Drivetrain Putting 2011 MC S Engine in 2008 MC S
Old Feb 24, 2019 | 12:04 PM
PSUFencer's Avatar
PSUFencer
All --
I don't expect any issues, but I wanted to see if anyone had any cautionary tales or advice to share on dropping a 2011 MC S engine into a 2008 MC S? I am taking the engine and transmission as a unit and ECU from the 11 to put in the 08.
Donor car is: WMWSV3C50BTY22203 -- 2011 MINI Cooper Hardtop 2dr Cpe S -- Turbo
Patient is: WMWMF73598TT86702 -- 2008 MINI Cooper Hardtop 2dr Cpe S -- Turbo
Thoughts?
Thanks,
John
Old Feb 24, 2019 | 01:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It won't be plug and play as the Keys and other computers from your car will NOT communicate with the ECU from the donor car. We get asked about this swap often, and it is cheaper and 100 times easier to just go back with another N14 rather than going to the N18 engine.
Old Feb 24, 2019 | 01:52 PM
PSUFencer's Avatar
PSUFencer
WayMotorWorks -- Thank you so much for the response.
Now I am a bit confused. The 2011 donor car has a production date of 11/10 and has an N16B16A engine with a V757899480 engine block. Does that make any sense?
HELP, serious help!
Old Feb 24, 2019 | 02:33 PM
Eddie07S's Avatar
Eddie07S
Have you seen the engine in the donner car? An N18 will have a cover over the ignition coils on the spark plugs; the N14 will not. The N18 started with model year 2011, but not sure what month. You could go to REALOEM.COM and see where they show when the change occurred. A production date of 11/10 is late in the start of the production year. My 2012 was ordered in late Aug 2011 and delivered in Oct 2011, so your date is about 2 months into the run.
A fun option might be is to get a N14 JCW engine and ecu as those ran through the 2012 models (I think. The N14 did run more years in the JCW than in the S) .
Old Feb 24, 2019 | 03:40 PM
PSUFencer's Avatar
PSUFencer
Well, now my brain really hurts. The patient (bad) engine does not have a cover over the ignition coils on the spark plugs and the donor engine does indeed have a cover over the ignition coils. But based on the numbers on the donor car engine block -- V757899480 -- this should be an N16 non-turbo engine if I am reading all of the guides correctly. Maybe they used the same older block for later N18 builds? Oyy. I'm just not sure. So just FYI, there was absolutely NOTHING on the donor engine that did not hook up effortlessly on the patient car. All of the connections were exactly the same. We had the engine out of one car and in the other car in about 2.5 hours. We are transferring over the ECU and other computers from the donor car now. All I can say is, stay tuned!
Old Feb 24, 2019 | 07:12 PM
Eddie07S's Avatar
Eddie07S
Old Feb 25, 2019 | 04:26 PM
PSUFencer's Avatar
PSUFencer
It will be a short movie, I promise! Piece of cake!
Old Feb 27, 2019 | 07:16 PM
PSUFencer's Avatar
PSUFencer
Ok. So where is the DME located on the 2011 donor car? HELP!
Old Feb 27, 2019 | 08:52 PM
NeonLed's Avatar
NeonLed
https://www.minimania.com/pdfile/R56...%20Upgrade.pdf
Old Feb 28, 2019 | 07:48 AM
PSUFencer's Avatar
PSUFencer
My bad -- I meant the CAS not DME/ECU. But I found it -- what fun having to remove the dash to get it out!
Old Feb 28, 2019 | 08:35 AM
Eddie07S's Avatar
Eddie07S
https://www.dewalt.com/products/powe...l-only/dcs380b
Oh, you wanted to save the dash? ...
Old Feb 28, 2019 | 11:01 AM
MiniToBe's Avatar
MiniToBe
https://www.northamericanmotoring.co...ne-swap-2.html
Whitt
Mar 10, 2014 02:53 PM
Poolemeister
R55 :: Clubman Talk (2008+)
Jun 21, 2013 09:34 AM
Fa53tmini
Jul 5, 2011 04:04 PM
