Drivetrain Heat shielding for under the bonet
Old Mar 25, 2019 | 03:55 PM
cyberlunacy's Avatar
cyberlunacy
Not my best work but doesnt do a damn thing.
So the question is, should i have NOT push it down theough all the nooks and crannies, should i instead of just stuck it to a few places and left a gap between the hood and heat shield creating a barrier?
if it doesnt really matter then i can tell you this stuff i got doesnt do a damn thing, infact the outside feels like its hold more heat than inside outside is about 130F and inside is 105F at its max’s and turbos hottest unshielded area is about 230F
this is after about 20 min after ahutting the engine down
Old Mar 25, 2019 | 10:12 PM
blue al's Avatar
blue al
Looks like you have put another lid on the saucepan ?
ie it's holding heat longer, and reflecting back into the engine bay
Old Mar 26, 2019 | 07:44 AM
cyberlunacy
That’s the whole point of a heat shield it’s to protect the hood from getting too hot but it’s actually having the opposite effect
Old Mar 26, 2019 | 08:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
A typical heat shield does not contact the surface you don't want to get hot. You need to have an air gap between your "shield" and the hood.
Old Mar 26, 2019 | 10:48 AM
cyberlunacy
damn it i figured i did that stuff wrong... ugh that is some sticky glue on that thing
Old Mar 26, 2019 | 11:26 AM
DneprDave's Avatar
DneprDave
The best thing you can do is to insulate the hot side of the turbocharger, it'll drop the under hood temperatures dramatically and it is good for the turbocharger, increasing tit's efficientcy.
This is what I put on my car. http://www.waymotorworks.com/wmw-turbo-heat-shield.html
Old Mar 26, 2019 | 07:49 PM
thebombardier's Avatar
thebombardier
This. I bought a PTP turbo blanket from Detroit Tuned and that did more for under hood temps than my AEM intake, AEM heat shield, gold heat tape, removing the hood scoop grill. I can do multiple back to back hard pulls, have a red hot downpipe and put my hand directly on that blanket and it's mildly warm.
Old Mar 27, 2019 | 03:33 AM
knt's Avatar
knt
Not sure what heat shielding material you are using, but I find Zirotec do good material for this kind of work
https://www.zircotec.com/
Old Mar 27, 2019 | 10:37 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
The turbo blanket really helps and then you add the stock shield back in place and it really cuts down the heat and holds in place very well! https://www.detroittuned.com/mini-co...turbo-blanket/
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
djdraddy
R55 :: Clubman Talk (2008+)
Oct 30, 2011 05:46 PM
jtack
Aug 28, 2008 04:43 PM
TonyB
Road Racing Discussion
Dec 30, 2005 08:02 AM
Aliron
Jun 7, 2003 09:58 PM
