Drivetrain OCC & Forge Inlet Tube
Old Mar 20, 2018 | 05:45 PM
400mphpc's Avatar
400mphpc
Has anyone done a successful install of an Oil Catch Can with a Forge Inlet tube? If so, would you mind sharing a photo of your work and possible suggestions? Trying to sort out the routing of the tubes and connections before I purchase the OCC.
Attached Thumbnails OCC & Forge Inlet Tube-4d812a3a-6b22-458b-b95e-66550eba6f75.jpeg
Old Mar 21, 2018 | 01:17 PM
Kalibdor's Avatar
Kalibdor
It's not an ideal setup, but it works. Hose coming out of OCC goes down, back behind airbox, up and over. Just long enough not to kink up on the bends. Will be switching to a dual occ soon so it's gonna be tight in there.
Old Mar 21, 2018 | 01:19 PM
400mphpc's Avatar
400mphpc
Thanks. That's almost what I had in mind. Is it working okay for you?
Old Mar 21, 2018 | 01:22 PM
Kalibdor's Avatar
Kalibdor
Yeah it's fine. I previously had it where the return line went towards the front of the engine bay and circled back around from that end but it was in the way when I went to put a scoop air diverter on so I switched it up. For what it's worth the real benefits of catch cans come in when you have one on both pcv lines (hence my switching to a dual setup) but one is better than nothing. And the only really good dual setup I know of is Saikou Michi who are on a couple month wait list at this point (the one I'm waiting for).
Old Mar 21, 2018 | 01:48 PM
400mphpc's Avatar
400mphpc
Okay. Thanks again for the pic and feedback.
Old Mar 21, 2018 | 03:29 PM
ohiojcw's Avatar
ohiojcw
I'll be watching this thread. I have a dual BSH can setup ready to go on my car but the weather hasn't been cooperating. If I get to it soon I'll post up my routing. I was think a 90-degree fitting somewhere in the mix might help clean up the routing because of how the Forge connects...
Old Mar 21, 2018 | 04:16 PM
400mphpc's Avatar
400mphpc
Looking forward to seeing what you do as well.
Old Sep 19, 2018 | 01:08 PM
ohiojcw's Avatar
ohiojcw
forgot to update this... finally installed my OCC a while back and my solution was to, well... i went the easy way..... i ditched the Forge bits for the much more workable Alta TIP.... such a nice well made piece....
Old Sep 20, 2018 | 09:56 PM
iranman's Avatar
iranman
Not the best pic, but this is how I did mine.
Old Feb 5, 2020 | 12:11 PM
Yiuwin Tsang's Avatar
Yiuwin Tsang
Hey sorry to resurrect an old thread, but what did you use to elbow the 90° from the Forge hose? If you used a coupler, what sizes? I've got the Alta CAI too and looks like you have the GTT OCC which I'm also looking at, I believe it comes with connectors, hoses and brackets but the connectors look straight line... Cheers! (FWIW)
Sweet valve cover btw.
Old Feb 23, 2020 | 06:08 AM
Yoshimura 1's Avatar
Yoshimura 1
Look over in the how to section and there's another thread that list everything. I actually commented
on it today.
Visionaire
Aug 9, 2021 10:47 PM
'10JCW
Jun 28, 2014 12:58 PM
dennyh
Dec 20, 2013 03:01 PM
Dead Ringer
R55 :: Clubman Talk (2008+)
Nov 21, 2008 09:40 AM
joshK
Jan 1, 2008 11:01 AM
