Drivetrain OBX-Racing Header Dyno Results!
Old Sep 27, 2005 | 07:51 AM
  #301
jbsf3's Avatar
jbsf3
OK- I just ordered mine, I'll keep you guys up to date when I get it installed. 1FSTMINI- as far as any problems with the header- they sounds more like install issues that any good/professional installer could handle fairly easily...no?
Old Sep 27, 2005 | 08:24 AM
  #302
Android993's Avatar
Android993
OBX Header
I got mine with all the parts included, donut, flange, gasket etc. Just got it back from JetHot with the coating and am looking forward to putting it together with a new high flow cat. My question is:
Did anybody do it on jackstands? Or is a lift required?
I wanted to clamp it all together and then drive it over to be welded together.
I think the bang for the buck fits in line with the car and a marginal gain from SuperSprint would be negated. My $0.02 worth
Old Sep 27, 2005 | 08:43 AM
  #303
jbsf3's Avatar
jbsf3
Android993- WOW! That looks great. I want to get mine coated also but not sure how that would work since I'm going to have the factory CAT welded on? I guess I could remove it from the car once it is all together but then I'd have to drive it with no exhaust- somehow I'm guessing that wouldn't last long!
Old Sep 27, 2005 | 08:49 AM
  #304
1FSTMINI's Avatar
1FSTMINI
correct me if im wrong........But your welding your cat to a flange they supply which then bolts to the header..right?. I know that how other companies do it that way for use of a off road pipe if you want to take the cat off.
How much is the jethot coating?
Old Sep 27, 2005 | 09:03 AM
  #305
Galaxie500's Avatar
Galaxie500
Does anyone have any ideas on how I can get a replacement donut gasket? As noted above, mine has failed and I have an exhaust leak now.
Help!!
Old Sep 27, 2005 | 10:04 AM
  #306
1FSTMINI's Avatar
1FSTMINI
Try bring the sample to your local muffler shop to match it up....I dont see why they wouldnt have something that fits.
Old Sep 27, 2005 | 10:31 AM
  #307
jbsf3's Avatar
jbsf3
1FSTMINI - that is a great questions, I'm not sure. I hope you are right as I really want to have this thing coated. Anyone have any info?
"correct me if im wrong........But your welding your cat to a flange they supply which then bolts to the header..right?. I know that how other companies do it that way for use of a off road pipe if you want to take the cat off."
Old Sep 27, 2005 | 11:39 AM
  #308
ripley's Avatar
ripley
What's up at Sparktec??
I'm ready to take the plunge and do this upgrade. Just to be sure I could get a header, I tried to call Sparktec. I've tried several times. No answer, no voice mail. I've dropped several emails but no response there either. Are these guys still in business? I don't want to place an order over the web or thru ebay without knowing they're around and have inventory. Anyone have any insight?? Or, does any have first hand knowledge of other vendors selling OBX headers for the MINI? And would you recommend them?
thanks, ripley.
Old Sep 27, 2005 | 12:49 PM
  #309
BluMiniMe's Avatar
BluMiniMe
Originally Posted by ripley
I'm ready to take the plunge and do this upgrade. Just to be sure I could get a header, I tried to call Sparktec. I've tried several times. No answer, no voice mail. I've dropped several emails but no response there either. Are these guys still in business? I don't want to place an order over the web or thru ebay without knowing they're around and have inventory. Anyone have any insight?? Or, does any have first hand knowledge of other vendors selling OBX headers for the MINI? And would you recommend them?thanks, ripley.
Dan = Spartec. If he has posted an auction, then he has it in stock. He doesn't put up an auction unless he has them in hand. You'd be safe to "buy it now" if there is one.
Old Sep 27, 2005 | 12:58 PM
  #310
1FSTMINI's Avatar
1FSTMINI
Check out this post in the beginning of this one. This shows you the set-up.
https://www.northamericanmotoring.co...achmentid=4687
I dont recommened tightening the spring that much also as you see in the pic....Pointless on a flex joint.
Old Sep 27, 2005 | 02:59 PM
  #311
jbsf3's Avatar
jbsf3
So it looks like I can coat the header before having the shop do the welding work- that is good news....now I just have to decide on a coating. I'm no so worried about looks- I am more concerned with keeping the engine bay as cool as possible- not too easy with an all black car in Texas!
Old Sep 27, 2005 | 04:52 PM
  #312
namwob's Avatar
namwob
It should be easier with jackstands Because the wheels dangling moves the sway bar out of the way more.
Old Sep 28, 2005 | 08:37 AM
  #313
MINIAACK's Avatar
MINIAACK
My OBX is being installed today. I noticed that the precat would be removed. How much louder will my MINImonster be? I also do have a dynomax catback. Is it possible to run the precat and OBX?
Old Sep 28, 2005 | 08:44 AM
  #314
1FSTMINI's Avatar
1FSTMINI
In one word....LOUD.....Dynomax was never quiet on any car ive heard. You'll find out soon enough, wont ya.
Old Sep 28, 2005 | 08:57 AM
  #315
dcummings's Avatar
dcummings
OBX header
I noticed a slight sound level increase after the install. I have a Milltek exhuast and the sound still isn't as loud as the Alta Intake, but almost. I like it!
Old Sep 28, 2005 | 09:58 AM
  #316
jbsf3's Avatar
jbsf3
MINIAACK - be sure to post your impressions when you get your car back. I'm interested in hearing if it is indeed any louder with the header installed.
Old Sep 28, 2005 | 10:04 AM
  #317
J0kER's Avatar
J0kER
same here!!
Old Sep 28, 2005 | 04:32 PM
  #318
Bahamabart's Avatar
Bahamabart
Same here - while I am using the one-ball exhaust, I found it louder as well.
Old Sep 28, 2005 | 05:10 PM
  #319
jbsf3's Avatar
jbsf3
Bahamabart- was it louder at all RPMS or just WOT? Also did the tone change at all, did it get deeper? One last question- was it WAY louder or just a bit louder?
Old Sep 28, 2005 | 05:12 PM
  #320
Android993's Avatar
Android993
For the JetHot coating it was $165 plus shipping both ways. Really came out nice. I have a '68 Shelby 500KR 428 with headers that have the grey and it looks okay - since its a matt color it doesnt have the shine that the silver has. I'm going to clamp it all together and then drive it over. At least I dont have to wear ear plugs and the shop is a bit of a drive to get the welding done.
Old Sep 28, 2005 | 06:03 PM
  #321
J0kER's Avatar
J0kER
did u say ur going to have it welded after the jethot or ur jus goin' to clamp it together.....wont the clampin' break the coatin' off?
and if ur goin' to have it welded, wont that be defeating the purpose of the jethot
Old Sep 28, 2005 | 06:29 PM
  #322
jbsf3's Avatar
jbsf3
Joker- see post #310 above- doesn't look like the coating will be welded on...
Old Sep 28, 2005 | 06:52 PM
  #323
J0kER's Avatar
J0kER
im not catchin' the relation cuz what i was referin' to is if u have something coated then weld it it will defeat the purpose of the coating unless it gets coated again after the weldin' is done or will it work fine since they will be using stailess steel to weld it, therefore it will be ok....when ever i used the jetcoat method all welding and fittin' was done (cuz when i used it i had to bang/clearance it out around the header bolts on all my chevy blocks) prior to coatin' so as to not disturb the coatin'
Old Sep 29, 2005 | 01:20 PM
  #324
jbsf3's Avatar
jbsf3
MINIAACK- any updates?!?!?!?
Old Sep 29, 2005 | 08:26 PM
  #325
///ACS330Ci's Avatar
///ACS330Ci
OK, I just read through all 13 pages of this thread, so forgive me if I missed something but which Random Cat was the correct one to use with this setup? I think someone posted that one of the two was too big, but I didn't see which one was the best option.
TIA
