure. ECU requires factory tools.
Matt
Old Mar 15, 2006 | 07:28 PM
obehave's Avatar
obehave
Matt
More than 2 I think
Old Mar 15, 2006 | 09:43 PM
Dr Obnxs's Avatar
Dr Obnxs
Seems like a thousand!
Originally Posted by obehave
More than 2 I think
but I guess that's OK, I was misinformed once too!
Matt
Old Mar 15, 2006 | 09:45 PM
MSFIT's Avatar
MSFIT
How about disconnecting the ECU leave it off for a little bit and then plug it back in?
Old Mar 15, 2006 | 09:49 PM
Dr Obnxs's Avatar
Dr Obnxs
I don't think that does it either....
I had a DME reset done for a TB change so the ECU could learn the new potentiometer positions for full open and full closed. It wiped all the personal preference settings as well, and they had to reset them all.
I think the battery trick worked on older ECUs because flash memory was soooo expensive, they used cheaper RAM that needed power to keep things "remembered". Now flash is cheap, so you can add memory that will remember things through everything short of a lightning strike, or a bunch of really energetic cosmic rays!
Matt
Old Mar 15, 2006 | 09:50 PM
etalj's Avatar
etalj
that's the same as doing the other one, that resets the OBC....but that resets the ignition and timing adaptation I'm sure...
Old Mar 15, 2006 | 11:07 PM
Tüls's Avatar
Tüls
Turbius Maximus
this is correct....if you disconnect both sides...in the engine compartment it will reset...however, you must wait one minute after the car has been shut off to ensure all post ignition procceses are completed... thank you and have a great day....LOL...(sorry I had to add that...it sounded like some kinda technical recording...LOL)
Old Feb 9, 2008 | 06:43 PM
qweewq12's Avatar
qweewq12
Sounds like the only way to reset it is to use a obdII reader or to pull the ECU connectors?
Old Feb 9, 2008 | 09:49 PM
lanevomr's Avatar
lanevomr
why reset the ecu? I don't get this thread. Are you looking to re-program the ecu after the mod or there is something else I missed?
Old Feb 10, 2008 | 04:49 AM
qweewq12's Avatar
qweewq12
Clear SES light(s) w/o using a code reader...
Old Feb 10, 2008 | 05:20 AM
qweewq12's Avatar
qweewq12
Just tried the "disconnect neg battery term, press brake pedal for 10 secs and then wait 15 mins"... SES light was still there upon re-connect...
I do have a code reader (actron cp9125) coming this week, so I guess I will give that a go...
Old Feb 10, 2008 | 08:05 AM
jhiggs26's Avatar
jhiggs26
If it was a 'fluke' thrown code then after a number of clean drive cycles your SES light will go out.
Jeremy
iggi
18
Feb 9, 2026 01:00 AM
DeniseNY R52
May 17, 2016 05:16 AM
portedbuckle
Sep 11, 2015 07:02 AM
Jacob Kenney
Sep 1, 2015 10:22 AM
robbiedowns22
Aug 25, 2015 12:20 PM
