Drivetrain JCW exhaust installed, Vibration and Loud?
Old Oct 14, 2005 | 07:50 PM
minis2005DS's Avatar
minis2005DS
Hi everyone:
I just had my JCW works exhaust installed today, after the installation, first, I found it is a bit louder than exhaust (When you turn on your car, you hear "WHoooom....", which is much cooler than stock. But then the installer told me that he found that the JCW resonator is sticking with the center mount plate... Which will cause vibration... Ok, I then give it a try and it really gives vibration to my seat (Make you feel like your seat has the massage feature...). It feels ok at the beginning, but after past though a traffic, I found it starts to be annoying... :impatient
The garage guy told me that the JCW 's resonator is different than the stock one; the JCW one is curving to the bottom (touch that middle plate), but the stock is reverse.. (like mount on air...).
Do you know if this is normal or not? The exhaust was sold from a 2003 JCS owner and mine is a 2005...
Any information will be appreciate.
Btw, I do feel some performance gains after the JCW exhaust installed though.. Very nice.
Old Oct 14, 2005 | 07:54 PM
Morris9982's Avatar
Morris9982
I have that exhaust and have no vibrations.
Old Oct 14, 2005 | 07:57 PM
eVal's Avatar
eVal
It must be the change in hangers from 2003 to your car that is causing the problem - and I'm not sure what the installer did to make it that way
Anyway, I have a JCW with the current hanger set up on my 05 and no vibration. Sounds like he needs to hang it differently to compensate for the change - perhaps someone here can advise specifically how to do it right.
And yes, the resonator is completely different on the stock exhaust, doesn't even go in the same place. Is this guy familiar with Minis?
Old Oct 14, 2005 | 08:02 PM
minis2005DS
Thanks a lot, I am thinking that might be the problem... Since my JCW exhaust is used, it did not come with the JCW exhaust hangers... I am currently using my stock 05 hangers... Maybe that it why?
And do you think if I can purchase the JCW exhaust hangers from the dealer?
Old Oct 14, 2005 | 08:07 PM
eVal's Avatar
eVal
Well, the JCW I got had the hangers integrated on, they were not seperate, I have no idea if you can purchase them individually and weld them on. I assume you have an MCS from the 'DS' in your name (for dark silver)? Just want to be sure we are talking about the same thing.
Old Oct 14, 2005 | 08:25 PM
minis2005DS
Sorry for the wrong words... Yes, I do have a 2005 Dark Silver Cooper S, what I meant was the "Plastic things" which hold the exhaust's hangers (Forgot what it calls.. )
Sorry for the confuse. :impatient
Old Oct 14, 2005 | 08:48 PM
minis2005DS
A small correction... The "plastic things" = gasket, and the middle plate is "cross-brace" which is now stick together with the exhaust Mid pipe... And the installer said the vibration may comes from it? They said I may need to have a different gasket or cross-brace??
Old Oct 14, 2005 | 09:20 PM
minis2005DS
Sorry again, the "plastic things" = Rubber mounting... My bad.
Old Oct 15, 2005 | 05:13 AM
chows4us's Avatar
chows4us
You are trying to use a part for a pre-Jan 2004 car in a post-Jan 2004 car. Its not going to fit right (as you found out).
Ask your dealer what you can do
Old Oct 15, 2005 | 07:49 AM
minis2005DS
Thanks, that was what I am thinking... I will contact the dealer to see what they can do... I really want to keep this exhaust though.
Old Oct 15, 2005 | 02:31 PM
minis2005DS
Problem fixed today! The problem was that installer (newbie) who turn the mid pipe upside down... Which made the mid pipe get in touch with the bottom part of the car.... to cause the vibration..!
Today they just turn the mid pipe and problem fix... But now the thing is... The JCW exhaust is even more quiet than my stock exhaust, but it makes the Rev goes smoother..
Thanks for all your helps, and sorry for the confuse again.
Old Oct 15, 2005 | 07:20 PM
chows4us's Avatar
chows4us
Good fix.
The JCW exhaust is VERY quiet. Quieter than stock. DO NOT think its not just as good, if not better, than any other aftermarket exhaust. Mike Cooper said he designed it that way on purpose because he wanted it "refined".
Old Oct 15, 2005 | 07:23 PM
gmcdonnell's Avatar
gmcdonnell
Question - is it possible to buy just the JCW cat-back exhaust in the U.S.? If so, where and how much?
/gary
Old Oct 15, 2005 | 07:52 PM
chows4us's Avatar
chows4us
/gary
Technically no. However, see http://forums1.roadfly.com/mini/foru...6723926-2.html
$1300
Old Oct 16, 2005 | 06:56 AM
mbcoops's Avatar
mbcoops
You can buy it from Classic Mini, who is a sponsor on this site. I was interested in the exhaust a few months ago and called to get info. It's pricey, but all JCW stuff is.
mb
Old Oct 16, 2005 | 02:28 PM
minis2005DS
Thanks for your input. Yea, actaully I find now the RPM runs a bit smoother than the stock exhaust, but it seems that is has less pop pop sounds (but it is still there) and no more Whoom Whoom noise compare with the stock exhaust...
I really love the JCW exhaust, but not sure if it gives the similar HP as any aftermarket exhaust?? I can tell there is a performance gain, but not really sure how much does it help.
Good fix.
Old Oct 16, 2005 | 03:12 PM
chows4us's Avatar
chows4us
Someone on MINI2 put the same car on a dyno, first with JCW, the second with Borla Race. The Borla made 2 more HP. That about guarantees you that it makes just about the same as the other if you consider the Borla Race exhaust near the top. The JCW is just "refined" as designed
Old Oct 16, 2005 | 06:14 PM
minis2005DS
Cool, now it makes me feel even happier with the JCW exhaust!
and another thing is, since the hanger of the 05 is different the pre 05, now I just use the outer hangers with the mount rubbers for the end pipe..(hope it makes sense), since the center hangers and mounts are not the same... (the hangers in better then 2 end mufflers...), which makes me scare about that they mufflers will fall down one day...
minicoclub
Nov 11, 2015 07:25 AM
dyeLucky
Sep 11, 2015 10:41 AM
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
ASRman
Aug 13, 2015 09:33 AM
papawhiskey
Aug 10, 2015 09:31 PM
