Drivetrain Webb Motorsports HDI Box
Out of curiosity for those shipped all ready or for an order today will you be sending out the larger filters as a replacment once they become available? Any thoughts towards CARB certification for us in Kalifornia ?
John
John
Seems easy enough to swap in the stock stuff when it comes time for a smog test, though.
Just to make sure it is clear, none of the orders placed (all 8 of them) have gone out yet - the production pieces are getting here tomorrow. They will all ship with the larger filter.
No plans for CARB cert - the thing takes 10 minutes to swap once it is in the first time. It can also be ordered powder coated black (though I don't like it for heat absorption) which looks very OEM (roadside check).
Hope that helps!
Randy
Hope that helps!
Randy
Hope that helps!
Randy
Hope that helps!
Randy
... lifting the bonneth is easier than lifting the car
Originally Posted by joker
so why not anodize it? cuz powder coatin' will insulate heat
?! or what do u mean as far as "u dont like it for heat absoption"
Originally Posted by crazyaboutmini
lets just hope your getting a carb certification for the exhaust though
Originally Posted by bee1000n
I don't want to presume to answer for Randy, but I'm pretty sure any intake modification is illegal in California. Dinan's intake is still listed as 49-state legal, for instance. If a company that size hasn't had theirs certified in California, I don't think any others are either.
That may be so, but you are looking at one of the largest air filter companies around! They have the time and money to do something like that. Where as a small company like Webb Motorsports probably does not have the time and money to do that. Like some of said, its real easy to change out the aftermarket intake before getting it inspected.
Garrett
Garrett
Originally Posted by garretwp
Has anyone tried this yet with an M7 Strut brace?
Randy, have you confirmed this yet if it will work or not?
Garrett
Garrett
Same here about the M7 Strut Bar
will it clear the WM CAI?
just when I was ready to order an Alta CAI
I would love to see the numbers on that sexy little box Randy
does anyone know if the M7 strut will clear the Alta CAI?
adios,
Charles
adios,
Charles
adios,
Charles
adios,
Charles
Now back to the topic @ hand..
Originally Posted by spiderx
want a deal on a used Alta so I can buy the Webb?
Originally Posted by mdsbrain
Yes it clears. But you will need to trim trim the Alta's rubber trim.Now back to the topic @ hand..Anyone? I want to swap too!
My only concern with cutting the rubber trim is
having less restriction on the firewall against the hot air
making it easier for the hot air to come into play with the CAI.
defeating some of the pourpose of the CAI.
this is why the JCW and the WM CAI's
are making more sense to me
the more I read about enclosed CAI's
I must admit the WM looks very very tempting by the minute
I just wish it had some sort of bling/badge type on top.
Correct me if I'm wrong,
I read somewhere in a thread that putting the M7 bar
will raise somewhat the bonnet and it will not close flush.
can anyone comment on this?
regards,
Charles
What!!!??? you too?....
regards,
Charles
regards,
Charles
Yes the M7 bar will cause your bonnet to not close flush on newer cars due to thicker bonnet insulation. My bar has been on about 6 months and the insulation has compressed alot and the gap is much smaller.
Yea I had to remove the insulation from the hood for the hood to close. By the way i have an 05. So I will be modifying the airbox to only allow cold air from the cowl area as the insulation has been removed and is not sealing the air box anymore.
Garrett
Back on Topic!
Garrett
Back on Topic!
Originally Posted by farmerj
Hey Randy,
Will this unit fit smoothly in a '05 MCSa as a DIY or do I need to wait for you to venture out to CA again? Thanks.
-f
-f
Originally Posted by discodan
what's the difference in hoses for MCS vs. MCSa? length? width?
