Drivetrain Intake, exhaust, plugs and pulley wheel.....
Old Apr 27, 2005 | 12:51 PM
mcnamaraz's Avatar
mcnamaraz
To anyone whom has done mods like this before, how much of an increase in performance can I expect to see. I am slightly worried that I am going to dump a bunch of money into the car and really not see a huge increase in performance. Here is my list of desired parts.
Alta 15% Wheel
Borla Street Exhaust
Denso Plugs
Alta Intake
Any thoughts?
Old Apr 27, 2005 | 01:11 PM
camelpilot's Avatar
camelpilot
big increase. worth the time/money spent, thats for sure.
WIth all that stuff you mentioned you could get up to 210bhp depending on what your stock hp was to start with.
Old Apr 27, 2005 | 01:13 PM
rataha's Avatar
rataha
I am thinking 190 but I am not well versed in these things
Old Apr 27, 2005 | 01:14 PM
sfjames2's Avatar
sfjames2
That list of mods will put a bigger grin on your face.
I'd suggest the Borla Race though instead of the street.
Old Apr 27, 2005 | 01:21 PM
kaelaria's Avatar
kaelaria
190 is much more accurate.
Old Apr 27, 2005 | 01:29 PM
dragonwang's Avatar
dragonwang
I think you need software to make it a bigger improvement. I last dyno'ed at 170whp & 160wtq with Alta 15% pulley, GIAC chip, and IK22 plugs.
Old Apr 27, 2005 | 02:16 PM
mcnamaraz's Avatar
mcnamaraz
Ok
I am starting with stock HP....at altitude.....5200 feet (Denver) so I am starting with about 155 rather than 163.....but it sounds like most people think I will see a huge difference....
more thoughts?
Old Apr 27, 2005 | 02:33 PM
camelpilot's Avatar
camelpilot
After recalculating, I agree, 190.
Old Apr 27, 2005 | 02:36 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
You will definatly see a noticable difference, weather its huge or not depends on what you actually expect. There is no doubt your car will behave completly different with an exhaust, pulley and inake.
Old Apr 27, 2005 | 02:44 PM
002's Avatar
002
I have that set up, but with milltek cat back and MTH and got nearly 190 at the wheels. 188whp 163wtq to be exact. This helped me lose a full second from my 1/4 mile times.
You will definitely notice the power, but it won't be earth shaking.
Old Apr 27, 2005 | 03:12 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Alta 15% Wheel
Denso Plugs
Alta Intake
Any thoughts?
Usually the MCS gets about 143-145 wHP which is the number you want to watch. It varies alot and you are at high altitude.
These are conservative estimates- you'd need a good dyno done to know exactly.
Any 15% pulley would gain about 13-15 wHP at best. You might add another 5+ wHP with a good matching ECU software upgrade.
Borla street-It's quiet and isn't the most high HP system. Figure about 4 or 5 wHP.
Plugs- nothing gained for HP
Alta intake- figure about 5-6 wHP if that much. Makes alot of noise.
So at best about 168-171+ wHP or about 190 HP vs 163 HP for stock. All depends what you start with at the stock level.
Having the right ECU software would be a good thing.
Old Apr 30, 2005 | 05:27 PM
gollygwagen
Guest
Posts: n/a
Save yourself some guessing, buzz down to Highlands Ranch and take my car for a spin. Pretty much what you are shooting for in mods.
Old Apr 30, 2005 | 07:33 PM
mcnamaraz's Avatar
mcnamaraz
Ok
I have tried to contact Randy at WMS, but with no reply yet. I understand things are very buys for him right now and he is taking time to reply to people's messages and what not.
Is there a way I can contact you and take your car for a spin?
Old Apr 30, 2005 | 07:50 PM
Rep. San Marino's Avatar
Rep. San Marino
For the average driver not doing 1/4 milers, what can I expect to see in improvement with these mods in the 0-60mph? Thats the most important for regular work driving in my opinion. Off the line in lights when I need to get out in front to cross over three lanes and hit the on ramp.
Old May 4, 2005 | 08:44 PM
supersand's Avatar
supersand
I just had these same three things changed over on my 04 mcs. I had a 15% pulley, a milltek exhaust, the JCW intake and denso plugs added. After the additions the increase in performance is definately noticable... (read not imaginary or wishful thinking). The lower end of the RPM range is more drivable now. I agree with others though this isn't magic (it's not like "getting a whole new car")... the engine is still has only 1.6L... but I'm happy with the percieved/real gains I feel. If you were doing it on a budget just get the pulley as I imagine (and what others have shown) is where most of the difference comes from.
Erik
Old May 5, 2005 | 04:52 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
Let me throw this into the mix...
For $139 and not much more in labor (when you're putting the SC pulley on) you can add a lightweight Alta crank pulley. I noticed a big difference in power low down in the rpm band. Less bog on starting from a stop.
Old May 5, 2005 | 05:45 AM
jlm's Avatar
jlm
" Less bog on starting from a stop"
typically, with lighter rotating components (flywheels, crank pulley) you tend to get more bog, which is why drag racers don't like lightweight flywheels.
the real advantage is when you frequently want the engine to speed up and slow down and do it quickly, like road racing.
Old May 5, 2005 | 09:31 AM
Veni_Vidi_Vici
Maybe I've just naturally started to launch at higher rpm's. Let's say this, then: there was an obvious, positive difference.
Teh
Aug 22, 2022 04:37 AM
W0TM8
Dec 19, 2019 07:50 AM
tr3y003
Oct 22, 2015 10:48 AM
David.R53
Sep 1, 2015 06:49 PM
maniacalmorgan
Aug 19, 2015 08:44 AM
